Thread Tools Search this Thread Rating: Thread Rating: 198 votes, 4.98 average. Display Modes
Old 01-16-2012, 06:31 AM   #21
Hermes
My Ride: cars older than you
I have OEM BMW Assist + Bluetooth and I have a card with the pair key code. The controls (R/T+ up/down buttons) are not the best because it just pulls your phonebook in alphabetical order, but one time last month I was driving and dropped my phone under my seat. I was not able to reach it since I was driving up to OC with a bunch of other BMW's and couldn't stop, so I did use the R/T button to make a few calls. Helpful if you have to use it but not great.
Interesting side note, my car has none of those trunk marking about pre-wired for Nav but when I pulled apart my rear deck to solve the rattle I found the wires and the Nav antenna already installed!!! I'm guessing homelink must be pre-wired too.
Respect Your Elders
Hermes is offline   Reply With Quote
Old 01-16-2012, 08:46 AM   #22
Lemonsqr
My Ride: 2001 TiAg 330i
parrot here
Lemonsqr is offline   Reply With Quote
Old 01-16-2012, 02:55 PM   #23
as if
My Ride: 2005 bmw 325xi
Originally Posted by MrBourne View Post
Negative. I guess I should just talk to a dealer/mechanic. Maybe they can help.
For what it is worth, I called the dealer. he told me that if I have the passkey, I should have BT. Hope he is right. he also told me that I should be able to pair the phone myself. He suggested googling for instructions to pair the phone. In the end, we may need to go to the dealer to get it done as long as it is all prewired.
as if is offline   Reply With Quote
Old 01-16-2012, 03:00 PM   #24
samson
My Ride: 05' 330i
Send a message via AIM to samson
I believe at some point, BMW removed the logos in the truck for pre-wiring. My 05 330 is doesn't have any logos either, but is pre wired for everything.
samson is offline   Reply With Quote
Old 01-16-2012, 06:00 PM   #25
ashpelham
My Ride: 2005 325Ci
Want to say thank you to the OP for letting me know that I have Bluetooth in my '05 325Ci!! Didn't even know until today. Went outside with my iPhone 4, and started it right up.
In fairness, I've only had the car for 2 months, but still, a big shout out for THANKS!!!
ashpelham is offline   Reply With Quote
Old 01-23-2012, 08:57 PM   #26
MrBourne
My Ride: 2005 BMW 325i
So I am finally figuring things out, but I still need a little help.
I took apart the carpeting on the left side of my trunk and found this:
What exactly is this unit? The two right plugs were plugged in but the left two ports were empty and for some reason there was a hanging loose plug that I believe is supposed to be plugged into the far left plug.
Is this module only for BMW Assist or does it also have bluetooth capabilities? If my research is correct, I would need to buy a bluetooth ULF module. Any help is appreciated!
MrBourne is offline   Reply With Quote
Old 01-09-2013, 02:39 AM   #27
saxual328ci
My Ride: 2004 325ci
I saw this today. It looks like you need the wiring to connect everything. I'm curious to find if I have bluetooth module in my car. I see that it keeps saying No Phonebook on my display.
saxual328ci is offline   Reply With Quote
Old 01-09-2013, 08:04 AM   #28
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
I have a 2000 323i and I have the official/genuine BMW bluetooth. steering wheel buttons works, phone number/name display on radio screen, calls taken through car's speaker system, etc
Old 07-31-2013, 02:46 AM   #29
edfadude
My Ride: 1999 323i
All E46 models can be upgraded for bluetooth
If you have an E46, your car is wired for a phone and you can add bluetooth using BMW OEM parts. Even if you don't find a microphone above the dashboard, the wiring will be there and you can add the microphone.
I have a base model 1999 323 from the first year E46 was available in the US. I purchsed the Bluetooth ULF with all necessary connectors from www.bimmernav.com.
My install was more complicated because I have the base steering wheel without buttons. However, connectors for a phone were already wired to the center console. I simply purchased a new button for the bottom of the dash and popped it into an unused position next to the heated seat button. Now I just press this button to use voice commands for the phone or the navigation system._nr_
edfadude is offline   Reply With Quote
Old 09-15-2014, 06:47 AM   #30
Alan thomson
My Ride: bmw 330 ci sport
my bluethooth
Hi guys I am new to this site so please bare with me.
I have a 2004 bmw 330 ci sport and cant connect my phone to it.
The phone is a Samsung s3.
It tells me it is paired up but dos not work I have to be holding the phone also the language in the pairing section has changed to I think is French.
I have had it connected but would not load the phone book so I was told to unpair the phone and start again now it wont work. Is there any one that can help please .
Alan thomson is offline   Reply With Quote
Old 09-15-2014, 10:09 AM   #31
Poundingsand
My Ride: 2005 E46 330i
Hi All,
I've been struggling with my Bluetooth as well. I was able to pair my last phone and it worked great, but I recently upgraded my phone, and now it will no longer pair.
I called BMW to see if there was a software update available, or some other method of getting my phone to link. I was told that the E46 Bluetooth system is pretty much obsolete, and is not updateable in terms of software. I was told to get a Parrot and have that installed instead. I'd rather use the existing mic, steering wheel controls, etc, so if anyone has found a solution to this, please let me know!
Poundingsand is offline   Reply With Quote
