Windshield washer fluid light...? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-24-2009, 07:40 PM   #1
iliescu2
My Ride: E36, E46, E53
A few weeks ago the light on the dash came up, I checked the tank and sure enough it was empty so on my next gas trip I filled it up... the light went off and that was that.
2 days ago I was on a roadtrip and the light came on again so I stopped at the next rest stop and filled it up, but the light stayed on. I thought it was strange but I had washer fluid so I didn't care. Yesterday when it was time to come home I ran out of fluid halfway through my trip, but I only sprayed maybe 20 times the entire trip?
My light is still on and I have no washer fluid... it seems like it stays in the reservoir but when I start using it the amount of washer fluid decreases much more rapidly.
The tank itself isn't leaking I checked, so I'm stumped... any thoughts?
iliescu2 is offline   Reply With Quote
Old 02-24-2009, 07:43 PM   #2
Solidjake
Radar Specialist
Solidjake's Avatar
My Ride: '13 328i Msport 6MT
do you have the cold weather package?
Old 02-24-2009, 08:01 PM   #3
//TRD power
My Ride: 3.0 | 200hp | 214trq
Fill it up with water, park it, and check underneath in the morning to rule out leaks.
//TRD power is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-24-2009, 08:22 PM   #4
EDawg
My Ride: :/
it's leaking somewhere. washer fluid doesn't magically disappear into thin air. mine is currently leaking as well. in my case, i think it is the pump itself that is the culprit.
EDawg is offline   Reply With Quote
Old 02-24-2009, 08:51 PM   #5
mashupmark
My Ride: BMW 316i E46
I know it sounds stupid, but you didn't leave the cap off after refilling did you? Mine evaporated after topping up and leaving the cap off! Ooops!
mashupmark is offline   Reply With Quote
Old 02-24-2009, 09:16 PM   #6
//TRD power
over a few months?
Old 02-25-2009, 01:06 AM   #7
iliescu2
I don't know, I have the sports package if that is any help?
No
I will do that to be absolutely sure.
I'm pretty sure it's something else too. It doesn't leak when parked, only when being used. And the stream of fluid on the left is SLIGHTLY weaker than on the right, so I'm thinking some gets lost somewhere between the reservoir and where it exits to hit the windshield. Could be the pump or one of the hoses?
Anyone else have any experience with this acting up?
Old 02-25-2009, 01:28 AM   #8
SaaDiesel
My Ride: 02 330i Tech 1
If you have the cold weather package (heated seats, headlight washers, ski sack etc.) there could be a leak within the headlight washers. It could be the headlight washer pump itself, or where the spray nozzle cover attaches to the pump. My pumps went bad a long time ago and I had them replaced under warranty. You should def. fill up the tank, spray, and check for leaks regardless. These diagrams from realoem may help-http://www.realoem.com/bmw/partgrp.d...25&hg=61&fg=45
E46-7 years STRONG
ZSP/ZPP/ZCW
BFP Intake, Euro Cooling Ducts, OEM Clear Lenses, 8000K HIDS
Matte Black-Grill, Headlight, Window, & Body Trim
SaaDiesel is offline   Reply With Quote
Old 02-25-2009, 04:11 PM   #9
iliescu2
In that case, no I don't have the cold weather package. I was wondering why my other BMWs have heated seats and this one doesn't, thanks for clarifying. So if I don't have the headlight washer pump could it be another pump? I'm thinking that's what it is since the tank itself doesn't seem to be leaking.
Old 02-27-2009, 01:15 AM   #10
iliescu2
Anyone?
Old 02-27-2009, 01:20 AM   #11
mkodama
mkodama's Avatar
It is only held in with 1 bolt. Might as well unbolt it, and unclip the sensors connectors and pump connectors. Then just look around the reservoir, shake the fluid around, etc... Check around where the pump and sensors go in.
Old 02-27-2009, 02:07 AM   #12
JL328i
My Ride: BSM 03 325i 5MT ZSP
mine was leaking a few days ago. took the tank out, sure enough one of the hoses was loose connecting to the pump. its not hard to do at all, just un-bolt the one bolt and its pretty much a no brainer from there....
The 328i that once was... :(
JL328i is offline   Reply With Quote
Old 02-27-2009, 02:20 AM   #13
scott0482
My Ride: 1997 M3
Send a message via AIM to scott0482
mine goes through it insanely fast when i use it.. i remember buying fluid for other cars and i would pour 1/3 of the bottle in.. e46.. you just turn the bottle upside down and let it go.. then a few weeks later if you use it the light comes on again.. i mean, i could care less if it sprays it on my headlights.. but it does.. i want some mini wiperblades on them.. volvo style, that's pimp...
pic related.. but horribly implemented.
scott0482 is offline   Reply With Quote
Old 02-27-2009, 02:23 AM   #14
mkodama
mkodama's Avatar
They aren't on modern cars for a reason...
Old 02-27-2009, 02:33 AM   #15
scott0482
My Ride: 1997 M3
we are in the infancy of automobiles.. in the future they will be laughing at us.. like we laugh at people in horse drawn carriages.. that's scary.. driving is fukin fun..
Old 02-27-2009, 02:35 AM   #16
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
i believe that the washer fluid pump seals tend to die..mine did and it started leaking through the weep hole on the pump.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 02-27-2009, 03:26 AM   #17
sean96gsr
My Ride: '13 335i / '04 ZHP
Yeah, check the seals by the pump, it's probably leaking. Is there a puddle under the car when you park?
sean96gsr is offline   Reply With Quote
Old 02-27-2009, 10:15 AM   #18
CTSport330i
My Ride: 06 CiC ZHP/ 05 X5
Common problem. Replace the washer fluid pump itself. It is only a $40 part from Bavauto.com. It takes 5-10 minutes to replace.
CTSport330i is offline   Reply With Quote
Old 02-27-2009, 02:54 PM   #19
iliescu2
No there's no puddle I think it only leaks when I actually use it (it's been filled and stayed filled for a few weeks, but when I use it it seems to drain extremely fast)
Old 02-27-2009, 04:58 PM   #20
Grovedale
Grovedale's Avatar
My Ride: an E46
I think he is correct, picked a washer fluid pump up at the dealer ($28.00) 10 min later, no problem.
I don't have OCD, I just like things a certain way.
Grovedale is offline   Reply With Quote
