looking to buy wheels and need help/advice. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 03-12-2009, 01:20 AM   #1
CroVlado
My Ride: 2004 MB BMW M3
Question looking to buy wheels and need help/advice.
ok ive decided im buying the umznita uforged u20 wheels. since they let u create the wheel however u want. i was gonna do a 19x8.5 front and 19x10 rear.
now i talked to them and everything but i wanted your advice also. i want the car to have no rubbing. they are going on a M3.
front wheel questions:
would 245s fit on the front rims and avoid rubbing?
what spacers are needed or recommended?
should i go ahead and bump the rim up to a 19x9?
rear wheel questions:
275-285 should fit fine right?
spacer size?
if i keep the front 19x8.5 should i lower this to 9.5 instead of 10?
both:
im looking to run the wheels running flush or near flush with the bulge of the fenders. what setup do ur recommend from above info?
is it too big of a difference in width of the tires (245f - 275-285r)
other:
have u seen any cars with these wheels, i searched google for uforged u20 but found umznitas pictures only? cant ask for a photoshop either due to the angle of these wheels... wouldnt look right. unless u know how to make it look right lol.
i cant think of anymore questions.. and sorry to make it so long but thank you for all of your help and advice. u ppl are great!
here's a link to the wheels.
http://www.umnitza.com/product_info....oducts_id=1313
CroVlado is online now   Reply With Quote
Old 03-12-2009, 10:38 AM   #2
DOCTOR 3VIL
My Ride: e46 m3
20 is too big. I am actually moving down from my 19 ZCP wheels to 18'' lightweight Enkei wheels, but those wheels have a nice design to them.
You may have some rubbing issue in the rear if you go with 285 and those wheels, but most likely you'll be OK.
I have 285's on my 19 ZCP wheels in the rear with 5mm spacers and the rear right would rub on bumps, so I took it out.
Anyway, good luck. Post pics once you get new wheels.
V-CSL Roof/Evosport headers/Evolve Tune/3.91/Moton CS/Evolve/Autopower Roll bar/Sparco Evo 2/Brembo
DOCTOR 3VIL is offline   Reply With Quote
Old 03-12-2009, 11:14 AM   #3
marioalex24
My Ride: 2002 M3
I think that 19" wheels would be max on the m3. 20s are to big and i think you would loose the performance..
1. 2006 Lotus Exige (sold)
2. 2008 Mini Cooper S (currently own)
3. 2011 E92 M3 (sold)
4. 2002 E46 M3 (sold)
marioalex24 is offline   Reply With Quote
Old 03-12-2009, 01:09 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You can do 20's on an M3 but it requires some custom fitting and fender modification. I think 20s are oversized for this car and it looks odd, stick with 19s.
19x8.5 and 19x10 would be perfect provided you get the correct offsets. Go with a 245/35/19 and 275/30/19 front and rear tire to avoid rubbing as well.
Old 03-12-2009, 03:17 PM   #5
p0kerface
My Ride: 02 CB 6MT M3
if you're getting the wheel made the way you want, get the correct offset instead of using spacers
p0kerface is offline   Reply With Quote
Old 03-12-2009, 05:25 PM   #6
CroVlado
i have no idea where u guys get the idea that these will be 20's???? the wheel is called u20. the wheel itself im getting are 19" .... idk where confusion came in, i stated 19x8.5 and 19x10.
i think the name of the rim could confuse.. but yea guys it will be a 19" wheel. sorry for any confusion.
Old 03-12-2009, 05:26 PM   #7
CroVlado
what would be the correct offset?? umznita makes these wheels to the size u want. so if i dont have to use spacers id love to just get the wheels PERFECT size.
Old 03-13-2009, 12:19 PM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
For offsets, we typically have the wheel manufacturer determine this based on the car model, brakes and sizing. This is why we work exclusively with professional wheel designers for all of our forged wheels (HRE, DPE, 360Forged, Vorsteiner, Vellano, VIP Modular etc...) as they are well versed in the correct specs for these vehicles to make sure they sit flush with the fender and avoid rubbing issues.
u20, wheel fitment, wheels, wheels setup
