Old 02-26-2009, 01:13 AM   #1
Toadfart
My Ride: 04 330i ZHP
Cold Idle Woes.
So I started getting cold idle stall issues late November and I just wanted to share my experience with trying to get it fixed.
I first thought it was a vanos issue, so having a ZHP I ordered a Dr. Vanos unit to get rid of the "ZHP rattle" and the vanos seal problems. Chris was awesome in shipping and communication along with quick refund for core exchange. Awesome.
Then I found a crack in my valve cover hose, so I ordered one through ECS to replace it. I replace it pretty easily. Someone said that a bunch of crap needed to be replaced to get that hose replaced, but I was able to easily swap it out by only removing the airbox. Shipping through ECS took 2 weeks for some reason, I emailed them for a status of the shipping and received an answer by email 3 days after I received the hose.
I then found out that my thermostat was failing so I figured I would replace that as well as the water pump and hoses. I was short on time so I only did the thermostat and will do the water pump later. I ordered the parts from Pelican Parts and got the product within 2 days. Awesome service.
After all this work, I still have the cold idle issues and decided to check out the lower intake boot while I was doing my thermostat. I found a small crack in the hose that goes into the ICV. I ordered a new ICV, oil and filter for my next oil change from www.getbmwparts.com. It's been 2 weeks and I finally get a tracking number. Well, turns out that UPS lost my package and I'm screwed out of close to $80 bucks I spent. Apparently getbmwparts doesn't do customer service by phone or offer a live person to talk to, so I filled out their form online, but I haven't heard anything from them. If anyone from getbmwparts is reading this please contact me.
So here I sit after close to a $1000 in repairs frustrated with this problem. I owned an Integra with a built motor I put together in my garage which was faster and more fun to drive than my Bimmer, but sold it as it was a high maintenance car..yet I've spent more time and money on my ZHP =[
I just wanted to share my frustration and vent a little bit.
Thanks for reading.
Toadfart is offline   Reply With Quote
Old 02-26-2009, 01:15 AM   #2
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
sux!
Bimmer4Lyfe is offline   Reply With Quote
Old 02-26-2009, 07:50 AM   #3
guest041115
Banned User
I got my first cold idle problems yesterday had the car for a month or so
guest041115 is offline   Reply With Quote
Old 02-26-2009, 11:23 AM   #4
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Then I found a crack in my valve cover hose, so I ordered one through EAS to replace it. I replace it pretty easily. Someone said that a bunch of crap needed to be replaced to get that hose replaced, but I was able to easily swap it out by only removing the airbox. Shipping through EAS took 2 weeks for some reason, I emailed them for a status of the shipping and received an answer by email 3 days after I received the hose.
Thanks for reading.
We don't sell hoses, are you sure you're not referring to someone else?
tom @ eas is offline   Reply With Quote
Old 02-26-2009, 11:45 AM   #5
Toadfart
You're right it was ECS not EAS. I'll make the changes in the post.
Old 02-26-2009, 05:46 PM   #6
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
I don't think M54s get cold idle issues from VANOS seals. You probably have a vacuum leak somewhere. If you're having problems with getbmwparts.com, either evan or jason is usually online on AIM during business hours, or you can PM them on here.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 02-26-2009, 11:36 PM   #7
Toadfart
Awesome. Anyone know their screen names?
Old 02-27-2009, 08:13 PM   #8
Toadfart
Spoke to Jason from Tischer.
Went and bought a new lower intake boot from local dealer and replaced the cracked one. Still stalls.
Old 02-27-2009, 08:45 PM   #9
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Time to read the error codes in the engine. It maybe possible your fuel filter is clogged up and not giving enough juice.
GoingNuts is offline   Reply With Quote
Old 02-27-2009, 10:10 PM   #10
Toadfart
Will the car store codes even with no lights on the dash? I have a fuel filter ready to be swapped when I have free time. Will report results if it takes care of the issue.
Old 02-27-2009, 10:22 PM   #11
GoingNuts
Just Nuts
My Ride: 2004 330Ci
There are always codes in the car. Even your radio and door mirrors report error codes. Although you probably won't have anyway of getting to them without going to the dealer. The check engine light only shows when there are critical errors. The less critical ones are meant to be read when the car is serviced by the dealer.
Old 02-28-2009, 12:49 AM   #12
Toad21
My Ride: 00' 328CI
I have a similar issue that I too assumed it was vanos related. I read the engine codes today and it turns out its code 119, which is the Throttle Body Assembly. I am going to take it out and see if anything is wrong with it and clean it then maybe order a new one if I cant fix it.
Toad21 is offline   Reply With Quote
Old 03-02-2009, 07:55 PM   #13
Toadfart
Replaced fuel filter today and still have issues.
Old 03-02-2009, 08:02 PM   #14
pylt
My Ride: 330i
Just a shot in the dark, but how old are your sparkplugs? If you're anywhere near 100k miles, why not replace those too?
Good luck.
pylt is offline   Reply With Quote
Old 03-02-2009, 08:17 PM   #15
Toadfart
Good luck.
I'm at 57k miles. Replaced 3k miles ago.
Old 03-10-2009, 11:03 PM   #16
Toadfart
Update!
Replaced the entire CCV / oil separator system and hoses.
No dice. I'm really thinking about trading this junk in for something that runs right.
Old 03-10-2009, 11:23 PM   #17
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
How about paying for a proper diagnostic of the issue????? You have thrown so many parts at the car that is comical. Are these all new OEm BMW parts or the cheapest part you can find? But the reality still is you are replacing parts with really no diagnostic behind them!!! Then you complain how expensive the car is??? I am sorry i just don't get it?
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-11-2009, 12:52 AM   #18
Toadfart
The parts I replaced were defective. Vanos rattle gone. Broken thermostat replaced. Cracked intake boots replaced. Goose honk from CCV fixed with replacement. Learn how to read. The parts I replaced had issues, I didn't blindly replace them. I'm glad you're easily amused. Simple things for simple minds.
This forum is here to help each other resolve problems. If you have nothing positive to contribute to this website why don't you get the **** out?
Old 03-11-2009, 02:09 AM   #19
guest041115
Banned User
i had this problem then it went away, but from searching it doesnt look like a "proper diagnosis" (as jbeurotech, the genius, suggested) will help isolate the problem. If mine ever comes back im gonna replace the adjuster unit
Old 03-11-2009, 07:15 AM   #20
jbeurotech
Regional Sponsor
Why not test the throttle body and related components a FAULT IS NOT AN INDICATION A PART NEEEDS TO BE REPLACED. Seriously I am not trying to be a dick but look at all the parts you have replaced already. You either have very bad luck or some didn't need it.
Seth Thorson
