Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 5.00 average. Display Modes
Old 03-09-2009, 12:46 AM   #1
lowrider
My Ride: modified 323Ci
Send a message via AIM to lowrider
Thumbs Up AVIC-F90BT||Double Din Install~Lots of Pics
First off I would like to say that at this point in time this retrofit is in no way "Plug and Play" or "Simple" even with the aid or retrofit kits and wiring harnesses.
This install is not for those who are afraid of cutting into their BMWs, dealing with lots of wires, or doing a lot of customizing to get everything to fit right.
That being said, let's move on to what everyone wants to see. As I go through the pics I will try to make it as "DIY" as I can. I will definitely point out what's important and/or tips and trick I found out along the way.
Parts Cost: < $1000
Labor: 23 Hrs
Components:
Avic-F90BT
GEX-P10HD
HVAC Relocation, Antenna Adaptor, R17 Wiring Harness, HD Radio Box
PAC SWI-PS
Janus Kit w/ Bezel
Now to the install:
Removed Trim
Removed Radio
Removed Center Vents (Damn they were in there tight!)
AC Controls pop right out
Taking out shift boot and removing trim
Removed remainder of center console and Air Box cover
Shot of condenser and servo arm
Footwell duct hole
Valve that needs to be modified
After hours of cutting and test fitting, because I had no template
Modified Servo Arm (Cut ~3.5 cm from tip)
Test fitting servo arm
Modified the Valve
Smaller half has to be glued in
Videos of valve and arm functioning correctly
And finally the box fits (Just to this point took about 8 hrs)
Applied insulating foam to reseal the majority of the air box (Note: you have to cut a new hole for the AC Temp sensor as you will have to cut the old hole out)
Box installed (Top screws have to be done with a small 90 degree drill)
Temp sensor install and starting to aluminum tape the holes
Ended aluminum taping the whole box
Test fitting carrier, it sort of fit. Major interference with bezel
Had to remove the material protruding out the front
Had to shave the back of the bezel to get it to fit right
Photobucket
Picture courtesy of EAS
lowrider is offline   Reply With Quote
Old 03-09-2009, 12:48 AM   #2
lowrider
Next came the bezel, which had MAJOR fitment issues in width. So 4hrs of filing and wet sanding with 400 grit followed by 2000 grit got it looking almost like it never even had to be f@&!ed with lol
(This is not the fault of EuroSpec, they cannot guarantee fitment of every single head unit out there)
A MESS
Me setting the new head unit into the carrier
And after about 13 hrs or work, it fits
Soldered all the wires
Shrink Wrapping each one (this is a b!tchin tool)
The wiring harness (Big shrink tubing covers all the wires)
Pictures like this used to scare me, anyways wiring harnesses in
Tapping into VSS (Also tapped in Reverse and Steering wheel control all from sub-connection box on top of fuse box)
Things to note
  • VSS (Speed Sensor): Black and White
  • Reverse Sensor: Blue and Yellow
  • Steering Wheel Control: Red and White w/ Yellow dots
  • All wires in the car are unique and mean the same thing no matter their location in the car
  • By previous statement, the VSS and steering wheel control can be tapped into very easily by wiring looms located near the AC/Radio (I discovered this after the fact)
  • Only the Reverse absolutely need to be tapped into through the glove box
Dad helping me remove A-pillars so we can run microphone wire and NAV antenna wire
Gauge Cluster had to come out to run wires
Long story short, HD Radio box and SWI-PS run and located behind glove box in empty space
This is a great chasis ground location for the head unit and other things (ie. parking brake sensor from head unit
Almost done
Radio and AC installed
ALL DONE!!!
Microphone
Nav Antenna
Overall I am very happy with the install. I'm having a lot of fun playing around with the features and the ipod integration is so many times better than my old cassette tape and wire method!
I would like to thank EAS and Eurospec. I would also like to thank Tom and EAS, for their help and support through this as well as awesome customer service. I definitely recommend doing business with both of them!
Photobucket
Old 03-09-2009, 01:00 AM   #3
M3_GTR
My Ride: hates driveways
sick DIY.
I bought a sub and am scared to pull it apart and just put it in, this helped me abit
I might just give it a try
FOR SALE!
M3_GTR is offline   Reply With Quote
Old 03-09-2009, 01:18 AM   #4
azndrunk74
My Ride: LSB vert
Good job! I just finished mine this weekend as well (avic f700bt). I used the same install kit which I bought off ebay, they sent me a .pdf for the template. The whole install took me about 14 hours, I never want to do it again. The PAC-SWI doesn't work that well for me, it seems to lag quite a bit.
LSB|Cinnamon
azndrunk74 is offline   Reply With Quote
Old 03-09-2009, 01:18 AM   #5
towlie
My Ride: 02 ///M3
that is basically the ugliest thing I have ever seen in my life, go to hell.
j/k, amazingly done! Attention to detail is everything.
towlie is offline   Reply With Quote
Old 03-09-2009, 02:22 AM   #6
JGallardo
My Ride: E46 M3
Good job! Mine was done 2 weeks ago (avicf900bt) and i love it. The pac adapter works good for, it just has a little lag every once in a while only when using my ipod and trying to skip/rewind a song, but always works great for volume control. Oh by the way, the mic for the bluetooth on mine got installed on an empty littel vent that it's located on the headliner, right next to the sunroof switch if you what i mean, or i might just post pics later this week when i get my car back from the body shop. Great job again!
JGallardo is offline   Reply With Quote
Old 03-09-2009, 02:43 AM   #7
Skyisthinkn
My Ride: Bmw
good job
Skyisthinkn is offline   Reply With Quote
Old 03-09-2009, 05:23 PM   #8
lowrider
Photobucket
Old 03-09-2009, 06:48 PM   #9
xe460
My Ride: 02 325i auto
Very nice!
I still haven't gotten a chance to put mine in yet.
Are the wires all color coded the same between the Pioneer F90BT and the aftermarket harness? Did you have to install the parking brake switch too?
xe460 is offline   Reply With Quote
Old 03-09-2009, 06:51 PM   #10
beemteam1001
My Ride: E46 323i
wow way too much work... but looks good
e46 323i K&N CAI, AA Cat Back, Crank Pully, stage II chip, eBay headers[/SIZE]
beemteam1001 is offline   Reply With Quote
Old 03-09-2009, 08:31 PM   #11
dmm698
My Ride: 2002 325ci
when i did mine i also used the kit from euro spc and had no template. i like you jsut cut cut and re cut. i was really nervous i was going to cut it to big one time on accident and be F'd. Overall i love the f900. im getting pissed at it right nwo because i cant get the stupid clock to turn ahead an hour and save that time. Anyways, install looks great man.
dmm698 is offline   Reply With Quote
Old 03-09-2009, 10:58 PM   #12
lowrider
Thanks, and I know about the time, HOW ANNOYING!!! I'm gonna get around to reading the manual soon enough.
Photobucket
Old 03-09-2009, 11:30 PM   #13
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
<3 the detail!
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 03-10-2009, 04:36 AM   #14
-Jay-
My Ride: 06 X3 3.0i
Send a message via AIM to -Jay-
good job with the install.
i hope to be installing my double din soon.
-Jay- is offline   Reply With Quote
Old 03-10-2009, 08:10 AM   #15
dpgrand
My Ride: 2005 330xi
What are you overall thoughts on the Janus kit? Is it worth the $$?
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 03-10-2009, 12:14 PM   #16
lowrider
It is definitely worth the money, even with the modification/customizations that have to be done. It still saves a lot of time, and let's face it, this is still a custom install.
Photobucket
Old 03-16-2009, 12:00 AM   #17
Blacksage
My Ride: E46 M3
good write up! I dont really understand how to tap into the wires behind the glovebox though. I am still deciding between pioneers 700 and 900 unit. Seems like the 900 can play DVDs...
Blacksage is offline   Reply With Quote
Old 03-18-2009, 09:01 PM   #18
kcalhoun27
My Ride: under conctruction
does this unit work with the factory amp? all you did was install the HU and you had full sound?
TIA
-kevin
Originally Posted by theribdoctor View Post
chili is awesome, I bleed aqua and orange.
kcalhoun27 is offline   Reply With Quote
Old 03-18-2009, 09:11 PM   #19
lowrider
TIA
Yea, as long as the blue and blue/white wire are connected, you're good to go.
Photobucket
Old 03-18-2009, 09:23 PM   #20
kcalhoun27
i assume those are the amp power signal wires. thanks, and great job!
-kevin
