Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 02-10-2009, 09:22 PM   #1
dakotadriver
My Ride: 2003 325 xiT
P0014 and P0015 Codes
2003 325 xiT with 62,000 miles:
The SES light came on tonight. I borrowed a code reader from autozone and pulled the following codes:
P0014 and P0015. They seem to point to cam timing. My first thought was cam sensor but I don't want to throw parts at it.
The codes seem to conflict with eachother because the 0014 reads timing over advanced and 0015 is timing over retarded.
Also, it is idling about 100 to 200 RPM above normal. Has anyone else seen this before?
Thanks,
Mark
dakotadriver is offline   Reply With Quote
Old 05-23-2009, 02:14 PM   #2
baller2000
My Ride: e46
have you resolved this? I'm having the same code P0015 only, with BMW fault code 28BC - camshaft bank 1 stiff. would like to know your fix. thanks.
baller2000 is offline   Reply With Quote
Old 05-23-2009, 02:24 PM   #3
BMWh0r3
My Ride: 325CIvic
its the sensors. had the codes pop up in my car. bank 1 is intake side and bank 2 is exhaust. good luck.
edit: get oem sensors. from what i've read, the aftermarket ones last one day or 3 months. in other words, they suck
-Brandon
:eeps:
BMWh0r3 is offline   Reply With Quote
Old 05-23-2009, 09:36 PM   #4
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
We installed a vanos seal kit to resolve his issue. He brought the car to us.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 11-24-2009, 02:35 PM   #5
brandonbigdog
My Ride: 01 330ci
im getting the same codes, p0014 and p0015. I replaced the Intake CPS and nothing has changed. Any ideas?
brandonbigdog is offline   Reply With Quote
Old 11-24-2009, 03:04 PM   #6
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
see post 4
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 11-24-2009, 03:12 PM   #7
brandonbigdog
My Ride: 01 330ci
vanos seals it is then
Old 11-24-2009, 03:14 PM   #8
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
that makes sense.
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro NC dealership.
Eurobahn BMW is offline   Reply With Quote
Old 04-29-2010, 10:04 PM   #9
AlpWhitE46
My Ride: 2 BMW's
Send a message via MSN to AlpWhitE46
Sorry to bring up an old thread but i got this about a month ago... i still drove the car around...
Keeping in mind that from about a year ago..i've had 2 experiences where the car would not start (it would turn all fine just not start...and i kept holding the key it and somehow it turned on)..
There has also been instances where the car would start but had really rough idle or died (its happened but ... also not often) <--- this seems like vanos seal problem
Today however, my car won't start with anything i tried, even tried jump starting it for fun.
I read from the computer those 2 codes...
I highly doubt my car wont turn on because of vanos... Is it high probably in my case it is the Intake camshaft sensor?
Ivan
AlpWhitE46 is offline   Reply With Quote
Old 04-29-2010, 11:09 PM   #10
Starless
My Ride: 02' 325i
P0015: Camshaft Position, Act B - bank 1, timing over retard
P0014: Camshaft Position, Act B - bank 1, timing over advanc.
If it's a sensor, it's gonna be a EXHAUST one and not the intake. "Bank 1" in the code does not mean "intake", it means Cyl 1-3, Actuator means VANOS, "A" means intake, "B" means exhaust. So, the problem is on the exhaust side. If it's a sensor it's the camshaft exhaust sensor. This is per Rajaie. I initially thought it would be intake sensor myself.
My car ran ok with these 2 codes, not perfect but ok. The fact that yours does not start at all baffles me. The codes went immediately away after I replaced the seals. See my P0014 and P0015 write-up here (esp. posts #6 and # 8):
http://www.bimmerfest.com/forums/sho...ighlight=p0014
Starless is online now   Reply With Quote
Old 04-30-2010, 08:15 AM   #11
AlpWhitE46
My Ride: 2 BMW's
Thanks for that
I just really don't see the car not starting due to the seals...it has to be the sensor!
But after that I'm getting the seals!
So i guess i will order the exhaust one
Ivan
Old 04-30-2010, 08:29 AM   #12
AlpWhitE46
My Ride: 2 BMW's
Hey I wanted to pick up the sensors from this site..
http://germanparts.ca/catalog.html
Do you guys think its ok, they are reputable here.
However the part is not OEM, but they are aftermarket german quality sensors..?
Ivan
Old 04-30-2010, 08:39 AM   #13
Starless
My Ride: 02' 325i
Originally Posted by AlpWhitE46 View Post
Thanks for that
Rajaie convinced me that with these code the problem was on the exhaust side. Some people though believe that Bank 1 in the code means intake (more by analogy with other codes). I know it can be confusing. Do your own research and make a decision. I personally would go with the exhaust one.
Also before you spend money on the sensor you might wanna check with a mechanic or other knowledgeble members here if it's at all possible for the car not to start because of the sensor. My understanding was that the bad sensor would cause rough idle or something along those lines...
Sometimes it's a coincidence. It could be that the codes have nothing to do with the fact that the car does not start. I'd look into the fuel pump in this situation. It's like in my bimmerfest thread that I gave you a link to a guy was thinking that his rough idle was caused by these two codes and it came out that his spark plugs were the culprit of that...
When you put the key in ignition two position you shoud hear the hissing sound of the fuel pump building pressure for a couple of seconds. If it's not happening look into further fuel pump diagnostics.
Good luck!
Edit: buy ONLY genuine bmw sensor. Tisher would be the best vendor for that from my point of view :-)
Old 04-30-2010, 08:48 AM   #14
AlpWhitE46
My Ride: 2 BMW's
Ok thanks, I think these guys are fine.
I'm buying both sensors... Bmw quoted 216$ CDN for each sensor!
F THAT
These are 70$ each... and ill get o-rings too.
Just going to replace both i guess. I hear hissing perfectly fine, it should not be the fuel pump
Ivan
Old 04-30-2010, 12:21 PM   #15
jdstrickland
My Ride: '94 325iC & '00 323i
Thanks,
Mark
According to this link, http://www.aa1car.com/trouble-codes/codes_99.htm, those two codes conflict with one another.
I'm not certain what Camshaft B Positiion is, but it can't be both advanced and retarded at the same time unless the sensor that is making the report is having it's own issues.
jdstrickland is online now   Reply With Quote
Old 04-30-2010, 02:48 PM   #16
mujjuman
My Ride: not an E46
Wow that's crazy
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 04-30-2010, 03:32 PM   #17
AlpWhitE46
My Ride: 2 BMW's
I bought the intake and exhaust one i will change them and let you know if car works
Ivan
Old 04-30-2010, 06:45 PM   #18
jdstrickland
Why replace them both? Only one is reporting an error.
Old 04-30-2010, 08:42 PM   #19
AlpWhitE46
My Ride: 2 BMW's
If i'm doing one, I might as well do the other.
I'm at 150,000 KM...its about time?
Ivan
Old 05-02-2010, 09:58 AM   #20
AlpWhitE46
My Ride: 2 BMW's
Ah i give up.
I put in the exhaust one (mind you the tip is a bit thicker on this after market sensor)
But it fit fine... I couldn't get to the intake one because of the 32mm that i didn't have.
Car did not start.
So next would be the intake one, but i think i'm just going to tow the car.
edit: i just did intake one too, car still won't start lol
Going to get the mechanic to bring me computer to reset ECU?
See if that will do anything/bring up same code?
Ivan
