E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 02-21-2009, 05:26 PM   #1
Alex D
My Ride: BMW 330 CiC
What battery for an e46 CONVERTIBLE!
Searched for posts on this needing a new batt for my 2001 330Ci vert but only came up with info for the e46 sedan and coupe battery types but the e46 convertible has a different size battery.
Can someone post what battery type fits the e46 convertible and where to buy?
thanks guys!
2007 335i Convertible - Karmesinrot/Korallrot, 6-speed, Sport, Premium, Cold Weather, i-Drive/Nav w/iPod/Sirius
2008 Infiniti G35S Journey - Obsidian Black/Stone, Premium/Sport Packages
2006 Saab 9-3 2.0T SportCombi - Steel Gray Met./Grey, Sentronic, Premium/Premium-Sound/Cold Weather Packages, Xenons
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Alex D is offline   Reply With Quote
Old 02-21-2009, 06:29 PM   #2
BodyMan
My Ride: 2002 325i
Sorry I cant help, but I didn't know there was a difference in the vert battery. Learn something new every day.
BodyMan is offline   Reply With Quote
Old 02-21-2009, 08:44 PM   #3
Team_Persia
My Ride: '05 ZHP 'Vert - SOLD
LOL, when did the vert have a different battery size?
-Amir
Team_Persia is offline   Reply With Quote
Old 02-22-2009, 02:02 AM   #4
cityjohn
My Ride: 2001 M3
I've heard it requires a special vibration-resistant battery that is unique to the convertible body.
cityjohn is offline   Reply With Quote
Old 02-22-2009, 09:07 AM   #5
Tim30250
My Ride: '02 330Ci, '09 G37
Send a message via AIM to Tim30250
Since always. It's smaller than the coupe battery which will not fit the vert. I learned this the hard way when changing mine a few years ago. Everyone talked about the autozone batteries being decent so I picked up (IIRC) the 49DL which people used in their coupes, but it did not fit. I then had to get (IIRC) the 94 series that did.
2002 BMW 330Cic... ZSP, 5MT
Mods: VF Stg. 1 Supercharger, Eibach Pro-Kit Springs, UUC Sway Bars
Original Owner... 51,612 miles as of 02/23/17
Tim30250 is offline   Reply With Quote
Old 02-22-2009, 09:08 AM   #6
Tim30250
You heard wrong. It has nothing to do with vibration, it's just a smaller size.
Old 02-22-2009, 10:41 AM   #7
Alex D
It is a smaller size because the vert has a special mounting mechanism using tie rods to hold the batt .... the battery acts as a " low frequency chassis vibration" damper weight. Now don't laugh this is absolutely true!!! The battery is an integral part on the vert keeping ultra low frequency chassis tremors dampened. That is why the vert battery has this special mounting mechanism with these "tie rods" and that is only the case in the vert.
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Old 02-22-2009, 11:08 AM   #8
BobSC
My Ride: 01 330Cic, 12 750Li
I heard the vibration explanation from my BMW dealer as well. I think it is a part of the overall vibration reduction system.
2016 X5
2012 750Li (Sold)
2012 X3
2007 750Li (Sold)
2004 X3
2001 330Cic
2000 328i (Sold)
BobSC is offline   Reply With Quote
Old 02-22-2009, 11:44 AM   #9
i_ween
My Ride: '02 330Ci Vert
I wonder if the 2x4 the previous owner jammed in next to my battery helps with vibration-dampening? My battery is too small for the battery compartment and has a 2x4 jammed in there to keep it in place...
-Derek
check out my astrophotography:
www.gil-galad.com
i_ween is offline   Reply With Quote
Old 02-22-2009, 11:52 AM   #10
Alex D
I would certainly correct that. The harmonic vibration dampening system using the battery as a weight is certainly a delicate component system in the E46 vert. The battery installation instructions in the Bentley manual explain the process of installing a battery and its not just "clamp it down".
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Old 02-22-2009, 11:55 AM   #11
scottswheels
My Ride: is 10!!
ooo, you vert owners are soo special. who cares?
jk, interesting info. gl op
scottswheels is offline   Reply With Quote
Old 02-22-2009, 11:59 AM   #12
Alex D
From the Bentley Manual. Section 541-1:
"CONVERTIBLE BATTERY -
BMW has designed a special Convertible battery tray with link rods which serve to dampen body flexing and vibration.
CAUTION: The E46 Convertible requires a special battery which is designed for constant vibration. A battery not designed for this will fail much earlier."
My indie shop quoted me $175 installed for an OEM BMW battery ... I think that's what I am going to go with.
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Old 02-22-2009, 12:05 PM   #13
scottswheels
My Ride: is 10!!
go with OEM if thats what you can find that meets the special requirements but for the love of all that is good do not pay to have it installed
Old 03-13-2009, 10:13 AM   #14
Tim30250
This sounds like nothing more than theoretical over-engineering that serves no purpose in practice. I no longer have my battery bolted down with the stock tie-downs, nor do I have a stock spec battery, and I have no perceived difference in vibration or chassis dynamics.
My stock battery, which was presumably designed as such, lasted 3 years. My aftermarket replacement, which presumably is not, has lasted 4 years and counting. So much for that theory.
I paid about half of that for my Autozone replacement and have a battery with far more CCA and reserve than the OEM battery that has already outlived the one that came with the car.
Sorry, I just don't see the need to be so particular with a replacement, especially when the OEM piece seems inferior to less costly alternatives.
Old 03-13-2009, 10:32 AM   #15
Bill W
My Ride: 330ci
It is the group 94 that you need from autozone. I just replaced mine last week and autozone wanted 135 for the battery and did not have any in stock (would have taken a day to get it). So for 45 more I picked one up from the dealer.
Bill W is offline   Reply With Quote
Old 03-13-2009, 11:19 AM   #16
Alex D
It is hard for me to say why BMW did this. One thing I am sure of is that an auto manufacturer will not push up unit cost or complexity unless there is a clear need or value in doing it, whether it is product quality, features, benefits or to be able to charge more margin. I am pretty sure BMW did not install this complex design without reason ...
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Old 03-13-2009, 11:57 AM   #17
bronsky
My Ride: 323ci 2000
Type 94R Duralast battery from Autozone fits perfectly in the vert. I think they only make the size in their top of the line Gold Duralast. A gold Duralast 94R, with a 3 year warranty set me back about $119 last year. Fits perfectly in the clamps and the dampers connect as if the battery is OEM. The price was less than half what the dealer wanted for OEM. I'll bet the Gold has higher amp hours.
I would go with the Gold 94R. That way, you still have the harmonic damper thingy that BMW says is so important to vibration control. No wonder the vert costs so much more than the sedan. lol.
Sedan owners can use the cheaper battery, the 47DL but it will not fit in the vert. Small sacrifices!
Here is my post last year in a great thread on the battery issue. I reported then that the 94R fit perfectly in the OEM clamps, including the dampers.
http://forum.e46fanatics.com/showthr...ronsky&page=11
Bronsky
bronsky is offline   Reply With Quote
Old 03-13-2009, 12:10 PM   #18
Tim30250
I completely agree. Unfortunately, it seems to me that this was an extraneous and overly complex design that serves no perceivable purpose other than cashing in on the proprietary replacement parts.
Old 03-13-2009, 01:00 PM   #19
ss396
My Ride: 330Ci
great thread as usual here on this board. i 330ci that i've owned for 4 years with no battery trouble yet but i know its coming.
ss396 is offline   Reply With Quote
Old 03-13-2009, 02:23 PM   #20
Tim30250
Hmm, if you think that now, you really would have enjoyed it several years ago. As a guy that's been here for better than 7 years now I must say that it has devolved a bit from its beginnings. A little too much talk about lights, tints, wheels, and bumpers these days. Luckily, every thread ever created has been archived so you can find out just about anything you need to about the mechanics and technology of your e46 on this site.
Welcome!
