Old 04-17-2012, 12:48 PM   #41
hockey_fan
My Ride: 2000 323i
Originally Posted by jasonbimmer View Post
yes, GM pan is smooth and has 21 bolts.
ZF is different.
Thanks for that...that eases my mind quite a bit...now to figure out what kind of fluid to use.
hockey_fan is offline   Reply With Quote
Old 04-17-2012, 03:04 PM   #42
captkhaos
My Ride: '02 330Ci
This is where you want to look (type this into your search engine): BMW SD 92-113 6/2001
Sorry but I couldn't put the link in for you.
captkhaos is offline   Reply With Quote
Old 10-26-2012, 12:42 PM   #43
Tament
My Ride: 2001 330I
I am about to do my fluid, hope all goes well
Tament is offline   Reply With Quote
Old 08-06-2013, 08:56 PM   #44
Drexellake
My Ride: 05 330ci Convertible
Looks like I'll be playing this game soon. Can't wait. Looks like the hardest part is figuring out which fluid to use.
Drexellake is offline   Reply With Quote
Old 08-06-2013, 10:30 PM   #45
blkonblk
My Ride: 06/2000 330i ZSP/ZPP
if you have a ZF tranny, this is where you should look for type of fluid.
http://www.thectsc.com/index.php?p=c...parent=56&pg=1
They sell ZF tranny fluid cheaper than dealer. I used compatible Amsoil fluid LT71141 before I found this site.
Life is a journey not a destination, so enjoy the ride!
blkonblk is offline   Reply With Quote
Old 08-07-2013, 07:17 AM   #46
Mr Podman
My Ride: E46 Coupe
When I changed ATF in my GM transmission I hunted down a source for the factory fill Texaco ETL-7045E fluid. I bought 7 x 1 liter bottles of Texamatic 7045E from Bavauto for $12.00 each. I didn't want to buy fluid from a BMW dealership because they pump it from a drum into containers and I had zero confidence that whoever did that pumping would actually select the correct fluid to begin with. Hence the aftermarket choice.
The fluid is expensive and when you ask around how much you need for a drain and refill (with the pan dropped and a new filter installed) you get some real funny answers.
I bought 7 x 1 liter bottles, I still have one of those bottles unopened. After my transmission was re-filled I still had fluid left in the 6th one liter bottle I had opened. So, I needed between 5 and 6 liters to achieve the fill.
If I ever do another transmission drain and fill (and I'm not planning to) I will probably use Dexron VI fluid instead of the Texaco 7045E factory fill. Here is a brief explanation why.
The GM transmissions used in our BMW's were also widely used in many General Motors vehicles. My A5S 360R transmission is known as the 5L40E when it is installed in a Cadillac. Same transmission. Back when GM designed our transmissions, they were validated and specified using Dexron III fluid. That old Dexron fluid recipe was the standard of the day even though the fluid itself was a fairly crude mixture with widely varying characteristics.
Also back then, BMW wanted a fluid with longer life characteristics ("Lifetime Fills") and GM simply had nothing to offer. So BMW worked with Texaco to come up with the recipe for the 7045E factory fill used in our cars.
Later, for the 2006 model year, GM developed and released their version of a modern and sophisticated long life fluid in the name of Dexron VI. GM states in writing that Dexron VI should be used as the replacement fill for all older GM transmissions that used previous Dexron versions.
Dexron VI is an excellent product, is widely available, cheap and compatible with our GM transmissions.
That's why I'd probably use it next time.
Mr Podman is offline   Reply With Quote
Old 08-07-2013, 07:24 AM   #47
jfoj
My Ride: 330CiC, M5, X5, E93
Mobil 1 Synthetic ATF is a pretty good universal fluid and is usually readily available.
Old 08-07-2013, 07:31 AM   #48
Mr Podman
My Ride: E46 Coupe
The people at Mobil say:
"The new Mobil 1 Synthetic ATF will meet the requirements of Dexron III. In the product description we recommend Mobil Dexron-VI ATF for GM vehicles manufactured in 2006 and later. For vehicles older than that, Mobil 1 Synthetic ATF is still a perfect fit."
Much of what they are communicating is based on legalities protecting GM's marketing of Dexron VI. You might want to compare the two fluid specs particularly as it relates to long term shear characteristics. It might be on par with Dex VI, it might be on par with Dex III.
Old 08-07-2013, 08:49 AM   #49
Hogan773
My Ride: 2002 325xi
Podman at what mileage did you do the change, and did you drop the pan or just change the fluid?
If I do this I'm definitely just gonna go Dex6 - it's available everywhere
Hogan773 is offline   Reply With Quote
Old 08-07-2013, 08:52 AM   #50
Knight
My Ride: '05 330Ci | '01 325i
Redline D4 ATF meets the specs and is a proven fluid. $11/quart on Amazon, shipped.
Knight is offline   Reply With Quote
Old 08-07-2013, 09:04 AM   #51
Hogan773
My Ride: 2002 325xi
Dex 6 can be had for like $5 or $6 a quart though.
Old 08-07-2013, 09:19 AM   #52
Mr Podman
My Ride: E46 Coupe
Redline D4 is essentially an old Dexron III formulation and it has a cult following on BMW message boards.
Dexron VI is a far superior fluid from the perspective of longevity.
Old 08-07-2013, 02:13 PM   #53
Knight
Redline D6 is $11.50/quart on Amazon. I'm sure another brand is cheaper, but to me it's worth paying a bit extra for a reputable product with many success stories posted.
I considered D6, but from what I gathered, D4 will mix more easily with the old fluid. And since there is no drain plug on the torque converter, there will be some mixing, even with an extra flush.
I'm going to stick to 50K mile intervals for the ATF change from here on out to be on the safe side.
Old 08-07-2013, 04:04 PM   #54
Sweetness
My Ride: '01 325i
Anyone who needs confirmation on this sensitive topic, check my sig below. Backed by professional results.
Maybe if you guys fuucking searched before digging up ancient threads.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 08-07-2013, 04:58 PM   #55
Mr Podman
My Ride: E46 Coupe
I did it including dropping the pan and changing the filter at approx 65,000 miles.
Lot's of crud on the magnet at the bottom of the pan and the fluid was discolored. It needed a change.
I bought the Meistersatz brand service kit at Pelican Parts for the transmission filter, gasket and 20 housing bolts and was very happy with the quality of their product.
I used a simple angled torx wrench to access the drain bolt with a length of pipe on it for added leverage. Be sure to loosen the fill bolt first so you know you can fill later. If I recall correctly, it is a different size than the drain bolt.
In terms of shift quality after the change, I didn't feel any difference. More of just a maintenance thing.
Old 08-07-2013, 05:24 PM   #56
Hogan773
My Ride: 2002 325xi
Yes my understanding is T45 on the fill and T40 on the drain but I might have that reversed
For the fill bolt you got in there with an angled torx wrench?
Any tricks to putting the pan back up, or did you just lie under it and hold it up with one hand while hand threading a bolt or two with the other?
Did you leave the car running for the final fill or did you just fill, turn on the car, shift a few times, then turn off and do the final fill till it dribbled out?
Old 08-07-2013, 05:27 PM   #57
blkonblk
That's exactly the same company - California Transmission Supply Co. - on my previous post. I found out about them after I had replaced my ATF.
Old 08-07-2013, 05:40 PM   #58
Mr Podman
My Ride: E46 Coupe
My cryptic note say torx 45 for both drain and fill but in the back of my mind they were different (like torx 40 perhaps).
I bought a set of cheap torx keys that look like the one pictured below from Amazon.com and used a length of pre-cut and threaded black pipe (about 18") from Home Depot for added leverage.
I followed the fill and check level procedures in the Bentley manual without exception.
The particular filter kit I chose had a well formed gasket that stayed in place with just a few of the 20 screws in place. Some brands have floppy gaskets that would be a nightmare.
Old 08-07-2013, 05:47 PM   #59
Mr Podman
My Ride: E46 Coupe
You also need a light duty torque wrend for the 20 pan screws. The torque spec is something like 8 ft lbs (check me on that) and I remember thinking that if I was tightening them without a torque wrench I would have felt the need to crank them quite a bit more.
Old 08-07-2013, 07:17 PM   #60
Drexellake
That's how I found this thread. Doh!
atf, transmission, zf tranny
