Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Professional CD Spec
Hi all.
I have a 2003 320d SE Touring with a Professional CD installed from new. Just wanted to know what the difference was with other BMW units? I have the standard 6-speaker set up,don't even know if I have an amp. I don't have the HK set up- that I do know. Any info would be good. |
#2 |
What exactly are you looking for, power ratings? a subjective evaluation of non-amplifier vs. amplified?
#3 |
1) How is it different to a Business CD.
2) Is there more to it than just the head unit. |
#4 |
Anyone?
#5 |
#6 |
In US, we do not have the non-amplified radios, so I can't comment on it. If you only have sis speakers, my guess is you have a non-amplified radio. Why are you asking, are you looking to upgrade the stock system with a higher-end stock system? - don't waste your money.
#7 |
Not being funny but it doesn't matter why - I just ant to know how they differ.
Power/features etc. I'll try some UK forums as you said, lesser known in the US. Regarding upgrades, I'm going to go the Blaupunkt Plug/Play route and drop in a small digital amp with OEM loom. I have a brand new Alpine 2 channel amp but it will be too much hassle to plug into my stock set-up (nor pre-outs for factory) and I don't want to change the HU. |
#8 | |
You can connect the alpine amp to the oem head unit using an adaptor, regardless of what unit you have.
#9 |
Pre-out converter from standard speaker output right?
![]() My Alpine won't fit anywhere other than the loadbay and I'm not into that. Would still like to know about this 'Pro' HU... |
#10 |
If you do not have an oem amplifier, pretty much any adapter that can handle speaker-level signals will work. If you do have an oem amplifier, you need an adapter that can take balanced-differential signals.
#11 |
And the Prof CD spec?
#12 |
I am guessing it is a Business CD with a built in amplifier for powering the speakers. I would guess ~10-15W per channel at the most.
Halston Pitman
rhp@bavsound.com | ext. 104 BSW | Audio Solutions for YOUR BMW www.bavsound.com | 404-963-8857 ![]() iPod Integration | Plug & Play Speakers | Subwoofer Solutions | Satellite Radio | HD Radio | Bluetooth |
#13 |
#14 |
I am talking about the unit that directly powers speakers. All US cars have an amplifier in the trunk from BMW that powers the speakers.
Halston Pitman
#15 |
My E46 was non HK and had an external amp in the trunk.
#16 |
I have a factory Professional unit and no amp.
So how can a 'lesser' head unit, like a Business CD say, power speakers without an amp? |
#17 |
I was under the impression that all the BMW stereos have built-in amps. If I remeber correctly the Business units have a 10W per channel built-in amp and the Professional units have 20W per channel built-in amp. I also think the Professional units have a larger/more detailed LCD display. I believe the reason all US spec. cars utilise an external amp in the boot is to power the additional speakers, even on the non-HK units. In the UK all units Business and Professional (non-HiFi and non-H&K) only have 4 mid-bass and 2 tweeters connected which the built-in head unit amp can handle. I think, but not sure about, the all US spec. cars also have an additional 4 mid range speakers, makeing 10 in total compared to our 6, hence the need for the external amp. The HK system has "upgraded" speakers and a sub-woofer fitted. I am sure someone with an HK system and more knowledge of the various BMW audio systems will chip-in to confirm or correct.
#18 |
Now we're getting somewhere - this would make sense. My Pro stereo does sound better than my old Business one but not massively so.
#19 |
I have the Business CD unit and swaped out the BMW speakers for some half decent Alpine ones. 6.5" 2-way coaxles in the rear deck and 5.1/4" components in the doors. The Alpines have much larger magnets and suck more juice from the already weak built-in amp. Far clearer and richer sound, but I need to crank up the volume knob to get a decent volume level. As such the max volume is now lower but not, that I have ever maxed out the volume anyways. Given the Professional unit has a better and more powerfull built-in Amp it will cope better with decent speakers attached. I also noticed by changing the speakers that the bass gave much crisper thumps. Much improved but a small self powered sub would top it all off nicely, without the need for any great expence.
#20 |
My Ride: 95 525TDS, 94 525iT
All the headunits have built in amplfiers, at the moment my car with the standard hifi system is powered by the Business CD headunit.
| Tags |
| amp, head, professional cd, unit |
