E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 4.86 average. Display Modes
Old 08-01-2012, 10:48 PM   #161
whataboutbob
My Ride: 2002 325 xit...
152xxx rear spring an motor mount..got new tires too and an alignment..luv this car and dont know what id replae it with
whataboutbob is offline   Reply With Quote
Old 01-01-2013, 02:37 PM   #162
EDWAGON
My Ride: 2004 325xiT
Originally Posted by EDWAGON View Post
Did cooling refresh
Rt cv axle again- found someone sold me a rebuilt GKN for 125
Today power steering pump
At 68k now
Fuel pump - left me stranded
Alternator replaced was overcharging
at 75 k now
EDWAGON is offline   Reply With Quote
Old 01-01-2013, 04:17 PM   #163
Bimmerboy630
My Ride: 2001 325xi
128xxx miles nothin really other then a cv boot and axle and I messed up my clutch. That's about it I'm in the process of replacin my clutch
Bimmerboy630 is offline   Reply With Quote
Old 01-01-2013, 08:32 PM   #164
Sixracer
My Ride: '01 325xiT, '85 M635
Originally Posted by srm5161 View Post
...and my passenger front window is slowly dying
+1
...................2001 325Xi Touring..................1985 M635Csi..................
Sixracer is offline   Reply With Quote
Old 01-05-2013, 08:49 PM   #165
EDWAGON
Drivers side window regulator going.
Old 01-06-2013, 12:11 AM   #166
Iggy27
My Ride: 2003 330xi
I see every one is doing their water pumps and thermostat. What's the best brand that has all medal? I keep seeing Stewart
Iggy27 is offline   Reply With Quote
Old 01-06-2013, 12:29 AM   #167
e46alfonso
My Ride: 330xi MT, mustang gt
oe/oem and stewart are best.
Old 01-06-2013, 01:04 AM   #168
Iggy27
My Ride: 2003 330xi
Just do I need to only by th thermostats housing? Or also the sensor too? And Stewart is a wp?
Old 01-06-2013, 11:47 AM   #169
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
thermostat and it's housing are all one part. stewart is an aftermarket higher displacement water pump
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 01-06-2013, 12:41 PM   #170
Iggy27
My Ride: 2003 330xi
Then what is a good thermostat? I plan on keeping the car for years to come. What brand should I go with?
Old 01-06-2013, 02:27 PM   #171
Blizare
My Ride: 2001 330xi
Wahler for the thermostat.
2001 330xi
2003 530i
Blizare is offline   Reply With Quote
Old 01-07-2013, 09:36 PM   #172
GCoop
My Ride: '04 325xi
Put me down as part of the valve cover gasket crew. ~130k and 9 years not too shabby. Probably could have replaced it a couple of thousand ago TBH.
Struts and shocks are probably next on the list.
GCoop is offline   Reply With Quote
Old 01-07-2013, 10:11 PM   #173
Kubica
My Ride: 2003 325xi
I just sent back a wahler that leaked after six months. Go OE for the thermostat.
Old 01-07-2013, 10:34 PM   #174
gferrer
My Ride: '91 318is/ '03 325xi
@135K now replaced water pump, alternator, window regulator driver side rear, expansion tank.... the usual ey??
gferrer is offline   Reply With Quote
Old 01-07-2013, 11:12 PM   #175
Iggy27
My Ride: 2003 330xi
Well I want a non plastic one I plan on keeping the car for a while.
Old 01-08-2013, 11:29 AM   #176
EDWAGON
Is Behr OE? I have a new Wahler in about 12 months no issues.
Old 01-08-2013, 12:27 PM   #177
SamDoe1
My Ride: 4cyl of fury
Wahler is the OE manufacturer...
Old 01-21-2013, 11:38 AM   #178
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
I see a whole bunch or window regulator replacements. If your window is struggling, check this out before replacing that expensive part. It might just be one of the brittle clips holding the wire to the glass. This fix takes some time and a 3¢ cable tie (although the cable ties CAN break).
http://www.skene.org/bmw/window/index.html
I've got about 120K miles on my 2004 330xi. So far, the major things have been:
front passenger side axle (the boot had cracked, grease had fallen out, and the car was wobbling roughly under acceleration!)
valve cover gasket
oil filter housing gasket
DISA valve (the flap had cracked off)
Tube Elbow (fixed an air-related CEL, and a high-pitched whistle)
some stupid vacuum tube (fixed another air-related CEL - 10¢ of hose to replace some cracked hose)
Fuel filter (remember to clamp the RETURN line!)
Spark plugs
power steering filter change and fluid change
brake rotors & pads (hint: autohausaz.com has free shipping on those heavy things)
belts & tensioners, including conversion to hydraulic tensioner.
To do soon:
new battery - I'm happy with the 8 years I got out of the original.
Cooling system overhaul (using Bav Auto's kit part no. "E46 COOL AUTO")
transmission filter replacement and fluid change
differential fluid change
VANOS line change (because I'm still leaking oil)
So how do I know when I need to change shocks, struts, and bushings? I know nothing about those things.
NCLee is offline   Reply With Quote
Old 07-11-2013, 02:50 PM   #179
EDWAGON
Left rear shock blown at 81,000 miles now
OFHG leaking
FCAB are worn
Old 07-11-2013, 06:09 PM   #180
GuiltySpark
My Ride: 02 325xi
Upper rad hose exploded, expansion tank broke, passenger window regulator, ground wire to tail light (fixed under recall), csb, headliner and pillars, leather stitching split a little in the top of the back seat, vcg was leaking, leaking washer fluid pump, cracked windshield cowling, sway bar end link, a single bad o2 sensor,icv or throttle body was dirty causing car to go into limp mode, and intake boot had a small crack in it. Will be getting another bmw next year hopefully an x3 (manual). Oh, and it has 168k. No lights now just need an alignment and a new window regulator.
GuiltySpark is offline   Reply With Quote
