Old 02-23-2009, 11:22 AM   #1
mhagley323
My Ride: 330i
Angel Eye Help!
I understand there are tons of threads on this topic but I could not find what I needed. I installed the P46's w CCFL angel eyes on my 99 323. All is in and working except the rings do not come on when i turn parking lights(1 notch to right). Only when turned all the way with normal low beams on. Im not sure how I need to wire this so i can have just the halo's on with the parking lights.
ANY help would be much appreciated, Im kinda new to DIY and it's such a better feeling then paying to have installed.
Thanks!
03' 330i
Mods
|M Tech II|P46| Orion V2|Painted Rear Diffuser and Moldings|Clears|Painted Grills|Koni FSD|Eibach|M6|WeissLicht LED|
09' ///M5
Mods
|BMW Performance Gloss Grills, Gills and Reflectors|SuperSprint|RPI|WeissLicht LED|
mhagley323 is offline   Reply With Quote
Old 02-23-2009, 07:36 PM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
You'll probably get more help over here. Moved and free bump
Tim
tim330i is offline   Reply With Quote
Old 02-24-2009, 01:18 AM   #3
mhagley323
My Ride: 330i
thanks!
Anyone have any advice, I know theirs some guru's out their when it comes to these halo's
03' 330i
Mods
09' ///M5
Mods
Old 02-24-2009, 02:48 AM   #4
Chris-TK
My Ride: Mk VI GTI
If you want them to come on when you turn on your sidemarkers/headlights you need to wire the halos to your corner lights. Most people use them wired up to the ECU compartment as the best way because they act as DRLs and are on all the time.
K.
Chris-TK is offline   Reply With Quote
Old 02-24-2009, 02:55 AM   #5
spikester550
My Ride: 330ci, 86.5 hardbody
Send a message via AIM to spikester550
paging silli3idoit!!!
MODS
ESS TX2, 3.38 Diff, K&N CAI, 19" LM's, UUC TSE3,
30 LED AE, OEM MT2 Front & Rear,
CF CSL Trunk, Black Kidney Grills, Smoked Corners,
Painted Reflectors, M3 Steering Wheel,
ZHP Shift Knob, Clutch Stop, Shark Injector,
15mm Spacers, 3k DDM HID Fogs, OEM M3 Hood,
Coilovers, UUC Sways, and many more..
spikester550 is offline   Reply With Quote
Old 02-24-2009, 11:12 AM   #6
mhagley323
My Ride: 330i
How do i do this. If I connect them into the parking lights will the angel eyes not blink as well when turn signal applied?
03' 330i
Mods
09' ///M5
Mods
Old 02-24-2009, 11:16 AM   #7
Chris-TK
My Ride: Mk VI GTI
Yes they will blink with the turn signal, so you might also want to consider using a designated kill switch and wire them up to that so that they can be turned on or off independently of all other lights.
K.
Old 02-24-2009, 05:07 PM   #8
mhagley323
My Ride: 330i
i suppose i should take it somewhere. I'm not familiar with wires and all that stuff by any means. Thank You btw.
03' 330i
Mods
09' ///M5
Mods
Old 02-24-2009, 05:58 PM   #9
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
You should just wire them up to be always on from the ECU box. It's the red wire w/ yellow stripes
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 02-25-2009, 03:47 AM   #10
Chris-TK
My Ride: Mk VI GTI
Wrong, it's yellow DOTS.
K.
Old 02-25-2009, 04:02 AM   #11
mhagley323
My Ride: 330i
thanks, and I really don't want them on all the time.
03' 330i
Mods
09' ///M5
Mods
Old 02-25-2009, 04:05 AM   #12
Chris-TK
My Ride: Mk VI GTI
Why not? They act as DRLs.
K.
Old 02-25-2009, 11:16 AM   #13
mhagley323
My Ride: 330i
this is true. I guess i'm going to walk out to the garage right now and this. Any extra connectors or wires I need? Also I don't have a soldering iron, do I need one?
03' 330i
Mods
09' ///M5
Mods
Old 02-25-2009, 11:19 AM   #14
Chris-TK
My Ride: Mk VI GTI
As long as you have the angel eye wiring harness you will be fine. Wire the harness up to the rings then tap into the ECU compartment accessory wire and the positive and negative battery terminals and then will work perfectly.
K.
Old 02-25-2009, 11:33 AM   #15
mhagley323
My Ride: 330i
ok nice, thanks for the help man.
03' 330i
Mods
09' ///M5
Mods
