Thread Tools Search this Thread Rating: Thread Rating: 488 votes, 4.98 average. Display Modes
Old 05-13-2013, 12:25 PM   #301
Stinger9
My Ride: '04 330Ci
Yes, come back when you're in the middle of the job and need some perspective! That'll be a better time to ask for more help.
Old 05-13-2013, 06:21 PM   #302
Handsome Kev
My Ride: 328
Does anyone have a diy for removing the step shifter?
Handsome Kev is offline   Reply With Quote
Old 05-14-2013, 11:23 AM   #303
Handsome Kev
My Ride: 328
DIY: **The New Unofficial Auto ----> 5 speed swap** Lots of pictures!!!
Nobody has done this swap from a step tranny?
Old 05-14-2013, 10:57 PM   #304
DavidDee
My Ride: 2004 325xi
OP did. Almost all automatics for the E46 have steptronic. There was only a few years that didn't come with it. Even if it's a non step tranny it should be exactly the same.
"It has a radio and speakers but it's kinda hard to hear over horny bitches moanin in the back when I start it up.."
DavidDee is offline   Reply With Quote
Old 05-15-2013, 07:42 AM   #305
Handsome Kev
My Ride: 328
I know but he isnt answering, I just want to know what is the cable atached to the step shifter and is there anything special that needs to be done to get it out. I need to install a new step shifter.
Old 05-15-2013, 01:30 PM   #306
cyberkaa
My Ride: E46 332i,M3;E30 325i
There are two cables.
One is a thin bowden cable for the ignition interlock.
The other is a thick bowden cable that moves a lever on the side of the transmission to select the gear.
Nothing special needs to be done for removal. You must adjust the second cable when you reinstall the shifter so the position on the gear shift corresponds to the gear the transmission is in. The procedure is explained in BMW TIS if you need details, but it isn't hard to figure it out by inspection.
-Kalim
(klx photo studio)
Old 05-19-2013, 06:56 PM   #307
tuxdreamerx
My Ride: 99 323i
Awesome DIY! I just finished my swap on a 99 323i (GM transmission) and had some info I wanted to pass on for anyone attempting this in the future.
Donor car was a 99 also.
1. 99 didn't use a clutch module (The one mounted on the master cylinder) So the wiring instructions were not useful for my car. The wiring for me only consisted of wiring pin 8 of the EWS to the purple/yellow wire on the brake harness. Now I don't care about clutch switches so if thats your thing this will work.
Here's the big thing that blew my mind - I have done NO recoding at all yet and my Traction control and cruise control work and I would imagine my ABS works but its dry and I can't test it yet, but no warning lights for those, I can enable and disable traction control with the switch and the car acts like it should in each state.
I imagine this has to do with the fact its an early e46 and there is some programming that is different.
I do have the explanation point surrounded by a gear in my dash but no gear letter. Also have a check engine light. So I would imagine recoding for me would just get rid of those warnings.
Car drives and shifts like it should. I kept the clutch fan and it only sounds like a helicopter when I first start driving then it kicks down or something and doesn't sound so loud.
If anyone every has any questions feel free to ask and I will try to help.
tuxdreamerx is offline   Reply With Quote
Old 05-19-2013, 07:10 PM   #308
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
what a stud
Timeless Motor Group
Old 05-20-2013, 02:58 PM   #309
SeattleLSB
My Ride: 2003 330XI, 2003 M3
Greenmonster, can you measure the hole? I'm sure one of these plugs will fit. Can anyone confirm if the manual has a plug in place?
http://www.realoem.com/bmw/showparts...86&hg=51&fg=80
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 06-03-2013, 11:08 PM   #310
clarkson23
My Ride: 325i
DIY: **The New Unofficial Auto ----&gt; 5 speed swap** Lots of pictures!!!
Can this be done to a 2004 325i?
clarkson23 is offline   Reply With Quote
Old 06-07-2013, 12:38 PM   #311
e46beater
My Ride: N63 F10
This maybe a dumb question but during this swap where does the clutch master cylinder top line (8 in pic) plug into at the brake reservoir? Is there another reservoir i need since the car was an auto?
I think I see the braided line in this pic
e46beater is offline   Reply With Quote
Old 06-07-2013, 01:22 PM   #312
Greenmonster138
My Ride: 99 323i?
yes the brake reservoir has a nipple coming off the side. the end is pinched closed for the auto. you have to cut that end so the fluid will feed the line. don't cut it too short. leave the barb to seal and close the line with a clamp.
Greenmonster138 is offline   Reply With Quote
Old 06-07-2013, 01:24 PM   #313
e46beater
My Ride: N63 F10
Probably would've been easy to see at home but I'm at work ordering parts so I appreciate the help!
Old 06-11-2013, 11:08 PM   #314
jimmyloose
My Ride: Der Kombi.
Please take a look in my pitiful thread;
http://forum.e46fanatics.com/showthread.php?t=990984
I've got a 2001 model year 325iT, and I'm having trouble with the wiring side of things.
jimmyloose is offline   Reply With Quote
Old 07-02-2013, 01:26 PM   #315
ewcmr2
My Ride: Many
Yes! I finally got my 2004 M56 swap completed. The physical part is pretty much the same, the coding part apparently is much harder.
After reading every thread on coding and buying the EBay vag cable/dis I got nowhere (not a computer geek!)
Found a shop (European Auto Source, Anaheimn CA) that said they could code car from auto to manual. They couldn't, and charged me for the privilege of being told they couldn't do it!
Finally found Thomas at German Auto Recycling, Riverside, CA. Thomas was able to code my car for the agreed price
ewcmr2 is offline   Reply With Quote
Old 07-02-2013, 10:47 PM   #316
Stinger9
My Ride: '04 330Ci
You paid? Why?
Old 07-02-2013, 11:08 PM   #317
TerraPhantm
My Ride: M3 & ZHP
Coding an M56 manual swap shouldn't be harder than anything else...
Old 07-02-2013, 11:12 PM   #318
Stinger9
My Ride: '04 330Ci
Guy who walked the high wire over the Grand Canyon said it wasn't that much harder than in the circus tent. Easy for him to say.
Old 07-02-2013, 11:19 PM   #319
TerraPhantm
My Ride: M3 & ZHP
Well I mean the procedure should be the same as any other E46 non-M manual swap. It's the same DME as 03/2003+ 325 and 330s. So it should come down to deleting option code 205, recoding all the modules, then clearing the DME adaptions.
Old 07-09-2013, 05:35 PM   #320
Jayster0966
My Ride: E46 E39 E83
Re: DIY: **The New Unofficial Auto ----&gt; 5 speed swap** Lots of pictures!!!
Subscribed. Lots of very useful info.
Jayster0966 is offline   Reply With Quote
conversion, evo3, manual, swap, uuc
