Thread Tools Search this Thread Rating: Thread Rating: 73 votes, 5.00 average. Display Modes
Old 09-15-2009, 08:07 PM   #41
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
TIP:
hey here is a tip for anyone who has a lot of trouble with installing back on the alternator cause it's so tight, when you first take it out using a prybar, watch out the for expansion tank coolant lines, and then spray PB blaster on the bottom end nut. when time to reinstall it. thread the bolt into the nut (while off the car) and hit it a few times with a hammer until you have easy putting it back in. it should really help a lot. and dont forget to tighten it really well so that the nut can slide back into place.
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW service at the dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro dealership.
Eurobahn BMW is offline   Reply With Quote
Old 09-16-2009, 12:30 PM   #42
X-vert
My Ride: 01 330i & 04 Tahoe
I don't suppose this leak would cause the same symptoms as a VCG leak? Got that smoking smell from time to time and seems to be coming from the back of the block.
X-vert is offline   Reply With Quote
Old 09-16-2009, 12:39 PM   #43
ssm1991
My Ride: 2004 325i
If you smell smoke then it's almost always the valve cover gasket (VCG), not the oil filter housing gasket.
ssm1991 is offline   Reply With Quote
Old 10-01-2009, 04:38 PM   #44
AlexTe46
My Ride: 2001>325i>sedan
Originally Posted by jumbee View Post
Just did the oil filter housing gasket and the CCV...had a leak from both...only difficult part was replacing the alternator...that required some patience and a rubber mallet ...replacing the CCV is a lot easier with the alternator and oil filter housing out of the way...even managed to get the hoses off without breaking them...turns out that the oil leak from the CCV was due to a split in the vacuum hose...
what is the CCV
AlexTe46 is offline   Reply With Quote
Old 10-01-2009, 04:56 PM   #45
easyIsle
My Ride: 02 330i
crankcase ventilator, under intake manifold.
#1
lots of info if you search
easyIsle is offline   Reply With Quote
Old 10-06-2009, 09:26 AM   #46
Pat330i
My Ride: 2001 330i E46
I just did this DIY (good job beberle!) this past weekend before changing oil. After one day, I'm getting oil leaking out from the bottom of the oil filter housing. Perhaps some of the six filter housing bolts weren't torqued enough? I'm pretty sure it's not the gasket as it's new and I double-checked that it was in place (with two sets of eyes) before replacing the housing. Any ideas?
Pat330i is offline   Reply With Quote
Old 10-07-2009, 11:08 AM   #47
beberle
My Ride: 2009 328 wagon
Did you clean the engine block surface? Mine had pieces of the old gasket on it when I removed it. You have to carefully remove any contaminates. Don't use screwdrivers because it will scratch the aluminum surface. Don't overtorque the bolts either... steel bolts going into alumimum block is a torque wrench MUST. Only thing I can think of other than the gasket moved while you were reinstalling... either way, you have to go back in '
Luck!
beberle is offline   Reply With Quote
Old 10-07-2009, 02:31 PM   #48
sudeep30
My Ride: bmw 325i 2002
well :: i had the same oil leak and like most people on forum deriving multiple theory till I decided to try to "beberle" ideas,, at the end i just want to say that i found multiple links that helped me on my way but "beberle" was primary one..ive uploaded pix on google pix and most of my pix showing removal of Alternator which was for me the main hurdle..also im not ur regular mechanic so i dont understand technical words so ive described in laymans language..
the links that helped me on my way were
http://forums.bimmerforums.com/forum....php?t=1284446 (fan removal better displayed)
Oil Filter Housing Gasket DIY w/ some pics
http://forum.e46fanatics.com/showthread.php?t=659100
http://www.beisansystems.com/procedu..._procedure.htm (fan removal)
and finally the pix that i took while repairing my oil leak problem
http://picasaweb.google.com/sudeeep3...eat=directlink
Thanx for ur time
sudeep30 is offline   Reply With Quote
Old 10-08-2009, 03:23 PM   #49
sudeep30
To get to OIL LEAK PROBLEM ONE HAS TO GET RID OF ALTERNATOR WHICH IS IN THE WAY…BELOW ive put lot of pix to enable removal of alternator out of the way …While doing the PROCESS below I came a/c lot of links which kindda helps !! but the main motivation came from " Beberle" ..Thank you " Beberle "..
http://forum.e46fanatics.com/showthr...ing+gasket+diy (WHICH was the most helpful)
I think I missed it but don’t forget to remove the batt conn @ bak of the bmw and lot more MISSING STATEMENTS which are covered in diff forums..
Also this is the link that i made and also im not ur regular mechanic so i m not at all technical hence my pix xplain in layman terms
http://picasaweb.google.com/sudeeep3...OBLEMSEPT2009#
Old 10-08-2009, 04:08 PM   #50
RockLee
My Ride: 99 328i. ZSP, ZPP,
Send a message via Yahoo to RockLee
do you have to drain the oil to do this?
1999 328i Sport Package, Premium Package, 5 speed, Alpine white.
RockLee is offline   Reply With Quote
Old 10-08-2009, 04:22 PM   #51
odgamma15
My Ride: 2003 330 ci
Thanks to the OP... did it 2 weeks ago following the instructions... no problems what so ever
Thanks!
used to hate german cars... now i have 2!!!!
odgamma15 is offline   Reply With Quote
Old 10-10-2009, 02:44 PM   #52
RockLee
Old 10-13-2009, 06:40 PM   #53
soro92
My Ride: 2003 330I
I,ve had this oil leak for awhile now, just cleaned the block and will double check after driving tomorrow, but I'm sure this is the source since the oil was accumulating right behind the filter housing where SSM1991 pic shows. Originally I thought it was coming from the CVV but that area is clean and dry. It looks like next weekend's project. And no Rocklee, you don't have to drain the oil to replace this gasket.
soro92 is offline   Reply With Quote
Old 10-14-2009, 10:56 AM   #54
Pat330i
beberle,
Yes, the engine block surface was cleaned. The old gasket, which was very hard, came out in one piece. There were no solid contaminates left over. I can't imagine the new gasket having moved too much, as we carefully made sure it stayed in place going in. I suppose it was residual oil from the engine side. I haven't seen oil on the floor for a couple of days and the dipstick oil level is only about a millimeter down from the subsequent oil change, so hopefully that was it. Also, the bolts were torqued at the 22 N-m spec that you provided. I couldn't find this spec in Bentley's, so I was just wondering where you got it from.
I'm not gonna stress out about this now, though. I'm now having misfire/idling problems.
Thanks,
Pat
Old 10-18-2009, 05:10 PM   #55
sudeep30
Finally this is the link for GETTING ALTERNATOR OUT TO GET TO Oil Filter Housing Gasket
http://picasaweb.google.com/sudeeep3...OBLEMSEPT2009# or
Old 11-12-2009, 05:09 PM   #56
lhendrick
My Ride: 330i
Originally Posted by Pat330i View Post
beberle,
Thanks,
Pat
As you may have found out by now a lot of idle/misfires are caused by a hole in the rubber flexible boot that connects the ouput side of the MAF to the intake manifold. It is close to the headers and it just seems to tear where it is accordian shaped. Very common and only and hour to change out and costs about $25 for the part.
lhendrick is offline   Reply With Quote
Old 11-16-2009, 12:05 PM   #57
kgvickers
My Ride: 2003 330i ZHP
I recently purchased a '99 323i for my son and this car has this oil leak. It's on the list.
I've got two years of working on my '98 328i and my wife's '97 528i under my belt. What has shocked me about this new engine is how difficult it is to access anything under the intake manifold.
So, my question is: While all this crap is out of the way, will I have reasonable access to everyting under the intake? I'm considering replacing the CVV (and all associated hoses) and all the vacuum lines I can get my hands on.
Or, should I also pull the intake for complete access?
Thanks for all the excellent write-ups!
Keith
kgvickers is offline   Reply With Quote
Old 11-18-2009, 03:08 PM   #58
jumbee
My Ride: 2000 328i
no need to pull the intake..remove the alternator, remove the oil filter housing then you will have clear access to the CVV and all vacuum hoses
jumbee is offline   Reply With Quote
Old 11-18-2009, 03:46 PM   #59
Hartman
My Ride: 2000 323i
Keith
Once you have the alternator and oil filter housing assembly out of the way, it opens up a lot of room and makes the CVV much easier.
Hartman is offline   Reply With Quote
Old 12-15-2009, 08:20 PM   #60
N8330
My Ride: 2002 330CI
Great post, Brian. Kudos for writing this up for everyone. I changed mine out Friday night and it was a piece of cake. Thanks again!
N8330 is offline   Reply With Quote
