Manual Transmission Fluid question - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-27-2014, 02:17 PM   #1
nschuber
My Ride: 2000 328ci
I have looked underneath my can and can see the yellow mtf lt 1 label. I figured this to be the zf 5speed and went to purchase some redline d4 atf. I accidrntially got the lower viscosity d6. My question is has anyone done this and will it work? Note d4 is impossible to find in houston.
nschuber is offline   Reply With Quote
Old 12-28-2014, 02:41 AM   #2
hitbyastick
My Ride: 2002 325i
I haven't done it, but I wouldn't use it either. Go to an O'Reilly and get some Pentosin MTF2 synthetic which should work just fine. It's basically what the dealer uses but at a reasonable cost. It's not worth it sometimes to go out of your way just to be able to use Redline.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 12-28-2014, 10:10 AM   #3
Kye7
My Ride: BMW 2003 330xi
Go to walmart and buy the gallon of valvoline maxlife atf. Stuff is amazing.
Speaking of manual transmissions.. don't those use gear oil instead of atf?
Kye7 is offline   Reply With Quote
Old 12-28-2014, 10:42 AM   #4
markusmarkus
My Ride: 2001 330Ci
I've used Redline MTL for decades and have had zero issues. You live in a warm climate and MTL is a slightly heavier lube run D4ATF. I recommend MTL.
Old 12-31-2014, 06:49 PM   #5
wallofgrath
My Ride: 2001 330Ci
You could probably mix half what you got with half Redline MTL too.
wallofgrath is offline   Reply With Quote
