Old 02-11-2009, 05:30 AM   #1
JacksonY
My Ride: BMW 330Ci (2004 E46)
golf tee mod
out of curiousity... If one were to do the golf tee mod and failed to plug the vacuum line... What would happen?
2004 BMW 330Ci - Sapphire Metalic Black
http://www.conceptfury.com/
JacksonY is offline   Reply With Quote
Old 02-11-2009, 05:38 AM   #2
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
Just use a screw. That way it's more secure
I would guess is the tee drops out, the valve stays closed. But I'm only guessing here.
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 02-11-2009, 05:43 AM   #3
JacksonY
hmm yea... that's fairly straight forward... but I am curious as to what would happen if I didn't plug it properly
The valve isn't affected if the vacuum line isn't plug... but I read somewhere about vacuum leak so I was hoping someone can explain... Thanks in advance
Old 02-11-2009, 11:07 AM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yep, just a vac leak. Just plug it, zip tie it, and go. I've had the same screw in mine for over 2 years.
Old 02-11-2009, 07:32 PM   #5
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
Sorry to thread jack but where does that vac line come from? i tried to source it but i lost it somewhere. lol.
SL Blak Soldier is offline   Reply With Quote
Old 02-22-2009, 01:41 AM   #6
JacksonY
Thats what I wanna know too...
Just really curious what are the effects of a vacuum leak....
Old 02-22-2009, 10:16 AM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
These cars only have one source of vaccum and that's the engine. The effect of failing to plug the vacuum line at the exhaust is the same as if you had a cracked intake boot or any other vacuum leak. A vacuum leak means unmetered air is entering the engine (ie, air is sucked in after the MAF sensor). You could potentially experience lean misfires and rough idle on cold startups. Just plug the line.
Old 02-23-2009, 04:54 AM   #8
JacksonY
Lovely... Thank you!
