California
Have you seen another BMW while driving around in your area? Maybe you can find their car in the E46Fanatics Garage! Northern California Southern California If you don't have your garage setup, sign up today HERE |
Rating:
#186881 |
My Ride: 633csi & 325i
dang says it can send mine its "too large". file size 62mb
#186882 |
My Ride: E46 332i,M3;E30 325i
If you guys can upload them to photobucket, I'll watch on the computer here.
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings |
#186883 |
uploading
#186884 | |
ModZombie Moderator
My Ride: manual stl gry 330i
Come to think of it, besides the oil leak, the intake boot could be a big deal. I mentioned to raf and he was able to witness it, sometimes when I hit the gas to rev, it would be sluggish and almost not move the engine, the next, it would rev perfectly fine.... might be a vaccum leak huh....
#186885 | |
#186886 |
link to video:
http://smg.beta.photobucket.com/user...6efb4.mp4.html
#186887 |
ModZombie Moderator
i am exhausted and have to be up in 5 hours. If you guys figure something out please post it and I will check in the morning. Thank you seriously for all the help, I am def feeling a little better. Thank you.
#186888 |
np we got your back buddy
#186889 |
get rest
#186890 |
Yep, sounds like you have big time intake problems. Pinging on M54s sounds like a very sharp tap, like a marble hitting the manifold. It'll produce that reverberation you heard in the exhaust, too.
Besides a leak, I would look at the DISA. It's not easy to do a DIY check, but if someone local with the BMW software can help you out, they can actuate the flap to tell you if it's working. The o-ring around is also a potential leak. The good news is that it isn't atypical, so you've a pretty clear diagnosis path.
-Kalim
#186891 |
My Ride: my favorite two feet
So odds are chad needs to replace his intake boot and some back lines to get rid of vacuum leaks. Then hopefully his CCV/DISA is good or in need of replacement without anything else being severally wrong or difficult to replace.
#186892 | |
#186893 |
i have some spare intake boot parts lying around.
#186894 |
The pinging should be worst at idle. The more air the motor needs, the less of a problem a vacuum leak becomes.
-Kalim
#186895 |
But yeah, the DME will try to compensate for the problem, e.g. retard timing, add fuel, etc. It might fluctuate, or it might disable a cylinder, so it won't even be consistent if the motor is shut off and restarted.
-Kalim
#186896 |
ModZombie Moderator
guys, thanks again for talking this through. Def sounds like the right path. I am going to see if I can get an intake boot soon..... also going to source oil housing gasket... pretty sure my disa is shot too, I hear it clicking not long ago...
#186897 |
that reminds me raf still has my injectors
chad should get new ones but yea best of luck chad man diy at his house this weekend |
#186898 |
ModZombie Moderator
Yeah, def going to see what i can do this weekend if i can get the parts.
#186899 |
The De46vil's Army
you can always get them from BMW.
![]() Garage Queen |
#186900 |
| Rate This Thread | |
