California
Have you seen another BMW while driving around in your area? Maybe you can find their car in the E46Fanatics Garage! Northern California Southern California If you don't have your garage setup, sign up today HERE |
Rating:
#190561 | |
My Ride: E46 332i,M3;E30 325i
![]() You miss me.
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings |
#190562 |
My Ride: 633csi & 325i
I think its about $350ish plus the intake manifold gasket $50ish. Unless you go the OFHG route. CCV is much more exposed and easier to check other hoses from the intake side.
#190563 |
What was the routine?
-Kalim
#190564 | |
-Kalim
#190565 | |
Yes, that would be ok with me.
-Kalim
#190566 | |
-Kalim
#190567 |
The De46vil's Army
![]() Garage Queen |
#190568 |
what other cars do you have?
#190569 | |
0491 and 0492 means something's wrong with the SAP. I think you have the vacuum controlled version, right? It's going to be a bit annoying, but you'll have to make sure everything behind the intake manifold is hooked up. If the SAP works, should make sure injection valve isn't clogged. Also, the little check valve (behind/under manifold) fails occasionally.
-Kalim
#190570 | |
Should clear them and make sure they're gone.
-Kalim
#190571 |
-Kalim
#190572 | |
![]() I love this lens: http://www.amazon.com/Canon-70-200mm.../dp/B0033PRWSW
-Kalim
#190573 | |
![]() Bring me back one from your trip.
-Kalim
#190574 |
What a cutie.
-Kalim
#190575 |
-Kalim
#190576 | |
-Kalim
#190577 | |
Black and Proud
Flight would be 2/12 tues
So probably drive up sun night or monday? Trying to decide now... Is everything okay with the scenario? (Minus the accidental s54 swap) [bimmerapp]
![]() Quote:
buy my sedan rear seats (gray leather) sell me sedan pillars!! (black fabric) |
#190578 |
The De46vil's Army
the wifey drives:
2011 KIA Forte 5-door EX: my new 2013 VW Passat SE: VW is currently a driveway queen, while the BMW is the garage queen
![]() Garage Queen Last edited by VALMONT; 02-01-2013 at 01:20 PM. |
#190579 |
i like the passat
#190580 |
-Kalim
| Rate This Thread | |
