Where is the heatvalve located? Its cold in my car =/ - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-11-2009, 02:43 AM   #1
scalare
My Ride: 328ci
Hello there. I am trying to figure out why my car dosent have any heat.
The engine is @ normal temperature and so on.
Where can i find the heatvalve? I want to se if its opens as it should.
And maybe try the flush the system after that. Maybe its clogged.
I have a 328ci -00.
scalare is offline   Reply With Quote
Old 03-11-2009, 03:17 AM   #2
paraklas
My Ride: ESS TS2 320ci
http://forum.e46fanatics.com/showthr...y+heater+valve
Old 03-14-2009, 12:31 PM   #3
scalare
My Ride: 328ci
Hello everyone!
Now i located the heatvalve. It works fine. Still got no heat doh..! =/ The hoses from the heatvalve is pretty cold, but if i squeese them alittle bit they will start to warm up. Then i get the fan going and i have a warm car for around 5-10mins. Then it starts cooling again, and i can repeat the squees solution. But i cant do that every time
I have been bleeading the system today, and i dont se any diffrence. Any tips?!
Old 03-14-2009, 01:19 PM   #4
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
still sounds like u have air in the system
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 03-14-2009, 03:20 PM   #5
magnuzza
My Ride: Black 323i
Check your thermostat.
magnuzza is offline   Reply With Quote
Old 03-14-2009, 04:08 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Fsu?
Old 03-14-2009, 04:13 PM   #7
scalare
My Ride: 328ci
Yes it might be possible. Any tips on how to bleed?
The car is @ normal temp, and seems to be no problem, still the thermostat?!
Originally Posted by Solidjake View Post
Fsu?
Fsu?
Old 03-14-2009, 05:14 PM   #8
330ciandr6
My Ride: .
Fsu?
seminoles?
he means fsr. but the fsr would cause the blower not to come on...and he hasn't said anything about the blower
Old 03-14-2009, 05:18 PM   #9
330ciandr6
My Ride: .
open bleeder and expansion tank cap and start the car...and keep filling it until it stops sucking it down and air bubbles stop coming out. then usually just to make sure its bled i'll drive the car til it warms up and let it run for a bit (with cap and bleeder closed). then let it completely cool down. once it cools down *most* of the air should make its way up to the top and you can just top it off from there. but i have a air bleeder at work that does all this for me
