Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 03-01-2009, 05:49 PM   #1
kyle808
My Ride: 00 328CI
Need help identifying OIL LEAK.
I think it's leaking about 1 qt every 2,000 miles. There's an oil spot on my driveway. My car has 143K miles and I changed the valve cover gasket at 101K miles. Any help is appreciated.
Where else can it be leaking?
Does this picture help at all?
"I'm gonna die! Jesus, Allah, Buddha - I love you all!
-Homer Simpson
kyle808 is offline   Reply With Quote
Old 03-01-2009, 05:53 PM   #2
shockin330i
shockin330i's Avatar
My Ride: '13 AW F10 535i
Send a message via AIM to shockin330i
I have the same problem....
ERnie
2001 330i Steel Blue e46 "Vanessa" [retired]
2011 335i AW e90 "Zoey" [retired]
2013 535i AW F10 "Lola" [retired]
2013 5.0 "alessandra" [retired]
2014 5.0 "jessica" [retired]
2011 135i JB E82 "Latoya"
Originally Posted by Nay330Ci View Post
:drool:
i'd cosign loans for that ho
Thanks dude. I knew she was a keeper when she blew me during a game of cod. I didn't do too well that game
shockin330i is offline   Reply With Quote
Old 03-01-2009, 05:55 PM   #3
kcgviceprez
My Ride: 2010 135/2008 //M
oil filter housing gasket is my guess...
i had a problem like this mine was the oil filter housing gasket, costs like $5 from the dealer part #
its part number 11421719855 and #6 on the chart
kcgviceprez is offline   Reply With Quote
Old 03-01-2009, 05:56 PM   #4
shockin330i
What number is it on the chart?
ERnie
:drool:
Old 03-01-2009, 06:03 PM   #5
kyle808
My Ride: 00 328CI
its part number 6 11421719855
was your's leaking at the same spot on the engine splash cover?
Was it any easy DIY to change out the housing gasket?
thanks.
-Homer Simpson
Old 03-01-2009, 06:30 PM   #6
kcgviceprez
yeah its #6, sorry. My leak was in the exact same spot and i was also adding oil every few thousand miles. it was a very simple DIY i their is one without pics on the forums, its not a hard process just time consuming, ill go out and take some basic pics for you guys so you will have a better idea of what you're dealing with.
Old 03-01-2009, 08:57 PM   #7
TEAMAFLCON
My Ride: 2003 325i
2003 325I
I'm having the same problem. I took these pictures today.
From below, the cover showing signs of an oil leak:
After removing cover, I snapped this picture:
A close up of previous picture:
Another pic of 'oily' area, same area.
Am I missing something here?
TEAMAFLCON is offline   Reply With Quote
Old 03-01-2009, 08:59 PM   #8
shockin330i
So you're from the valley...
ERnie
:drool:
Old 03-01-2009, 09:27 PM   #9
TEAMAFLCON
My Ride: 2003 325i
Yeah. Trying to identify this leak.
Old 03-01-2009, 09:30 PM   #10
shockin330i
I just noticed we're all from Texas...
Maybe it has something to do with the roads...
ERnie
:drool:
Old 03-01-2009, 10:38 PM   #11
cnotesdip
My Ride: 330ci
i have the same oil leak in the same place i at 88k was your milage?
cnotesdip is offline   Reply With Quote
Old 03-01-2009, 10:45 PM   #12
shockin330i
around 89k
ERnie
:drool:
Old 03-01-2009, 10:48 PM   #13
trig
My Ride: 2004 BMW 325i
It's probably your Oil filter housing gasket like others said. It took me an our to change mine. Do it even if it isn't it, because it'll go out eventually. Once you've gotten the housing off you'll really be able to tell where the leak is coming from.
trig is offline   Reply With Quote
Old 03-02-2009, 10:23 AM   #14
TEAMAFLCON
My Ride: 2003 325i
I'm at 77K.
It took you an hour? Sounds easy enough. Any DIY with pics?
Old 03-02-2009, 10:30 AM   #15
trig
No DIY, but I could take another look at it and do a quick write up if there isn't one available.
Here were my before pics.
Actually, I did write this on bimmerforums, but it was after the fact. I'll try to dig up what pictures I did take, but I dropped the camera during the install and broke it.
It's much simpler. It could be done in 20 minutes. I took an hour because I cleaned the **** out of the housing and completely removed it from the car. It doesn't need to be done though.
I:
Popped hood
Remove air filter lid and air filter (snaps)
Remove bottom piece of air filter (2 bolts) (I found it easier to move this way)
Remove small snorkel (pulls out)
Remove air ram (3 reusable rivet things)
Remove fan (One T-25 Torx bit screw and one more fake rivet)
Remove 2 bolts for PS resv. and push aside to shock housing
Slacken Alt belt tensioner (T-50 torx bit)
Drop belt
Remove two bolts from alternator and remove plugs
Wiggle alt. till it comes out. (I unplugged battery and alt.)
Remove 3 bolts from PS pump, drop down and set on sway bar.
Remove 6 bolts from housing, pull perpindicular to engine case off of the pins, and pull straight up through space of empty parts you made. The belt tensioner stays on the housing.
I removed way more than I needed to, but I was very annoyed with the mess of oil, so I took it all apart to clean it up.
Old 03-02-2009, 10:32 AM   #16
SeanC
My Ride: 330i
2003 325I
Earlier cars came with a cover for the drain plug.
possible causes for the oil leak:
Oil pressure switch
Vanos
Valve cover gasket
Oil pan gasket
Head
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 03-02-2009, 10:53 AM   #17
xavi330i
My Ride: 2004 330i smg
The gasket rings should come with the mahn oil filters.
xavi330i is offline   Reply With Quote
Old 03-02-2009, 12:42 PM   #18
kyle808
My Ride: 00 328CI
Thanks alot. I'm going to buy the gasket and change it out. It doesn't sound like a hard job. I've replace water pumps, belt tensioners, thermostats, etc... before so it's probably not that difficult to get to the oil filter housing.
Can I contact you if I run into any problems?
-Homer Simpson
Old 03-02-2009, 12:53 PM   #19
kyle808
My Ride: 00 328CI
Oh yeah, I'm look at your pics of the engine splash cover and it's looks like it's leaking from the same spot.
I'm curious, the leak is mostly towards of the back of the engine, but the oil filter housing is at the front of the car. Is it running down the pipes and dripping in the back instead of just dropping right below at the front?
-Homer Simpson
Old 03-02-2009, 01:50 PM   #20
trig
Like I said in the other guys thread, oil moves all over the place when you got wind in there going 80mph. I didn't believe anyone else either, but did it because it was cheap and farely simple, and also prone to failing anyways. My engine bay, including the other side of the motor was soaked in oil/grime, and I hadn't lost more than a whole quart yet.
