E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 02-24-2014, 10:21 PM   #81
rawbar
My Ride: 2003.5 M3 vert
thanks, i was expecting the big bar across the top. I think I do have that part, the long screw thing is in there, I'll take a closer look and see if I can figure out how it's supposed to work.
rawbar is offline   Reply With Quote
Old 03-08-2014, 07:11 AM   #82
crackerlee
My Ride: 2003 325Ci Conv.
Should be 94R. Prices vary. Autozone*$165.99; BJs $119; AAA $127.50
crackerlee is offline   Reply With Quote
Old 03-13-2014, 02:46 AM   #83
cityjohn
My Ride: 2001 M3
I'm sure you got it but I took a pic in case. That long screw holds down a bracket along the base of the battery. The rest of the screw's length is just so you can reach it.
cityjohn is offline   Reply With Quote
Old 03-17-2014, 03:22 PM   #84
IcedTea_822
My Ride: 2004, 325Ci Convert.
I got mine from Pep Boys before Xmas 2013, for $165 with tax, but i think they increased the price to $199 now.
Bosch Platinum Series AGM Battery Group Size H7/L4/94R
IcedTea_822 is offline   Reply With Quote
Old 03-17-2014, 03:36 PM   #85
Fritzo2162
My Ride: 330Ci Convertible
Watch out for the drip hose on the side of the battery. Mine snapped off and I have to MacGyver a connection to attach the hose again
Fritzo2162 is offline   Reply With Quote
Old 07-17-2014, 12:36 PM   #86
BimmerTex
My Ride: '07 550i, '05 325Ci
A couple of of follow-ups on the battery
First post...2 questions:
1. for the E46 convertible (2005 325 Ci), does the battery have to be "registered"/"coded"/"programmed" once you've replaced it?
2. I'll search the forum for this but...car starts fine, but the convertible top will start opening but stops after just an instant...no motor running sound or anything...it just stops. Read somewhere that could be a battery issue - that's why I'm thinking about replacing the battery. Any thoughts?
Thanks on both!
BimmerTex is offline   Reply With Quote
Old 07-18-2014, 12:12 PM   #87
johnrando
My Ride: '06 330 CIC ZHP
No, E46 battery does not need coding/programming/whatever. Just put it in. And don't let some db dealer/indy tell you otherwise as some have said. You do on the newer models but not on the E46. As far as the top, not sure, but bad batteries cause all kinds of problems on these cars.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 07-18-2014, 01:59 PM   #88
BimmerTex
Very helpful - Thanks John!
Old 07-23-2014, 10:24 PM   #89
cgj
My Ride: 2006 325CIC
For curiosity sake, what is this coding needed on new BMW's? What is it used for?
cgj is offline   Reply With Quote
Old 07-24-2014, 06:53 AM   #90
avincent52
My Ride: 325iT 5 speed/Sport
Found this explanation on the Munich Motorsport site.
BMW Battery Registration
The electrical system in late-model BMWs is so sophisticated that it tailors charging as closely as possible to both the type and age of the battery. There’s a computer that controls the alternator. When you replace a battery, this computer really needs to know if you’ve replaced the battery or updated the vehicle from a conventional Lead Acid battery to an Absorbent Glass Mat (AGM) type; it charges the AGM differently than a traditional battery.
This process of updating the alternator-control computer is called Battery Registration. Ignoring the registration process after replacing a battery won’t necessarily trigger a Diagnostic Trouble Code or Malfunction Indicator Lamp (‘Check Engine’ or ‘Service Engine Soon’ light). However, be warned that skipping the battery registration process can dramatically shorten the life of a battery in these vehicles and- worse yet- damage components within the entire electrical system.
We have diagnosed some BMWs with failing batteries installed less than a year simply due to failing to have the battery registered! The charging system often shortens the life of an unregistered battery by charging it too aggressively, especially when it is cold, and sometimes damaging other control units. More than once, we have replaced an alternator that failed prematurely because battery registration was not performed when the vehicle’s battery was replaced.
avincent52 is offline   Reply With Quote
Old 12-28-2015, 12:44 PM   #91
Derekwh
My Ride: '01 330cic & '86 E24
We have diagnosed some BMWs with failing batteries installed less than a year simply due to failing to have the battery registered! The charging system often shortens the life of an unregistered battery by charging it too aggressively, especially when it is cold, and sometimes damaging other control units. More than once, we have replaced an alternator that failed prematurely because battery registration was not performed when the vehicle’s battery was replaced.[/QUOTE]
Is there any truth to this?
Derekwh is offline   Reply With Quote
Old 12-28-2015, 12:56 PM   #92
daves325in2012
My Ride: 2004 330cic
No..that's not applied to the e46
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
Old 12-28-2015, 12:58 PM   #93
Derekwh
Thanks, that sounded kind of odd for cars of our vintage.
Derek
Old 12-28-2015, 01:46 PM   #94
ikalinin
My Ride: 06 330ci Convt ZHP
i just bought a [AutoCraft Gold Battery, Group Size 48, 730 CCA] at AAP for $124.63 after $20 core refund.
get 30% off w/ code TRT30
its on sale now, you can get it for $12 less. i will go get price adjustment
http://shop.advanceautoparts.com/p/a...48h6/2130015-P
update: the price just changed back to 160.99. i was able to capture a screenshot, and via chat, i was able to get the $13 refund back to my credit card.
screenshot url: http://s28.postimg.org/shlbewl1n/Capture.jpg
ikalinin is offline   Reply With Quote
Old 12-28-2015, 02:33 PM   #95
Derekwh
I see they have a good deal on the H7 AGM $154 after discount and no core but they are out of stock.
Old 12-29-2015, 11:16 AM   #96
Derekwh
It seems that both Walmart and Advance Auto are out of the H7 Platinum AGM batteries. At least in my area, Northern Calif. I wonder if these are both made by the same manufacturer?
Old 12-29-2015, 08:32 PM   #97
TAWBMW
My Ride: 2001 M3 Conv 6 spd
I am glad this thread popped up again. This is good info. I am reading up on the vanos rebuild among other upcoming pm's like gear box & diff oil changes and the info is all here. I am also rebuilding an 87 Bronco 302 and their forums are no where near as informational as this one so nice job here E46 fanatics!
TAWBMW is offline   Reply With Quote
