Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Thread Tools Search this Thread Rating: Thread Rating: 228 votes, 4.58 average.
Old 09-25-2012, 11:20 PM   #278201
mtnbound
Town Clown
My Ride: 330Ci Vert, 325iT
Originally Posted by cyberkaa View Post
I was going to ask which part, but then I realized who I was talking to.
All the things!!!
Bay Area Top Dropper
Orient Blue 330 Ci Vert
mtnbound is offline   Reply With Quote
Old 09-25-2012, 11:22 PM   #278202
325inthe510
My Ride: 152ci of madness
Originally Posted by briangl92 View Post
Kalim, the master tech came out and said the injector noise is typical of the M56. Apparently the larger injectors they run are just noisier.
I still find it interesting that with the same 2.5L block, it has a larger intake diameter and higher flow injectors than an M54. Makes you wonder what kinda power it'd make with a good tune and one less set of cats
Apparently the pressure bleed off is also normal. He said there's a purge valve in the pump. He said on rare occasions the valve can go bad but starts will take on the order of 5+ seconds.
The fuel tank filling issue is an issue they're gonna look into though.
Here's a hint (not much)
Feelsbadman
325inthe510 is offline   Reply With Quote
Old 09-25-2012, 11:28 PM   #278203
cyberkaa
My Ride: E46 332i,M3;E30 325i
lawl
-Kalim
(klx photo studio)
Old 09-25-2012, 11:29 PM   #278204
cyberkaa
E30 doesn't like Costco gas. :/
-Kalim
(klx photo studio)
Old 09-25-2012, 11:31 PM   #278205
albeee
My Ride: MKVII GTI
E30 doesn't like much of anything.
Originally Posted by VALMONT View Post
stancewerks is for dudes who pick up dudes for a little stretch and poke.
albeee is offline   Reply With Quote
Old 09-25-2012, 11:34 PM   #278206
albeee
My Ride: MKVII GTI
Not a whole lot. BMW takes the same approach as Honda when it comes to their engines (at least the NA ones)-they're about as tuned as you'll get from the factory.
Old 09-25-2012, 11:38 PM   #278207
325inthe510
Except honda can get as much power as my engine in a 2L 4pot while the jews in Bavaria intentionally make boat anchors so the m3 can look good and elitists on e46f can turn up their noses at us.
Old 09-25-2012, 11:46 PM   #278208
briangl92
My Ride: VQ37VHR
Yes, that's what I've discovered in my research about M56 injectors as well. I've been trying to figure out if they get louder if fuel pressure is low, but so far haven't found any solid data.
I think he meant the non-return valve in the pump.
The system should bleed off pressure slowly. It should fall 0.5 bar or less within 20-30 minutes of the pump being switched off.
Thanks!
Ya it was some sort of valve. Not 100% sure what he called it.
briangl92 is offline   Reply With Quote
Old 09-25-2012, 11:49 PM   #278209
albeee
My Ride: MKVII GTI
LOL, I remember there was a manufacturer who made a CAI for the F22 (S2K engine) and the car actually lost 2 HP.
Old 09-25-2012, 11:50 PM   #278210
325inthe510
lel I thought hondas respond well to bolt ons?
Old 09-25-2012, 11:50 PM   #278211
briangl92
My Ride: VQ37VHR
Then why the larger intake and injectors? From what I've read, the intent was to compensate for the more restrictive exhaust.
Old 09-25-2012, 11:52 PM   #278212
325inthe510
Tarbo it
Old 09-25-2012, 11:56 PM   #278213
mtnbound
Town Clown
yeah, me tooooooooooo
Old 09-25-2012, 11:58 PM   #278214
albeee
My Ride: MKVII GTI
Maybe they hired an engineer without an engineering degree.
Old 09-25-2012, 11:59 PM   #278215
albeee
My Ride: MKVII GTI
Well, 325 owners like to compensate, so...
Old 09-25-2012, 11:59 PM   #278216
albeee
My Ride: MKVII GTI
Briangle
Old 09-26-2012, 12:01 AM   #278217
albeee
My Ride: MKVII GTI
But seriously, BMW put the larger intake and injectors, so my statement stands; you won't be able to do much with the engine after the factory's had their way with it.
Old 09-26-2012, 12:01 AM   #278218
albeee
My Ride: MKVII GTI
Unless, of course, you go FI.
Old 09-26-2012, 12:04 AM   #278219
325inthe510
Albee why are you stalking me
Old 09-26-2012, 12:05 AM   #278220
cyberkaa
It likes making Prius drivers nervous.
-Kalim
(klx photo studio)
>implying the e9x is good, '02-'05 grandpas, '06 gods, '07 og's, '08 n00bs, '09 working class, '10 plebeians, '11 master race, '11 peasants, class of, norcal, norcal gen chaaaaat, norcal general chat
Rate This Thread
