#1 |
For those with a rear end thump.
Got mine fixed today. My shop replaced the differential mount bushing, part # 33-17-6-751-808. Both clutch pedal and gas pedal feel noticeably different now. The whole drivetrain seems to have tightened up. theres still a slight clunk going from 1st to 2nd, or 4th to 5th sometimes, but shifting noise has been reduced by about 90%.
#2 | |
How much did it cost?
#3 |
What thump is this? I have a very distinct sound when my auto shifts from second to first, (or third to second actually) thats rather annoying. The car also raises up when its put into reverse, and is lowered a little when put into drive. Is this sort of the same thump? My 330 doesn't do this, but i just assumed it had something to do with it being newer or a manual and not that there was something wrong.
#4 |
Acarder. I have pretty much the same car and same problem. Is yours an auto? I had my rear mount bushing replaced about 3k ago. Mine was about 50$ for the part and $250 labor (Canadian). That stopped the thumping that I was getting from the rear when I put the auto shifter from P-to-R. It got so bad that something sounded like it was snapping each time. But I still and recently have noticed more often, that sometimes when my auto downshifts when im coming to a stop sign it makes a slight thump from the rear on downshift (I think from 2nd to 1st, but it could be 3rd to 2nd). Its done it a couple more times recently. But doesnt seem to do it once the car id warmed (but not entirely sure on that). Anyone else know what it could be? Differential/fluid?
#5 | |
$50 part, $200 labor.
also, there was an audible clunk when shifting into pretty much every gear while driving. |
#6 | |
building up. control arm there, bushings everywhere, new tires, oil change and the list goes on |
#7 |
he said it could lead to subframe damage, but i'm not sure how long that would take. i need to do FCABs too lol. i've been putting it off for a good 6 months now.
#8 | |
time to do those right away then... ugh.. I have a feeling im not going to be covered if my subframe tears because my 328 is an import so i've gotta keep it in good condition or i'm f*cked |
#9 |
hmm, this is interesting. My car is a 328 auto and has done the big "clunk" when put in reverse since i got it a year ago. now my center support bearing is out on my driveshaft, i'm wonderin if the real problem is rear diff bushings? i'm kinda afraid of that. there are 3 rear diff bushings all together though right? they only replace one of yours?
#10 |
No I wouldnt think subframe damage. As much as it is a problem on the 328i, I dont think its as big as people make it out to be. They just come to places like this to report it. Ive read that its more common in the coupes that are standard. Im worried about mine seeing as its a 328 but people have had it covered by BMW. Seeing as it should be a recal if its a safety concern.
#11 |
[QUOTE=jeffro3000;9611167]$50 part, $200 labor.
That sounds like an awesome deal ! My mechanic wants $500 parts and labor . After checking at 4 different shops that is the cheapest rate I can find so my guy is giving me a "good deal". I don't know what the exchange rate is but 200 sounds like a bargain.The bushing on mine is starting to go. I'm not getting any noise but something felt a little off, after having my mechanic inspect and drive it the only problem he can find is a few tears in the rear diff. bushing. He said it would be ok to drive for a bit longer but if I go too long then it could possibly damage the sub frame. He also said that it's a good thing I have auto transmission because sub frame damage is more common in early e46 with manual transmission and 328i. One last thing to note: After doing a bit of research I found out that the bushings they make today are far better than the ones that originally went on the early e46 so even if you get OEM it should be better than the one that was put on the vehicle when it was new. Does anyone have a DIY on this ? I would like to check it out and see if this is a job I can take on myself. |
#12 |
My Ride: comes with blow
Sounds good! I've booked an appointment to have my rear diff bushing replaced in a few weeks, along with welding in the TMS kit. Might make it difficult to isolate any improvement to either the bushing or the reinforcement, but at least it may help to rule out (or in) something like the center driveshaft bearing. Will chime in when I'm done.
Vehicle history
1999 BMW E46 328Ci TS2 1992 BMW E36 316i Sold 1987 Suzuki VS1400 1996 Suzuki LS650 Sold 1984 Kawasaki 305CSR RIP Went from 305cc > 650cc > 1400cc > 2800cc No prizes for guessing what my next engine will be... ![]() |
#13 | |
mujjuman
![]() 2003 325xi 5MT Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP sig by Solidjake |
#14 |
My Ride: 00' 323i, 04 M3 Vert
Hi I recently purchased a Rear Diff TOOL for the rear diff bushing remove/install if anyone wants to rent it please send me a private message. Thanks!
#15 |
Hello Team ... Has anyone located a "cheap" tool to remove/install the rear diff bushing ?
Looking in Bentleys this looks like an easy job, except getting the bushing removed and the new one installed.. Ugh.. |
#16 | |
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
#17 |
#18 |
lol
mujjuman
#19 |
Found this on www.eeuroparts.com
Only $24.90
![]() 2002 330ci Titanium Silver Mods: LED Tail lights, Khoalty LED Angel Eyes, Keyhole Delete, DICE Silverline PRO iPhone Integration |
#20 |
Regional Sponsor
My Ride: 2000 E46 with 254K
Febi yuck......
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. |
