Old 03-07-2009, 08:03 PM   #1
iDriftYou
My Ride: is a HighWay monster
Question ATF Change.....
So, I went under my car today and read the sticker, Green sticker and it said to only use OE Fluid P/N: 83229407807, but the sticker was green? Reading this pdf http://tech.bentleypublishers.com/se...4/B305_240.pdf , it says that it should be a blue sticker?
Now I'm pretty sure I have a ZF tranny, so im not gona buy Esso fluid, which is like 20$ a liter, Im going with Valvoline Mercon V Fully Synthetic, this guy used it http://www.bimmerfest.com/forums/sho...d.php?t=166135 , and says works very well. Now one more question, I have 100,345 Miles on my car, should I drain and refill 3 times, and put in the new filter the 3rd time, or should I put in the new filter the first time and then drain and refill 2 times more? Also, anyone buy a Bavauto Zf tranny filter kit? Does it come with a new Ring for the filter? Just wondering, thanks again guys
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 03-07-2009, 08:15 PM   #2
iDriftYou
-Shehroz
Future: GT35r
My DIY:
Old 03-07-2009, 08:25 PM   #3
iDriftYou
no one? Seriously?
-Shehroz
Future: GT35r
My DIY:
Old 03-07-2009, 11:34 PM   #4
xylene
My Ride: 2003 325i
I got the GM 390R so I went with the Valvoline DexVi full synthetic. Couldn't work smoother. I did this a few weeks ago at 115K. This may not be perfect but its the way I did it... I did two simple pan drains and refills with about 50 miles in between each before I dropped the pan, cleaned it up, replaced the filter, and did the final refill.
When I did finally drop the pan, the fluid was really clean and majoity of the old stuff was out. The dex is so much cheaper than the oe stuff thats its affordable to really clean it up. Yeah, I"ve read lots of mixed reviews on straying from the esso with your ZF tranny, but if I was you...I would do it too. Go with Valv Mercron V that is.
Pleas be 100% sure with your tranny type...I was sure I had the ZF too until I got the gasket kit in and realized it didn't look anything like what I needed. I have a green tag on the side of my transmission, but it has GM stamped on it.
2003 325i - Sport+Prem Pkg
xylene is offline   Reply With Quote
Old 03-07-2009, 11:38 PM   #5
djnekkon
My Ride: MB3ci & z33 HR
why not searching by the vin#
Old 03-07-2009, 11:43 PM   #6
xylene
My Ride: 2003 325i
Yes, if you have any doubt at all on your tranny type...have you tried the VIN decode? Go here... http://www.bmw-z1.com/VIN/VINdecode-e.cgi
Old 03-08-2009, 12:07 AM   #7
iDriftYou
Ill do that now thanks!
-Shehroz
Future: GT35r
My DIY:
Old 03-08-2009, 12:09 AM   #8
iDriftYou
Here's what I got: Chassis number ND45111
Vehicle code AN37
Series E46
Model 325i ( 325i M54 )
Body type saloon
Catalog model USA
Production date 2000 / 10
Engine M54
Transmission Unknown
Steering Left
Catalyzer YES
Additional Information for Vehicle code AN37
Production FROM : 2000/06/01 TO : 2002/02/28
Engine M54
Engine Oil 6.50 Liter
Transmission Automatic
Transmission Model A5S 325Z
Transmission Oil 8.90 Liter
Rear Axle Oil 1.00 Liter
Coolant(w/o Air Conditioner) 0.00 Liter
Coolant(with Air Conditioner) 8.40 Liter
Brake fluid 1.00 Liter
Remarks :
Final drive (rear axel), Automatic transmission: lifetime oil filing
-Shehroz
Future: GT35r
My DIY:
Old 03-08-2009, 12:15 AM   #9
xylene
My Ride: 2003 325i
Yep, your a Z. Good luck with that trans svc, let us know how it works out.
Old 03-08-2009, 12:18 AM   #10
iDriftYou
For sure, hopefully everything checks out, so I kinda didn't understand your story, did u say u bought 2 filters and changed the filter twice with in 50 miles? Or did u just buy 1 filter and change the fluid once, then changed it again along with the filter? thanks again.
-Shehroz
Future: GT35r
My DIY:
Old 03-08-2009, 12:21 AM   #11
Lbert
My Ride: 325i
I have the same model and year, 325i, 2001. Attached is a picture of the same green label you described. I went with the Esso spec. In addition, the filter I got was for a ZF.
The guy you may be referring to the thread (http://www.bimmerfest.com/forums/sho...d.php?t=166135) might be me. See my updated post on the same thread (see post #127) regarding Valvoline's Mercon V. In summary, I stopped using Mercon V. An alternate to the Esso is Mobil 1 ATF. Mobil1 now states on the newly reformulated ATF bottle that it meets the Esso spec.
Name:	Transmission label.jpg
Lbert is offline   Reply With Quote
Old 03-08-2009, 12:28 AM   #12
xylene
My Ride: 2003 325i
just one filter change at the third and last fluid drain. The previous two, I just drained and refilled.
Old 03-08-2009, 12:34 AM   #13
iDriftYou
Thanks so much man, so M1 has a new atf formula? hmm, so either Castrol or M1 ATF, which to choose?
-Shehroz
Future: GT35r
My DIY:
Old 03-08-2009, 04:26 AM   #14
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
Anyone find that just a little sad?
Onto the topic, check the link under my sig -- I have the ZF and did two RedLine D4 changes so far (there was no need to do more on my car, as I was at 42K when I did the first time, 47K on the second, and I'm only at 55K now).
I would definitely change the filter the first time around. In fact, as expensive as it sounds, I would change everything the first time, put maybe 100 miles on it and do another change, then do another oil/filter change maybe 500 miles later (3rd change) -- you should be somewhere around 90% new oil by that point, and good to go.
BTW, I'm extremely happy with RedLine's D4 in both my tranny and power steering -- that's some good freakin' oil...
Sicily1918 is offline   Reply With Quote
Old 03-08-2009, 10:26 AM   #15
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
the sticker on pan is fluid, not type of tranny, that sticker is on side near rear of trans...............regardless, you cna use redline d4 no problem.............
http://forum.e46fanatics.com/showthr...n+fluid+change
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 03-08-2009, 11:17 AM   #16
kbok
My Ride: 2005 325i
+1 on this. Rather than guess which model you have or rely on VIN database, if you can see the sticker, then you can probably get to where you can see the plate on the tranny. You have to look on the side (not bottom) of the tranny, toward the rear. Use a trouble light or flashlight and look up at the side (driver's side in my case, 2005 325i, GM) in that area, should be on a stamped metal plate. Since its out of most of the road splash and grime it should be a lot easier to read.
kbok is offline   Reply With Quote
Old 03-08-2009, 02:54 PM   #17
01bim325
My Ride: Bimmer
Be careful with the VIN decode database. According to that, I've got a ZF tranny, but it's wrong. I definitely have a GM tranny. Go by what's shown on the tranny.
01bim325 is offline   Reply With Quote
Old 03-08-2009, 02:56 PM   #18
iDriftYou
So where exactly is the Stamp located? On the back of the transmission facing the rear?
-Shehroz
Future: GT35r
My DIY:
Old 03-08-2009, 03:09 PM   #19
wasp9166
Old 03-08-2009, 03:10 PM   #20
wasp9166
be careful with the vin decode database. According to that, i've got a zf tranny, but it's wrong. I definitely have a gm tranny. Go by what's shown on the tranny.
+100000000000000
atf, transmission, zf tranny
