No Codes/bouncy idle/oil light Video! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-11-2014, 03:03 PM   #1
Dryhuot
My Ride: bmw 320i 2003
ok so im out of ideas here my Bimmer has an idle or electric problem i guess
when i stop the idle drops to like 200. also when i turn on any electrical component idle drops to 400/500 same thing for turning the steering wheel..
i have no codes coming out witch is driving me crazy. ive cleaned the icv checked for vacuum leaks changed the secondary air pump fuel filter and allot more.
any one has experienced this?
Thanks guys appreciated,
Dryhuot is offline   Reply With Quote
Old 09-11-2014, 08:06 PM   #2
bmwguyNC
My Ride: 02 325i/06 330i e90
Send a message via AIM to bmwguyNC
Mine had the same problem. It is gone now as I sold it. Your idle is too low and yes that will definitely cause that oil light. You said you cleaned the ICV you may need to replace it all together. I was told by a mechanic something is causing the drop in idle. Could be ICV, Fuel Filter, fuel pump, I was even told a check valve in the oil filter housing could be it. I know I have read a lot about this and I know anyone with a GT1 software can change the idle by .50 at a time. example 700 RPM's to 750 RPM's. And mine would only do it after I drove it out on the freeway at high speeds. Driving around town it never came on. Almost like when the car was well warmed up. I also changed the oil sending unit, no change, oil filter housing gasket, no change. So basically the car is idled to low to turn the oil pump as it should be turning. Hope this helps somewhat and anyone else help the guy if you can. Get the idle corrected and the oil light will go away.
bmwguyNC is offline   Reply With Quote
Old 09-11-2014, 10:34 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Get an OBDII tool that can read Live/Real Time data. Check and post warm idle Fuel Trim values.
Old 09-14-2014, 02:22 PM   #4
netfatih
My Ride: 325ci
I just purchased a 325ci and it does the same thing. Any solution for this problem? What could be the reason? Which part needs to be changed?
netfatih is offline   Reply With Quote
Old 09-14-2014, 03:41 PM   #5
jfoj
Read the first 3 links below in my signature, pretty much answers most of the questions.
When you buy a 10 year old car, time to start replacing parts! If it is rubber and under the hood, it is time to replace all of the rubber items!
Old 09-14-2014, 04:12 PM   #6
netfatih
My Ride: 325ci
jfoj, I found your very informative posts before I read this thread. Thank you for all those! I was just wondering what Dryhuot did for his car first in order to fix this problem.
But anyway, I have couple cooling problems currently, I've started with water pump, thermostat, expansion tank and fan clutch already.
Old 09-14-2014, 05:03 PM   #7
NumbaOneNewb
My Ride: 2003 330CI Silver
does the check engine light come on when you have the engine off with key in position 2?
I had a bouncing RPM issue which eventually caused the car to stall during braking, but almost guaranteed during braking while cornering. it ended up from what I could tell oil coating and fouling 2 of the spark plugs. they were very wet.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 09-15-2014, 09:40 AM   #8
Dryhuot
not fixed yet im waiting on throttle body gasket and oil level sensor and air dis manif o-ring.
to clean my icv & throttle i will let you know after
thanks guys
