#1 |
how to disassemble rear view mirror on e46??
It stucks to the front window and I have no idea how to take them out.. Also which matrials do I need to use in order to attach it back to the wind shield?? |
#2 |
The plastic housing surrounding the base cracks open like an oyster. Then you turn the mirror base against the glass 90 degrees counterclockwise and the mirror will pop right off. Installation is the reverse.
#3 | |
Procedure to remove it is as cityjohn explained. Although if your mirror is has no electronics then the mirror base is most probably just one piece and doesn't come apart so no need to crack anything open, just turn counter clockwise and it will disconnect from the part that is stuck to the windscreen.
#4 |
Here is the BMW TIS:
http://www.bigpatsfans.com/mirror/pi..._%2016_060.pdf The mirror should be snapped off by pressing, rather than turning. Read the TIS to see what type you have and then follow the correct procedure for removal. Last edited by MitchSF; 04-08-2009 at 06:39 AM. |
#5 | |
#6 | |
#7 |
Related question: if I don't need to remove the whole mirror, but just need to take the front plate off (the part with the mirror on it), does it just pop off? My V1 is mounted inside the mirror casing, but whatever adhesive kept the plate pressed against the mirror has come off and now I can't tell if the signals are in front or behind me. If you need a picture to see what I'm talking about, just ask. Thanks.
EDIT: just in case, I drive a e46 M3 with the rain sensor mirror. I realize I'm reviving a very old thread, but I would rather archive related information in the same thread rather than start a new one. Last edited by cabe01; 10-28-2010 at 01:11 PM. |
#8 |
Sorry for bumping å verry old post. But is it possible to remove the part that sticks to the windshield?
#9 |
^Yes, companies that change windshields do that. They re-attach it with a special type of glue if I remember well that dries with UV
