Old 03-08-2009, 09:39 AM   #1
reez777
My Ride: 325i SPORT AUTO '04
Help Identifying E46 FCAB's
On RealOem Parts, it lists the following for Front Control Arm Busings on the E46:
SET OF BRACKETS WITH RUBBER MOUNTING D=66MM
02/2001 31126757623 ENDED
02/2001 31126777850 ENDED
02/2001 31126783376
The first two have 'ENDED' in the notes section, meaning that the latest ones are '31126783376. All are 66mm so I bascailly want to know the difference between them and if its ok to mix and match.
I have purchased the O/S bushing which I know is the latest one as it came in the box with the part number. On the actual bushing carrier it doesn't have a part number but shows: BMW 6756068 L XXI
I bought another bushing, also O/S, which shows on the part, BMW 6756068 L XVI.
How do you identify which part numbers correspond to which bushings from this information?
reez777 is offline   Reply With Quote
Old 03-10-2009, 06:01 PM   #2
reez777
nobody has any clue?!
Old 03-14-2009, 05:53 AM   #3
reez777
does anyone know the answer to this without assuming or being 'pretty sure'
Old 03-14-2009, 08:10 AM   #4
Whammy
My Ride: ZHP
02/2001 31126783376
Do this: Call/email Ruben@desertmotorworks, give him your VIN and he will get you the correct parts you need. I highly suggest getting the Meyle HD Arms & Bushings for the wrong. Better quality than OEM plus serviceable balljoints. I just ordered and installed my FCA/B and RTABs. Ruben has great prices.
Edit: Just saw that you are in London and not in the US. This is the right part # if you go with OEM: 31 12 6 783 376
I though again suggest getting Meyle HD over OEM. Not sure who in Europe has this.
Whammy is offline   Reply With Quote
