Miscellaneous
Non-BMW parts, Non-BMW for sale, motorcycles, random car parts, home electronics, cell phones, clothing, shoes, concert tickets, video games, pets and anything else you can think of! |
#1 |
Kyosho Inferno GT Aston Martin.......4 Sale!!!! $300 obo
http://newyork.craigslist.org/que/for/1051781755.html
Original price $400. *I haven't even ran 1 gallon of fuel through this car. * Upgraded Futaba magnum 3PM 3 channel FM radio (originally price $130) * Upgraded foam tires for better traction (original price was about $30) * Upgraded servos for better steering and throttle response * Remaining 1/2 gallon of Race 3000 30% fuel (Byrons Originals Inc) * Only needs inexpensive clutch spring.....I can cover cost of that! # Completely factory assembled - it takes only minutes to get running # Expertly detailed, licensed body of the Aston Martin DBR-9 race car # Durable, low-maintenance shaft-drive system based on the Inferno # Two-speed transmission. # 3mm blue-anodized aluminum chassis plate with countersunk screws # Massive GXR 4.6cc engine to spin the tires at will # Zero-maintenance, zero-loss pull-starter # Vented metal disc brake with steel-backed fiber pads # All-aluminum exhaust system with a two-piece tuned pipe # Fully adjustable four-wheel independent suspension # Composite oil shocks with dual O-rings seals and threaded spring pre-load adjusters. # High-traction low-profile 93 x 41mm street tires with foam inserts. # Big 17mm hex hubs to index the wheels to the axles. # Full set of precision ball bearings. # Foam bumper to protect against impacts. # Huge selection of factory and aftermarket accessories # 125cc quick-fill fuel tank with spill guard # Large flywheel for easy, consistent idle Specifications Length: 18.9 in. (480mm) Width: 12.2 in. (310mm) Height: 5.3 in. (135mm) Wheelbase: 12.8 in. (325mm) Ground Clearance: .4 in. (10mm) Track Width: (F/R) 10.31 in. -10.43 in. (262mm - 265mm) Tire Size: (F/R) 3.58 in. x 1.88 in. (91mm x 48mm) Gear ratio: 10.8:1 (1st) / 8.37:1 (2nd) Total Weight: 116.4 oz. (3300g) Engine GXR 28 with pull start
3.38 Diff UUC SSK Shark Injector Conforti CAI H&R RSS Coilovers H&R Sways OEM M3 Strut Bar Reinforced Strut Mounts Rogue Engineering RSM ProjectorE46 M Tech II Rear Ipod Integration |
#2 |
BUMP BUMP
![]() ![]() This car is FAST!!!!!!!! Give it a look. You won't be disappointed!!
