Windshield washer fluid light...? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-27-2009, 05:17 PM   #21
BB BMW
My Ride: 04 330ci ZHP
Raise the hood, start the car, then have someone sit in the drivers seat and use the windshield washer.
While water is being sprayed onto the windshield, look all around the tank, hoses, nozzles, etc.
While it is being used, the leak should be a lot easier to find, since this seems to be when it accurs.
It probably has a cut or split in one of the hoses that lets a lot more water pump out than normal. I would look at the passenger side closely, since this is the weaker stream. The water is going somewhere.
Good Luck
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
Thomas Jefferson
BB BMW is offline   Reply With Quote
Old 02-27-2009, 05:59 PM   #22
Cheema323i
My Ride: 2000 323i
Hey my car has the same problem. I took it to BMW today maybe like 3 hours ago and they told me( without looking at the car) that its probably my headlight washers. they said its usally the first thing to go when it comes to washer fluid equipment.
The guy sounded very sure and said his car had the same problem. 150 dollers a light, so i got the hell outta there.
let me know if it is the headlight spray or something else.
Cheema323i is offline   Reply With Quote
Old 03-01-2009, 02:13 PM   #23
mxli330ci
My Ride: 01 330Ci, 05 M3
my reservoir pump has a weep hole, thats were mine is leaking from. its a rectangle at the bottom near the output tube.
mxli330ci is offline   Reply With Quote
Old 01-12-2013, 04:06 PM   #24
Juliopinto03
My Ride: 2000 328i
does anyone know or can refer me to a link on how to reset the light?
Juliopinto03 is offline   Reply With Quote
Old 01-12-2013, 04:46 PM   #25
My325XI
My Ride: 03 325XI Sprt Prem
What light are you referring to? There is no reset for the windshield washer fluid light. And, did you know that your revived a thread from 2009...
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 01-12-2013, 04:47 PM   #26
Juliopinto03
My Ride: 2000 328i
The winshield wiper light on the cluster. LOL oh snap no I didnt, the search engine took me to this thread.
Old 01-13-2013, 09:24 PM   #27
My325XI
Add windshield washer fluid for the light to go off. If it's full, you most likely have a bad fluid sensor.
Old 06-13-2013, 08:08 PM   #28
2003 325i
My Ride: '03 Orient Blue 325i
Bumping an old thread. Just wondering why the weep hole on the pump itself? Mine started leaking out of there (headlight pump) recently. Why the heck is it necessary? I sealed the weep hole up and am going to run with it until it fails. Worst case scenarios? Leaks again, burn out pump, maybe blow a fuse? I'm not really concerned, just more wondering why bother with the weep hole.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 06-13-2013, 09:06 PM   #29
Blind_Shooter
My Ride: is your sister
do you know a way to test the washer pump? mine has never worked sadly
smells like crayons
Blind_Shooter is offline   Reply With Quote
Old 06-13-2013, 11:28 PM   #30
jdstrickland
My Ride: '94 325iC & '00 323i
You can buy a washer pump at the, wait for it... , the store.
Old 06-14-2013, 12:33 AM   #31
MJLavelle
My Ride: 2001 BMW 330ci
Replace the hose running to the pump. I had this issue too. It would stay full, until I used it a few times. It turned out the hose was leaking badly when it was pumping. So, I would lose a 1/4 tank just washing my windshield. I had replaced the pump and the grommet/screen. But, it turned out to be the hose.
