Old 02-27-2009, 05:37 PM   #1
Toad21
My Ride: 00' 328CI
Trunk Lid Lock Actuator
Hello all
My trunk will 20% of the time not unlock, and another 30% of the time will not latch when closeing. Does this mean I need a new Trunk lock actuator? What part/part number do I need to order?
Update:
This is what I needed to order, part 9 ($45)
http://www.trademotion.com/partlocat...layCatalogid=0
Toad21 is online now   Reply With Quote
Old 02-27-2009, 06:33 PM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
trunk latch...but i've heard sometimes there are shorted wires in the boot between the trunk and the body...
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 02-27-2009, 07:08 PM   #3
scottjoh
My Ride: 1999 323i - TiAg
Quote: "On a side note, I am getting new Door Lock Actuators for both sides. I am placing the order soon and thought I should replace this while I am at it."
Why are you replacing the door lock actuators? Doors won't unlock? Could be a GM5 problem.
scottjoh is offline   Reply With Quote
Old 02-27-2009, 07:41 PM   #4
canaryM
My Ride: is strong like bull
I actually have the same problem and I changed my GM5 not too long ago (not because of the trunk issue). Door locks and windows are fine. I doubt that's the problem.
///Sport Package | Nav | Park Distance Control | LED tails
///M3 Lip spoiler | Adaptive Xenons | 62 LED Angel Eyes
canaryM is offline   Reply With Quote
Old 03-01-2009, 09:00 PM   #5
Toad21
My Ride: 00' 328CI
I am still looking for what part to purchase. The electronic lock actuator for the trunk lock needs to be replaced, can anyone help?
I have found this, but I am sure its what I need (part #9 latch)
Old 03-01-2009, 09:05 PM   #6
mkodama
mkodama's Avatar
Have you ever greased your trunk latch? Also I would check to make sure the trunk seal is pressed down all the way. If the trunk seal isn't pushed down all the way, it means you have to close the trunk extra hard and it makes it harder to open the trunk. Try putting your key in the keyhole and turning counterclockwise. It shouldn't require much force to manually unlatch the trunk.
Old 03-01-2009, 10:12 PM   #7
maxboost83
My Ride: 2002 BMW 325Ci
i got a question about the trunk door actuator. when u use the key to remotely unlock the trunk, is it supposed to pop up on its own?
maxboost83 is offline   Reply With Quote
Old 03-01-2009, 10:21 PM   #8
canaryM
Yes.
Old 03-01-2009, 10:35 PM   #9
330CI_DROOLER
My Ride: bimmer?
I have the same exact problem, when I close it it doesn't close properly and I get the light on the dash that its open. When I press the open trunk button next to the driver's seat, it locks the trunk and the light goes away. I've learned to live with it since I dont use the trunk much.
330CI_DROOLER is offline   Reply With Quote
Old 03-01-2009, 10:40 PM   #10
Toad21
My Ride: 00' 328CI
Originally Posted by canaryM View Post
Yes.
Ok my trunk does not auto pop up either. Someone please be kind and help me find out what part I need. I have tried greasing the lock itself, it moves freely, it is the electronic motor actuator that is bad as far as I can tell.
Help!!
Old 03-02-2009, 09:48 AM   #11
Toad21
My Ride: 00' 328CI
anyone?
Old 03-02-2009, 12:23 PM   #12
Toad21
My Ride: 00' 328CI
Well I just ordered the one in the link above, I hope its the right one!
Old 03-04-2009, 02:27 AM   #13
amowolves
My Ride: 330ci
i have the same problem....
I've sent the car back to the dealership twice already with regards to the boot release not working properly. when i press the boot release button on the remote i can hear locking the mechanism clunking away but it doesnt release the boot unless i tug on it at the same time. and then when i go to close it, i have to press the unlock button on the remote again otherwise it doesnt shut.
now theyve had it back twice and each time theyve said theyve changed a part but they look like the same parts to me, so im wondering if they even bothered. Im sure they probably only adjusted the metal plate that the latch hooks onto as it looks slight;y out of place? it looks like its designed to be adjusted as theres two screws covered by plastic clips?
any ideas, shud i try adjusting the latch plate or should i just ring em up again?
Thanks in advance
Amo
amowolves is offline   Reply With Quote
Old 03-07-2009, 09:06 PM   #14
Toad21
My Ride: 00' 328CI
I should have the new Trunk Latch Actuator peice, linked above, on monday then i will post how the install goes. I have yet to find a DYI for this, since I have replaced the door lock actuators myself, I am sure I will figure it out and probably write up a DYI.
Old 03-08-2009, 01:29 PM   #15
Toad21
My Ride: 00' 328CI
So I took out the trunk lock actuator last night and it was the easiest thing to do probably why there is no DIY.
I do have a question for you gentleman though:
So the trunk is supposed to auto open when you press the unlock trunk button? If it just unlocks and does not pop up it must be the struts are not powerful enough anymore correct?
Old 03-10-2009, 12:24 PM   #16
Toad21
My Ride: 00' 328CI
So I replaced the Trunk Lock Actuator last night, and that was the culprit! Now my trunk opens and closes every single time.
FYI, i will upload picture later tonight.
Old 09-01-2011, 07:34 AM   #17
ComCool
My Ride: 330CI
Does the trunk now auto open? When I press they remote to open the trunk, my trunk just unlocks and relocks. I have to pull the trunk while pressing the remote to make it open.
Best Regards
Dennis
ComCool is offline   Reply With Quote
