Sponsored by The Tire Rack
Old 04-10-2009, 02:17 PM   #1
Maniac
My Ride: platinum ecoboost R6
coupe sport susp.265/30/19
will they fit? with the fenders rolled?
2002 325
19x8.5 38 offset
19x9.5 45 offset
<img src=http://i194.photobucket.com/albums/z76/E46Maniac/signumber2.jpg border=0 alt= />
Originally Posted by 46_coupe View Post
Attractive and stable works for me...I'd rather help wifey program the stove clock than wonder if she purposely left the gas on :eek:
grey green metallic-gone
platinum ecoboost on 35 toyo MTs
Maniac is offline   Reply With Quote
Old 04-10-2009, 03:00 PM   #2
Chris-TK
My Ride: Mk VI GTI
Without a doubt.
K.
Chris-TK is offline   Reply With Quote
Old 04-10-2009, 05:28 PM   #3
Maniac
how about without rolling fenders? Obviously if I don't need to I'd rather not roll them but I will if neccessary. Thanks for the fitting conformation
Old 04-10-2009, 06:36 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
235/265 combos would work on that setup without a problem as long as you are at stock height. No fender rolling required.
-Charles@VMRWheels
www.vmrwheels.com
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-10-2009, 08:14 PM   #5
Penguin Koolaid
Banned
My Ride: Inline Six
-charles@vmrwheels
www.vmrwheels.com
+1
Penguin Koolaid is offline   Reply With Quote
Old 04-12-2009, 02:51 AM   #6
Maniac
1 more question guys........... do i need spacers or anything?
Old 04-12-2009, 10:22 AM   #7
Chris-TK
My Ride: Mk VI GTI
With a 38 and 45mm offset NO you will not need spacers.
K.
Old 04-12-2009, 12:47 PM   #8
Maniac
thanks alot man
Old 04-16-2009, 09:15 PM   #9
Maniac
a guy local to me has H R race springs for sale im thinking of picking them up.............am i going to need to roll my fenders?
Old 04-16-2009, 10:47 PM   #10
Chris-TK
My Ride: Mk VI GTI
Probably
K.
Old 04-17-2009, 08:58 AM   #11
Maniac
thanks
Old 04-18-2009, 05:51 AM   #12
WhiteOut323i
My Ride: 2000 323i
Hey will fit perfectly fine
WhiteOut323i is offline   Reply With Quote
Old 04-18-2009, 02:13 PM   #13
BartenderPlease
My Ride: '03 540i/6 M-Sport
I don't think you'd rub, but to be safe I would roll them.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 04-20-2009, 11:37 AM   #14
Salazar
My Ride: 323ci
Send a message via AIM to Salazar
this setup should fit on a 2000 323ci as well correct?
Salazar is offline   Reply With Quote
Old 04-20-2009, 11:40 AM   #15
JJR4884
My Ride: BMW
FYI i have the SAME exact setup, and i am on H&R sport springs........ still no rubbing
JJR4884 is offline   Reply With Quote
Old 04-20-2009, 11:45 AM   #16
Salazar
My Ride: 323ci
Oh one more thing.. I may be getting this setup:
Wheel Diameter (Inches) - 19"
Wheel Width (Inches) - 8.5F/10R"
PCD Bolt Pattern - 5x120
Offset - 30F/37Rmm
Hub Bore - 72.6mm
Color - Hyper Silver with Polished Lip
Quantity - 4 Pcs. (1 set)
Will the tire setup above be alright with 10 in the rear? or will that stretch.. I a m running on H&R Cupkits, which are about the same drop with H&R springs.. With 19x10 in the rear I will probably need to roll fenders though right? And will the 30F/37R offset be fine without spacers?
Old 04-20-2009, 12:41 PM   #17
Chris-TK
My Ride: Mk VI GTI
Offset - 30F/37Rmm
Hub Bore - 72.6mm
You are going to rub like crazy both FRONT and REAR. The max you should go in the front is a 35mm and the rear for a 10" I would run something closer to a 40-45mm.
K.
Old 04-20-2009, 01:19 PM   #18
Salazar
My Ride: 323ci
thanks for the reply.. would those rub even with fenders rolled?
Old 04-20-2009, 01:22 PM   #19
Chris-TK
My Ride: Mk VI GTI
Fronts yes, rears is up in the air.
K.
Old 04-21-2009, 05:56 PM   #20
Salazar
My Ride: 323ci
2002 325
19x8.5 38 offset
19x9.5 45 offset
You don't happen to be looking at VMR's are you?
