#1 |
looking for DIY Differential fluid change....
I am looking for DIY Differential fluid change with pictures... I tried searching but so far I have found nothing. Maybe my searching skills arent the best. Please help.
I have the basics down... Jack rear end up find "fill" plug, unscrew it unscrew "drain" plug, drain fluid into container replace drain plug with a new washer use a pump to fill 75W90 fluid replace the fill plug.
mujjuman
![]() 2003 325xi 5MT Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP sig by Solidjake |
#2 |
Banned User
My Ride: E46 330 and E30 325
Someone didn't look hard enough.
http://bokchoys.com/differential/diff_fluid.htm |
#3 |
Here is one:
http://www.bmw325i.net/maint_rear_diff_fluid.shtml (hopefully the pictures will load for you. For some reason I am having some trouble with this website) You are correct on the basics. Make sure you put the rear of the car on jackstands. This should give you enough room to get the hex into the fill plug. I drove mine onto front ramps and then jacked up the rear and set the jackstands to make it level. All-in-all this is quite easy to do. |
#4 | |
#5 |
Thanks for the links.
Yeah i found that site, but it would have been ALOT more helpful if the pics worked. thanks for the link ken.
mujjuman
#6 |
also, a bit of a n00b question but where can i get ramps? and how much are they?
and what jack should i use, the one that came with the car? i would imagine not...
mujjuman
#7 |
Banned User
Go buy a good jack from Sears or Harbor Freight. Ramps are available at any auto parts store.
#8 |
cool, thanks
mujjuman
#9 | |
http://www.lowes.com/lowes/lkn?actio...3JS&lpage=none I bought the heavy duty plastic ($46, 12K lbs capacity) ramps from an Advanced Auto store and they work great too! http://shop.advanceautoparts.com/web..._T|GRP2042____ No problems with either set of products and I use them all the time! Hope this helps |
#10 |
yes it does. sweet. thanks!!
mujjuman
#11 |
Thanks for the links to the DIY
#12 |
question; that DIY posted says that the car needs 2 bottles of gear oil, but some people have posted that 1 bottle is enough- so, which is it? i have the liqui moly gear oil, 2 bottles which contain 1 liter each.
#13 |
I believe I used just over 1 bottle...
#14 |
its 1.1 L. So you need a little more than one bottle.
-Maksim DIY: How to Tackle Electronics Projects Need Quality Brakes, Headers, Meyle Products? BimmerBrakes has it! |
#15 | |
Stay stock my friends!
For Manual diff 1 L or 1.06 QT M3: 1.3 L (1.37 qt) Oil spec: BMW SAF-XO synthetic oil Good luck reading the diff fluid threads...get OE if you can figure out how like me!
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#16 |
^ thanks, dmax! yup mine is the auto. i wasn't able to find the oem fluid, so i bought 2 liters of the liqui moly fully synthetic 75w-90 gear oil. i figured it's german, so it's gotta be as good as oem.
