Thread Tools Search this Thread Rating: Thread Rating: 73 votes, 5.00 average. Display Modes
Old 09-02-2013, 09:46 PM   #301
EDWAGON
My Ride: 2004 325xiT
Originally Posted by NCLee View Post
Good luck, guys. EDWAGON, since you have an xi, I'd recommend you read my post on this job: http://forum.e46fanatics.com/showpos...&postcount=276
I did OFHG today able to leave ps pump connected and just pulled apart housing from engine block with plenty of room to change gasket. I found that gasket was very hard but don't think this is the source of my oil leak like stealership said. Used the you tube video as a guide.
EDWAGON is offline   Reply With Quote
Old 09-02-2013, 10:12 PM   #302
Sansho
My Ride: 2001 325i
When I had an oil leak, I thought it was the OFHG, which I replaced, however, in my case it turned out the oil pan gasket was leaking. Just for reference, dealer wanted just shy of $1,000 to replace the $30 gasket. I did it myself.
Sansho is offline   Reply With Quote
Old 09-04-2013, 06:13 PM   #303
mach.schnell
My Ride: 08/2000 330Cic x2
Not meaning to hijack the thread, but oil pan gasket repair in the manual says to suspend the engine using special tools. What DIY did you use for the oil pan gasket? (You may PM me if need be.) Or just post the DIY link perhaps?
Impressed,
Mach
mach.schnell is offline   Reply With Quote
Old 09-04-2013, 06:39 PM   #304
Sansho
My Ride: 2001 325i
There is a DIY here, and I posted observations on the job here. Most use a Harbor Freight engine support bar to hold the engine while dropping the lower suspension.
Old 09-04-2013, 09:33 PM   #305
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
Oil Filter Housing Gasket DIY
Yep.... But it is a horrible DIY for a cheap gasket... Sucks
Talking about the ofhg FYI
cd330 is offline   Reply With Quote
Old 09-10-2013, 11:18 AM   #306
mach.schnell
Thank you.
(still impressed)
Mach
BTW, ofhg was rather easy when I did it, in comparison to what the oil pan gasket seems to be.
Old 09-10-2013, 06:45 PM   #307
Sansho
My Ride: 2001 325i
OFHG is a snap compared to oil pan gasket.
Old 08-01-2014, 10:09 PM   #308
Je357
My Ride: 325xi
Originally Posted by mhallerbach View Post
The list of items to replace along with this DIY just gets longer and longer. . .
Yes it does
Je357 is offline   Reply With Quote
Old 08-09-2014, 03:28 PM   #309
Rickna
My Ride: '01 330xi - '09 IS-F
That's how I know I'm driving my Bimmer...
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 04-09-2015, 04:58 PM   #310
NoGuru
My Ride: 2002 330ci
Have to do this job this weekend.
NoGuru is offline   Reply With Quote
Old 04-09-2015, 05:29 PM   #311
schroeder6th
My Ride: 2002 330ci
NoGuru:
piece O Cake
Just follow the / this tread..
Have Fun
schroeder6th is offline   Reply With Quote
Old 04-09-2015, 07:40 PM   #312
NoGuru
My Ride: 2002 330ci
Originally Posted by schroeder6th View Post
NoGuru:
piece O Cake
Have Fun
Thanks! I am sure I can do it, just the time is tough.
Old 01-28-2016, 06:19 PM   #313
PabloCruise
My Ride: 2002 325i
Originally Posted by easyIsle View Post
just a tip ... PS fluid and motor oil will look, smell, and feel very different from each other.
Take a white paper towel and dab the liquid thats leaking on your engine.
Take another two paper towls and get some PS fluid from the reservoir on one, and motor oil from the dipstick on the other.
Compare and contrast ... it will tell you what kind of leak you have. While your in tehre, check your fluid levels. Which one is dropping more then it should?
Great points. I cannot tell if I have PS leak, or OFHG leak...
PabloCruise is offline   Reply With Quote
Old 01-29-2016, 10:05 PM   #314
easyIsle
My Ride: 02 330i
For my car, the oring for the ps tank top is Part #: 32-41-1-128-333-M103
$3.00
I havent ordered it yet, but I imagine it is the part thats failing because the leak on mine is so far up.
if your tank is wet further down its something else obviously.
I remember doing my OFHG on my car. It was a lengthy job but not impossible for a DIY in a warm place.
Plan to tackle both of these jobs at some point, if you are capable, and you will nip the problem
The valve cover gasket is also a common leak. This one leaks onto the exhaust and smells like burning. I did mine at 77k and its needed again at 152k.
easyIsle is offline   Reply With Quote
Old 01-31-2016, 11:28 AM   #315
PabloCruise
My Ride: 2002 325i
$3.00
Thank you! On mine, the steering rack is wet. At first I thought it was hoses, but I think it could be oil dripping down from the OFHG. I will fix the VCG and OFHG and see if any leaks remain!
Old 02-02-2016, 12:19 AM   #316
jason330cic
My Ride: 2001 330cic
I just replaced my OFH gasket; it was not fun. After driving the car I still saw a little oil on the engine. I hope it was just some oil that spilled out when I was working on it that wasn't wiped up. Wasn't sure about the torque amount for the 6 bolts, I did them at 20 ft lbs.
Jason330cic
jason330cic is offline   Reply With Quote
Old 02-04-2016, 07:23 PM   #317
lkstaack
My Ride: 04 330iZHP, 05 325iT
I recently replaced my OFH and gasket, oil pan gasket, and all of my power steering hoses. It's nice and clean down there now.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
