Old 06-26-2009, 04:35 AM   #81
richyboycaldo
My Ride: Mx5 300zx 240z 330c
How can I tell aparte the post and pre cat sensor. I was looking at this thread and I cant tell the difference. I always thought that these were the post cat sensors.
http://forum.e46fanatics.com/showthr...=02+sensor+diy
richyboycaldo is offline   Reply With Quote
Old 06-26-2009, 04:40 AM   #82
richyboycaldo
never mind I manage to find a nice DIY that shows me were the post cat sensor are.
http://forum.e46fanatics.com/showthread.php?t=293116
Old 06-27-2009, 11:13 PM   #83
wrecklessfool
My Ride: is paid off
Just went to the site and bought one of these How long does the shipping usually take?
wrecklessfool is offline   Reply With Quote
Old 06-28-2009, 03:48 AM   #84
i0kr1sol
My Ride: 330ci
I got mine exactly seven business days.
i0kr1sol is offline   Reply With Quote
Old 06-30-2009, 09:52 PM   #85
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
So this would allow us to pass inspection since sniffers aren't required for OBD2? (NY anyway)
phamine is offline   Reply With Quote
Old 07-07-2009, 01:39 PM   #86
wrecklessfool
I have received my O2 simulator and have gone a slightly different route than what this thread suggests. I cut the wires on the O2 sensor harness itself as opposed to hacking in to the main wiring harness of the car. I also decided to relocate my O2 sensors to the "drug bin" encased in an electrical box I bought from Lowe's. I'll post pictures and an easy to follow wiring diagram. I found this thread a bit confusing and did a little more research on other forums and I'll post the info I found most useful along with pics of my setup when it is complete. Might be a few days since I'm trying to get the electrical box powdercoated so it won't look like a lump of galvanized steel in my engine bay More to come soon!
Old 07-21-2009, 09:45 PM   #87
phamine
^^pics of your setup ready?
Old 07-21-2009, 11:42 PM   #88
BillyJoelR
My Ride: Velvy B.
Pixors please & details.
| There is no replacement for Displacement | Go Big or Go Home |
BillyJoelR is offline   Reply With Quote
Old 09-10-2009, 08:30 AM   #89
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Okay, I need someone who's installed these to clear this up for me. Here's what I did.
1. Red sim wire to 12v power, check
2. Black sim wire to grey ground, check
3. This is where, I got confused. There are 2 black wires going to each O2 sensor. Do I just cut and intercept one from each sensor? Do I cut both and intercept one from each? Sorry, this wasn't clear to me. I cut and intercepted one black wire from each sensor, but I'm not sure if that'll do it.
Let me know!
Old 09-10-2009, 10:53 AM   #90
aggieE46
Keep it clean
aggieE46's Avatar
Nevermind. I'm retarded and colorblind. I installed it right.
Old 09-10-2009, 06:46 PM   #91
guest11072016
Account closed.
I'm going to be doing this soon.... @#$% defoulers... lol
guest11072016 is offline   Reply With Quote
Old 09-11-2009, 09:36 AM   #92
aggieE46
Keep it clean
aggieE46's Avatar
For those of you who have installed this... if you put it in AFTER your SES light was already on, how long did it take for it to go off? I have 110 miles on the car since I installed it yesterday. Autozone won't clear codes anymore, and I can't get to a shop to do it any time soon.
Old 09-11-2009, 10:09 AM   #93
Focal E46
My Ride: is a DIYer
I don't think it will go away. I tripped a code in between header install and cat/defouler install and it never went away until I cleared it.
Focal E46 is offline   Reply With Quote
Old 09-11-2009, 10:10 AM   #94
Focal E46
My Ride: is a DIYer
I'm guessing you aren't close to Va, are you?
Old 09-11-2009, 10:13 AM   #95
aggieE46
Keep it clean
aggieE46's Avatar
Haha, no.
I guess I'll just have to make my way out to Stett.
Old 10-02-2009, 01:42 PM   #96
richyboycaldo
Hello, my mechanic installed the 02 sim, along with some VANOS seals and other stuff. After I got my car back. my reader now shows code P0135, that says
(Oxygen sensor heater pre-cat (Bank1))
Output digital pulse width (active low)
and this is the explanation for the code:
"DME final stage will set flagwhenever a short to ground, a shortto battery voltage or a disconnection between output transistor and component exists
So is this something related tothe 02 sim, or is something completely different. maybe the wiring was done incorrect. The sim is blinking green so I that means it ok.
Old 10-02-2009, 01:50 PM   #97
aggieE46
Keep it clean
aggieE46's Avatar
Responded to your thread.
Old 10-04-2009, 01:07 PM   #98
s3th
s3th's Avatar
My Ride: 05 330Ci ZHP
pretty sick.
You can just call me seth.
500px
s3th is offline   Reply With Quote
Old 10-16-2009, 09:05 PM   #99
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
I just installed my O2sim today. Spliced into the wiring right before it went into the plug to the DME. Really simple install. I cleared the codes and no CEL after running at idle for five minutes and a drive around the block. I'm going to try and get a smog check done Monday morning. I'll let you guys know what happens.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 10-17-2009, 10:21 AM   #100
guest11072016
Account closed.
^^ Keep us posted. I'm doing mine after I the new clutch/flywheel are on.
