Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
Ballast exchange help
I need some help regarding the following problem..
http://forum.e46fanatics.com/showthr...31#post9416831 i've been having flickering problems with the driver side hid (aftermarket, mcculloch brand) and switched the bulbs and the problem did NOT follow, hence i concluded that it must be the ballast or ignitor. now i know very little about these cars, and even less about electrical work, but have been able to switch the bulbs,etc. is it most likely the ballast since there is also a clicking sound coming from the problem side? How do i go about fixing the ballast? it is a mcculloch aftermarket kit, so do i have to have that brand ballast or can i use just about any brand, generic? .. how do i go about replacing the ballast? it is a mcculloch brand aftermarket hid. does it matter what brand the ballast is, etc??? where can i just get a ballast to replace it. thanks for any advice -newbie |
#2 |
1.888.JLEVISW
Have you tried swapping the ballast from one side to the other? If the ballast and igniters are separate, I would swap them individually to see which of the components is causing the issue.
| Tags |
| ballast, flicker, hid |
