Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
Valve Cover Gasket
I have a leaking valve covergasket 126k on a 2000 323 ci m52.
When I went to replace it the new gasket from the dealer does not seat fully into the valve cover. I was told by the dealer this is normal but the gasket I took out sat flush with the lip of the valve cover. This new protrudes about 3 to 4 mm up from the valve cover channel it sits in. Does anyone know if this is the way it is supposed to fit. Last edited by Blue323ci; 02-18-2009 at 10:14 PM. Reason: correct spelling |
#2 |
My Ride: E92 M3 | S4 | E30
Interesting. You can never trust the dealers, as some of them are really incompetent. You are 100% sure that they gave you the proper gasket?
If so, I say it's okay. Tighten it down with the proper torque specs and see how it goes. If it leaks, go to your dealer and don't be nice....
EUROPROJEKTZ - NorCal Chapter ![]() Ervin (Bay Area Detailer) |
#3 |
Yes it is the same part number I see on realoem.com so thats why I am concerned since it does not sit flush down in the valve cover channel.
