Thread Tools Search this Thread Rating: Thread Rating: 73 votes, 5.00 average. Display Modes
Old 11-27-2012, 07:19 PM   #281
raymoon
My Ride: Alpinweiß III
Hooray I paid a mechanic $300+ to do this ...
raymoon is offline   Reply With Quote
Old 11-27-2012, 07:46 PM   #282
schroeder6th
My Ride: 2004 330ci
Hooray, With The Help of This Site I didn't. Cost me 60 minutes and $2.00 in parts
schroeder6th is offline   Reply With Quote
Old 01-21-2013, 10:57 AM   #283
jcns
My Ride: California
I did mine yesterday.
For those who may be intimidated by this job, the following youtube clip walks you step by step. It took me under 3 hours. If I had to do again, I think I can do it in less than 2 hours.
Watching the video, being deliberate, cleaning the oily mess.
During my research, some recommended skipping raising the car/driving up on ramps. I recommend this step so that you can remove the splash guard and clean everything under the car specially because there will be oil everywhere. It's also much easier to get to one of the bolts.
jcns is offline   Reply With Quote
Old 02-04-2013, 06:38 PM   #284
YOnpds
My Ride: E46
Thanks for the video jcns!
YOnpds is offline   Reply With Quote
Old 04-12-2013, 01:00 PM   #285
comova
My Ride: Silver 325Cic
I just finished re-assembly (decided to also redo my oil separator) when I turn the key I'm only getting a click, click, click sound and no turn over. Anyone have this problem?
"The problem with the designated driver program, it's not a desirable job, but if you ever get sucked into doing it, have fun with it. At the end of the night, drop them off at the wrong house." -Jeff Foxworthy
comova is offline   Reply With Quote
Old 04-12-2013, 07:41 PM   #286
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
I'll bet you forgot to connect something to your alternator.
What I've learned so far:
  • don't start working on the car unless you have a ride to the parts shop.
  • whatever you're doing, Mango's guide is probably right.
  • the Bentley manual skips steps. LOTS of them. Don't tear your hair out when the next step makes no sense.
NCLee is offline   Reply With Quote
Old 04-12-2013, 08:23 PM   #287
comova
Mango suggested checking battery, so I walked it down to the local shop and had it charged. Started up no problem. Note to self... always disconnect battery.
Old 04-13-2013, 01:53 AM   #288
Chilton88
My Ride: 325ci, 325xi
Working under the hood
Although it seems that the OFHG replacement does not seem to be an electrically associated project, it is still SAFER for you and your vehicle to disconnect the battery. You could literally sustain 2nd to 3rd degree burns, or a heart attack at worst from inadvertently touching a live wire connected to the alternator and then not only do you have an out of commission vehicle, but also a huge hospital bill if you survived the shock without permanent injury.
I suppose that's why there are disclaimers in these DIYs but also I always take note of the warnings associated with personal injury. It's up to you though, I'm just trying to look out for a fellow Fanatic...
Chilton88 is offline   Reply With Quote
Old 04-13-2013, 03:02 PM   #289
comova
Lesson learned. I did (blue) tape the alternator wire when I disconnected it. But I will definitely disconnect battery next time.
Old 05-01-2013, 10:14 AM   #290
bruski
My Ride: 06 325Cic
protect those radiator fins
Unless the rad is going to pulled when doing any repairs that require removal of fan shroud & fan to work on the front of the engine, protect the rad fins by placing stiff cardboard next to the rad to cover entire area. Then tape along to the top of rad support for holding out of the way. Long bolts & ratchet handles will make a mess of those fins if left unprotected. You can't be careful enough not to flatten them. Remember the air must be able to pass thru the rad for cooling to take place.
bruski is offline   Reply With Quote
Old 05-14-2013, 10:56 AM   #291
campbellmn
My Ride: 325i
Thank you all so much for this thread! If not for you folks, I would not have been able to replace my Oil Filter Housing Gasket. I have a few things I'd like to contribute as a way of thanking you and to help folks just starting this project.
1. Belt Tensioners I: Note that they are different depending on when your car was made AND it's possible a previous owner upgraded from a mechanical to hydraulic so you really need to look and compare with pictures on parts supplier's websites before buying replacements.
2. Belt Tensioners II: The mechanical tensioners have a 5/8 in nub built in to release tension -put your big socket on this - it is much easier and less likely to damage things...
3. Belt Tensioners III: Can wear out so I recommend replacing each 100K or so - when the belt is off, spin the pulleys... if they make any sound it's time.
4. Not trying to suggest replacing everything, but if you've got a lot of miles on your car and: Since you've got the Oil Filter Housing out - you may want to replace the CCV and its 4 associated hoses (kits available many places for about $70) this is a VERY hard to reach part...
5. When replacing fan/housing on Automatic Transmission models: It's a bit hard to line up the fan to the large screw on the water pump, while also fitting the shroud in its position. You have to insert fan and shroud together - my advice is to focus on the position of the shroud first. I was able to place both parts behind the radiator and then I got under the car and guided the shroud into its retaining clips. Then getting the fan into position was easy. I used the wrench on the fan bolt but not very hard because the fan spins itself tight just by use.
campbellmn is offline   Reply With Quote
Old 05-26-2013, 09:27 AM   #292
brunorcng
My Ride: 2004 ZHP
Oil Filter Housing Leak
I highly recommend a good cleaning first with orange blast or simple green BEFORE you start the work. Less chance of nasty stuff getting into your engine and best chance of a good seal for the new gasket. Imagine if you had to do it over !!!
brunorcng is offline   Reply With Quote
Old 07-03-2013, 09:55 AM   #293
EDWAGON
My Ride: 2004 325xiT
Subscribed, I need to do this , car at dealer now for 4 wheel alignment, quoted me 416 to do oil filter housing gasket . Will DIY. love this site.
EDWAGON is offline   Reply With Quote
Old 07-03-2013, 10:24 AM   #294
tcphoto
My Ride: E92 335 MT Coupe
A lot of great information on this thread. I plan on doing this project next week. After pulling the alternator, I plan on using Gunk degreaser then Simple Green to clean up the mess and then the gasket. I hope to finish with a good cleaning of the other side after doing my VCG a couple weeks ago. Then it's on to esthetics like the windshield cowl and headlight lenses.
tcphoto is offline   Reply With Quote
Old 07-03-2013, 11:25 AM   #295
comova
Don't mess around too much with your alternator, I tried blowing compressed air in and wiping it down... I just had it fail and take out the battery with it.
Old 07-04-2013, 11:43 AM   #296
NCLee
My Ride: 2004 330xi
Good luck, guys. EDWAGON, since you have an xi, I'd recommend you read my post on this job: http://forum.e46fanatics.com/showpos...&postcount=276
Old 07-04-2013, 12:31 PM   #297
EDWAGON
Thanks!
Old 08-02-2013, 05:23 AM   #298
ti317
My Ride: 02 330ci coupe 5 spd
Originally Posted by Rotha View Post
i was thinking about doing this when i was doing a maintenance overhaul. but i know how much of a ***** it is to put the alternator back in so i was like YEAH FORGET THAT.
This thread is so big, it may have been addressed and I missed it but just install the top bolt and idler pulley first. Hand tighten and the alternator swings into its lower mounts. Install lower bolt and tighten both.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 08-02-2013, 05:32 AM   #299
ti317
Double post, deleted
Old 08-03-2013, 07:35 AM   #300
ti317
Update! That was blind luck! Had to pull the alternator out, I noticed a small hole in the cooling duct where a belt shred had hit it and decided to patch it.
This time,it would not "fall" into place.
I took it out and did the bolt trick, screwed in the lower bolt and tapped it rearwards to shift the threaded bushing in the alternator itself.
I took a picture and may post later if needed.
