Sponsored by BAVSOUND
Old 03-20-2009, 11:12 PM   #1
adrian320
My Ride: 2002 2.2L I6 Sedan
Question Where to make this Aluminum piece?
I have a CAD file for this piece. Although a little hard to believe it is a Amp rack. I really want this piece made of aluminum but willing to settle for other metals like maybe stainless steel.
Do you know a place where this piece could be done. It is aprox 3ft long. As for thickness I would go with 1/2" or so.
Thanks.
No, no, there is no climate change, it just getting hotter and hotter....and hotter. Yeah, right!?!!?
adrian320 is offline   Reply With Quote
Old 03-24-2009, 08:54 AM   #2
ca1242
My Ride: 2003 330i
Check your yellow pages for local metal fabricators. They should be able to do this in no time if they have the proper equipment.
Old 03-29-2009, 01:44 PM   #3
rjahr01
My Ride: 2007 911 carrera
Just a heads up that is going to be fairly expensive. I could cut it out of 3/8 stainless steel, I have a laser at my shop but that is the thickest it will cut... if you want it out of aluminum you will need to have it waterjet probably because most lasers don't cut aluminum all that well. But just material alone will probably be around 200 dollars, stainless price is about 1.50 a lbs and that would probably weigh 30-40 lbs plus the shop would have to buy a 4x4 sheet of material as well.
rjahr01 is offline   Reply With Quote
Old 03-29-2009, 08:44 PM   #4
adrian320
Thanks for the heads up. Being stainless steel, 3/8 thick would seem more than enough for my application. You work and /or own a shop for this sort of work?
Old 03-29-2009, 08:46 PM   #5
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
I would imagine you could go much thinner than 1/2 inch. Maybe do some relief work on it.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
aluminum, amplifier, machine, rack
