Old 02-25-2009, 03:44 AM   #1
E4tySick
My Ride: Xich Lo
Question about Power Steering
Hi, Fanatics
i have a 2001 325i and my Power Steering Fluid Reservoir starting to leak out of the top cap. Sometime when i didn't start my engine completely to it working temperature, then when i steer, i can hear this type of noice coming off form the steering. What was the problem. Was it my Power Steering Pump or any other things? Plz help me out
E4tySick is offline   Reply With Quote
Old 02-27-2009, 09:34 AM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Did you recently fill it? If so, did you use ATF or power steering fluid?
For one, it sounds like it's overfilled and if it's noisy, either the pump is gone or you've use PS fluid, which doesn't work in our cars.
