Old 03-14-2009, 04:59 PM   #1
mmedvesky
My Ride: 2007 328i
Stripped Tensioner bolt
I am in the middle of an agonizing cooling system rebuild on my '00 323i (manual tranny) and as I was trying to remove the belt, the Torx Head bolt on the tensioner just rounded and now I can not get the belt off. I am kind of at a loss here. Not sure What I should do to proceed. I was planning on replacing the tensioner as well (i think i have the hydraulic tensioner and bavauto sent me the mechanical) so not the end of the world, I just now need to get the belt and tensioner off.
Any suggetions or ideas? Can I cut the belt, or is this a dynamic built up energy disaster waiting to take out my eye? Can I drill out the torx head? Thoughts?
Thanks in advance,
Matt
2000 323i
mmedvesky is offline   Reply With Quote
Old 03-14-2009, 05:10 PM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
you aren't supposed to use the torx bolt to loosen the tensioner...there is a 16mm "bolt" built into the tensioner that you are supposed to use to loosen the tension
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 03-14-2009, 05:11 PM   #3
iDriftYou
My Ride: is a HighWay monster
+1, that torx bolt is a b!tch to release the tension with, socket FTW!
-Shehroz
Current: 1990 Toyota Supra
Mods: CP pistons/ Eagle rods/ HKS MHG/ 264 Cams/ Rebuilt CT26
Future: GT35r
My DIY:
DIY ZF 5HP19 Transmission Drain/ Refill : http://forum.e46fanatics.com/showthr...12#post9551712
"My life doesn't only move in a straight line, why should my car?"
iDriftYou is offline   Reply With Quote
Old 03-14-2009, 07:08 PM   #4
dragoncoach
My Ride: '03 325it/Jetta TDI
dragoncoach is offline   Reply With Quote
Old 03-15-2009, 11:58 AM   #5
Laxplayermjd
My Ride: 03 325i
Send a message via AIM to Laxplayermjd Send a message via Yahoo to Laxplayermjd
Can you see the bolt good? Mechanical tensioners had the spot for 16mm socket. If its hydraulic i have seen either a t50 bolt or like and 8mm hex. You can always pull really hard on the belt
Laxplayermjd is offline   Reply With Quote
Old 03-16-2009, 04:29 PM   #6
mmedvesky
My Ride: 2007 328i
I got the belt off by removing the idler pulley. Turns out not too much stored kinetic energy on the belt. And it turns out the DIY I used called for T50, however it was actually an 8mm hex. That is why it 'rounded'. The 8mm hex still works fine.
I do not, however, have the 16mm nut that I've seen some of you refer to. I've seen it in a picture somebody else posted, but my car does not have it. Is it maybe only on the 330i?
Matt
2000 323i
