Old 04-10-2009, 12:23 AM   #1
daveupshaw
My Ride: 2000 323i
Angry Slow jumpy Acceleration
Hey guys...
So i am very new to e46, i just got 2000 323i about a month ago. I dont really know anything about them.
So heres my problem, driving home tonight my acceleration all of a sudden is extremely crappy... i put the gas down all the way in first gear and the RPMs go up very jumpy and slow. same thing in all the other gears with less power in every gear. I have no idea what this could be since i dont know much about these cars.
I did try searching and did not find anything....any help would be awesome...
thanks guys
I replaced the rubber boot with the hole, so hopefully this fixes my problem.
here are some pics of the hole and the new piece
daveupshaw is offline   Reply With Quote
Old 04-10-2009, 12:37 AM   #2
Acarder
My Ride: 69' M3
Manual or auto? Could be a failing torque converter
Acarder is offline   Reply With Quote
Old 04-10-2009, 12:38 AM   #3
daveupshaw
My Ride: 2000 323i
manual....
Old 04-10-2009, 06:17 AM   #4
franz
My Ride: 03 330i
could be so many things, coils perhaps...
franz is offline   Reply With Quote
Old 04-10-2009, 06:18 AM   #5
Zimasha
My Ride: E46 328i 1999
Do the RPMs climb up jumpy and slow in idle as well?
Zimasha is offline   Reply With Quote
Old 04-10-2009, 08:25 AM   #6
Chriztofor
My Ride: 2000 323i (Auto)
The only experience I have with RPMS fluctuating is that it was the cam shaft sensor. First the intake went bad then the exhaust went bad (they are easy to replace). Otherwise read my sig. or goto autozone and check codes for free.
For most BMW problems start off by reading your codes using a peake research tool. Note, as mentioned by other members, although Autozone checks your codes for free they use a generic OBDII tool that does not have the BMW specific fault codes.
Chriztofor is offline   Reply With Quote
Old 04-10-2009, 02:20 PM   #7
daveupshaw
My Ride: 2000 323i
no it idles normal, and this morning on my drive to work it didnt do it anymore.
Also when i got home from work just now i took a look under the hood and found a hole in one of the air intake plastic hoses.. would that hav anything to do with it??
Old 04-10-2009, 02:32 PM   #8
Chriztofor
Yes, any air/vacuum leak could cause that problem.
Old 04-10-2009, 02:33 PM   #9
daveupshaw
My Ride: 2000 323i
The hose that has the hole in it is Number 5 in this image^^^ it is about the size on a quarter.
Old 04-10-2009, 02:35 PM   #10
daveupshaw
My Ride: 2000 323i
i will replace that hose than.
thanx for the help guys hopefully this will fix the problem!!!!"
Old 04-10-2009, 03:20 PM   #11
Kingnog
My Ride: 1999 323i *sport*
What image? I'd like to see it, I think I am having this problem too.
Kingnog is offline   Reply With Quote
Old 04-10-2009, 03:58 PM   #12
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
My Ride: 2001 / 330i
Send a message via MSN to ShaitanCR
Could it also be the Transmision Oil ? I know that happens to automatics when they are low on oil !
************! STEPTRONIC ALL THE WAY...
*SPL Car Audio Champion*
Hamann EURO Black Shadowline Grills
Black EURO 330i emblem
Carbon Fiber Hamann Style Eyelids
Carbon Fiber Emblems
Clear Turn Lights and Sidemarkers
ShaitanCR is offline   Reply With Quote
Old 04-10-2009, 04:08 PM   #13
mhagley323
My Ride: 330i
mine automatic does this as well. its been really sluggish the past few weeks. I almost have to floor it to get anything out of it. Torque converter?
03' 330i
Mods
|M Tech II|P46| Orion V2|Painted Rear Diffuser and Moldings|Clears|Painted Grills|Koni FSD|Eibach|M6|WeissLicht LED|
09' ///M5
Mods
|BMW Performance Gloss Grills, Gills and Reflectors|SuperSprint|RPI|WeissLicht LED|
mhagley323 is offline   Reply With Quote
Old 04-10-2009, 08:02 PM   #14
daveupshaw
My Ride: 2000 323i
Mine is not an automatic, and i just had my transmission oil checked and it is good/pretty new, all of the parts stores and the bmw dealer are closed today because of easter weekend.... so just took some duct tape and fixed the hole in the hose for a few days..i dont see any harm in doing that. as soon as i did this it does not do it anymore, plus the extremly anoying high pitch squeeling noise from the engine is now gone so i guess this hole was causing this as well. when the parts stores reopen after the weekend i will replace the part.
o and the image that didnt work was just a picture of the part from the oem bmw parts website, it was under mass air flow or somthing, and it was number 5.. thats just where my hole was, it is quite big and obvious to see...
cheers
Old 04-10-2009, 08:46 PM   #15
DBear
My Ride: 2001 325i w/SportsPk
I had the same situation a few years ago. Turned out to be a faulty cam position sensor.
DBear is offline   Reply With Quote
Old 04-11-2009, 03:48 PM   #16
N89
My Ride: 330Ci
I'm surprised no one mentioned anything about the clutch, is it slipping? When was the last time it was replaced?
N89 is offline   Reply With Quote
Old 04-11-2009, 07:25 PM   #17
daveupshaw
My Ride: 2000 323i
no its not the clutch, i fixed the problem, i changed the hose with the hole and its all good... im not sure when it was last changed tho i have only had the car about a month
Old 04-11-2009, 07:33 PM   #18
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
I had to change some hoses as well, BMW says you should change the hoses of the car every 5-7 years ! I bought mine a week ago and it still had the original hoses !
Old 04-11-2009, 07:35 PM   #19
Acarder
My Ride: 69' M3
Change the oil like twice in the next 3000 miles and drive like you stole it. You'll be good as gold after that (as much as it sounds like it, i'm not being sarcastic here. 6000RPM+ per journey to clean out the gunk and crap thats probably in there from the last owner).
Old 04-11-2009, 08:31 PM   #20
Kingnog
That doesn't sound (to me) like a very good idea. I don't see how running the engine at high RPMs will "clean" it, it just sounds like it will wear it out.
acceleration, engine light, no power, shaking engine, slow
