Old 03-26-2009, 02:06 AM   #1
KDS
My Ride: 2005 325i Sport
Drooping Hood Insulation
The under-hood insulation panel on my '05 sedan has started to drop down. There's a total of six tabs that are supposed to fit into slots in the hood, but none of them are staying put. Only the expanding rivets are holding the whole thing in place.
Is this typical? Seems like a really ghetto detail on an otherwise very nicely put-together car.
KDS is offline   Reply With Quote
Old 03-26-2009, 03:06 AM   #2
deafboy
My Ride: 2000 323Ci
Any pics of the sagging?
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 03-26-2009, 03:07 AM   #3
BruceWayne
BruceWayne's Avatar
My Ride: 03 LSB ///M3
you can just take it off, plenty of people do
AST 4200 | Vorshlag camber plates | Power Flex rtab & fcab | AFE stg. 2 | Auto Solutions SSK | Macht Schnell Studs | Stoptech stg. 2
BruceWayne is offline   Reply With Quote
Old 03-26-2009, 04:08 AM   #4
mkodama
mkodama's Avatar
+1
It's just sound deadening. If you take it off I don't think you would be able to tell the difference.
And tons of people will go on about it causing the paint on the hood to peel but they are just making that up. I have had this piece removed on my car for years, paint is perfect. Not to mention E46 engines run pretty cool, and that's why things like the valve cover and intake is plastic.
Old 03-26-2009, 04:11 AM   #5
only1shane
My Ride: 325ci vert
sounds like the tabs are worn out or broken a bit. Either get a new insulator from the dealer or take it out completely. You could also go ghetto and shove something in there with the tabs to keep them in tight, but I would not recommend that.
Color=Japan Rot
H&R Race Springs
HC Racing CF hood w/ M3 bulge
Color matched kidney grilles & front reflectors
only1shane is offline   Reply With Quote
Old 03-26-2009, 07:21 AM   #6
Darkoz
My Ride: E46 325Ci
What happens over time is heat causes the insulator to shrink slightly and become brittle, the two rear tabs on mine don't reach the slots anymore.
Darkoz is offline   Reply With Quote
Old 03-26-2009, 07:35 AM   #7
thailand
My Ride: 2004 330xi
You're absolutly right Darkoz. A lot of times you don't notice on other cars because they have more of those plastic screw types holding the insulation instead of slide-in tabs.
thailand is offline   Reply With Quote
Old 03-26-2009, 09:45 AM   #8
BodyMan
My Ride: 2002 325i
+1 True,true
BodyMan is offline   Reply With Quote
Old 03-26-2009, 09:46 AM   #9
beemteam1001
My Ride: E46 323i
remove it, it does nothing
e46 323i K&N CAI, AA Cat Back, Crank Pully, stage II chip, eBay headers[/SIZE]
beemteam1001 is offline   Reply With Quote
Old 03-26-2009, 09:54 AM   #10
The Jerk
My Ride: E46 M3
It is not ghetto. The insulation is held in place by tabs so that it can drop down in case of an engine fire. The heat melts the tabs and the blanket puts out the fire.
The Jerk is offline   Reply With Quote
Old 03-26-2009, 11:41 AM   #11
KDS
For real? That's kinda cool...
Old 03-26-2009, 12:47 PM   #12
Buegie
My Ride: Lookin for an M3
thats a myth...as people already said, its just for sound deadening
Buegie is offline   Reply With Quote
Old 03-26-2009, 01:09 PM   #13
GoingNuts
Just Nuts
My Ride: 2004 330Ci
It's normal. Over time, the insulation/sound-proofing shrinks from heat. Just get a replacement if you need it looking better. A new piece might even improve noise refinement. Without it the hood might get a bit too hot and there is risk of skin burning on contact.
GoingNuts is offline   Reply With Quote
Old 12-11-2011, 07:39 PM   #14
Danoff
My Ride: '04 330i ZSP
My solution: zip ties (you can spot 4, 2 on the sides and 2 on the bottom)
No word yet on whether the zip ties will melt, but I figure the plastic snaps that are keeping the middle in haven't melted yet, so the zip ties should survive.
Danoff is offline   Reply With Quote
Old 12-11-2011, 10:52 PM   #15
BeMyWhip
My Ride: 01 BMW 330ci
Mine is removed; it wasnt sagging, it was in great shape, but I just wanted my engine bay to cool off easier.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 04-14-2012, 04:55 PM   #16
zwei e46
My Ride: '99 323i & '05 325xi
Thanks for this idea. I had one of the tabs that lost its stiffness. This idea worked perfectly.
Thanks again
zwei e46 is offline   Reply With Quote
Old 04-14-2012, 05:16 PM   #17
jasonbimmer
My Ride: 2001 BMW 330xi
did you get it wet?
mine is petty good after 11 years.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 04-14-2012, 06:11 PM   #18
Roby G
My Ride: 2005 325 Ci
Stick it back up by using high temperature double sticky sided tape strips; and thats not duct tape either !
or just find the BMW hood insulation part with new grommet set online ... try Pelican parts or others
Burnin Arizona Heat Wave !
Roby G is offline   Reply With Quote
Old 04-14-2012, 07:52 PM   #19
BeMyWhip
Mine is still off.
Always Mod!!!
Old 01-24-2014, 06:42 AM   #20
bertonek
My Ride: 2005 E46
I really like this idea. Can someone tell me how you attached the wire tie to the hood? Did you have to drill holes to attach the tie to the hood?
Thanks for the clarification.
bertonek is offline   Reply With Quote
