Old 05-28-2014, 02:53 PM   #1
Joe Donovan
My Ride: 2000 bmw 3231
gear warning on PRNDL rough snifting Auto 323I
Any help is appreciated on this one. Car overheated on me on way home. Cut her off, let cool down and got her home. Its a 2000 323I, so I replaced the water pump, thermostat checked expansion tank, brackets hoses ect (replaced them last year). After the new parts were replaced, bled air out- test drove and the shifting was hard- driving and slowing down to stop. The gear light beside the PRNDL was on also. When I redid the cooling issue last year, I also replaces the Transmission thermostat. Any ideas what could be causing the hard shift and get the gear light off?
Joe Donovan is offline   Reply With Quote
Old 05-28-2014, 03:08 PM   #2
Joe Donovan
BTW, it has the GM tranny and fluids/filter were changed last year also. Never had a problem with hard shifting (and warning light) before
Old 05-28-2014, 03:30 PM   #3
lszlszx
My Ride: 1.8T, XC70
Scan for codes with a BMW scanner.
Did the light come on while overheating?
I don't see how that would affect the transmission.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 05-28-2014, 05:13 PM   #4
Joe Donovan
don't recall that. I don't have a scan tool so maybe AutoZone or elsewhere can scan
Old 05-28-2014, 07:36 PM   #5
lszlszx
My Ride: 1.8T, XC70
It's probably unrelated to the overheat. Faulty accumulators can cause hard shifting.
A standard scanner won't tell you much.
Old 09-12-2014, 09:03 PM   #6
ajmarks32
My Ride: 2003 330xi
Have you figured out what was causing the hard shifting? I just swapped out my fuel filter and fuel pump relay which fixed the issue I was having. but now the gear pops up for the transmission and it's shifting hard on acceleration and even harder while slowing down. I have an 03 330xi
ajmarks32 is offline   Reply With Quote
Old 09-15-2014, 12:45 AM   #7
NumbaOneNewb
My Ride: 2003 330CI Silver
hm.... perhaps you guys might want to try the transmission adaptation reset procedure. perhaps that'll help. it couldn't hurt it, i can tell you that. google it up to locate instructions. if you had the software and hardware, it would be a lot simpler and faster.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 09-15-2014, 10:17 AM   #8
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
AUTOZONE OBD 2 scanner will not be able to read the BMW specific codes. Need a BMW scanner like P.A. Soft v1.40 to read BMW subsystem codes..
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 09-15-2014, 11:40 AM   #9
Yewzer B Lewzer
My Ride: 2003 325i
Is your MAF plugged in?
^^Blue Ridge Parkway^^ '03 325i. '74 Jeep CJ-5. '93 Sailfish 170XL. '12 Westside SS Longboard. One of these four are sure to be running at any given point in time.
Yewzer B Lewzer is online now   Reply With Quote
