Old 04-11-2009, 03:20 PM   #1
miguelflyat04
My Ride: 2001 325i
Send a message via AIM to miguelflyat04
Steering wheel shaking after replacement of Front CA's and Bushings
Just last weekend I replaced my Front Control Arms, Bushings, and Wheel Bearings. Now when I drive 55 - 60 mph and above I get a nasty shake on my steering wheel. This occurs without me applying any brakes!
When I apply the brakes the shake is bad as well... I am 90% sure that this is due to warped rotors because when I rotated the rotor I heard the pad touching a spot of the rotor, then going free, then touching again, etc... So I am almost positive about my warped rotor issue.
Just today I had an alignment done at the BMW stealership because I needed one anyways! I was hoping that the vibration was due to the variations in the tires pulling to each side because of very bad alignment after the CA and Bushing replacement... However it did NOT resolved my issue and I am now trying to figure out what to do next!
The questions is... Could it be WARPED ROTORS the reason for having such a nasty steering wheel shake at 55 mph and above?? (Keep in mind that this happens while I am NOT applying any brakes)
Or should I start somewhere else?
Everyone is welcomed to share their expertise.
Thanks,
Miguel
miguelflyat04 is offline   Reply With Quote
Old 04-11-2009, 03:49 PM   #2
jemmons330cic
My Ride: 2001 330cic
Do you have any slop in your steering rack when your driving?
The other possibility is that your tires could have come out of balance, could have lost a weight from the rim? Thats an easy check.
" If you knew you couldn't fail, what would you try to achieve? "
jemmons330cic is offline   Reply With Quote
Old 04-11-2009, 04:13 PM   #3
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
My Ride: 2001 / 330i
Send a message via MSN to ShaitanCR
+1
After changing anything in the suspension or steering, you should definitely get the car balanced.
Also check tire pressure on a regular basis
************! STEPTRONIC ALL THE WAY...
*SPL Car Audio Champion*
Hamann EURO Black Shadowline Grills
Black EURO 330i emblem
Carbon Fiber Hamann Style Eyelids
Carbon Fiber Emblems
Clear Turn Lights and Sidemarkers
ShaitanCR is offline   Reply With Quote
Old 04-11-2009, 04:50 PM   #4
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
first check the balance of the tires, then change the brakes.
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 04-11-2009, 04:54 PM   #5
diesel jonny
My Ride: 2001 330d sport
balance and tracking
diesel jonny is offline   Reply With Quote
Old 04-11-2009, 04:55 PM   #6
miguelflyat04
My Ride: 2001 325i
Ok... I will be checking the balance next! Sometime in the next few days... I have lifetime rotation and balance on my tires so that would be cheap!
Keep your suggestions coming just in case balancing does not resolve my problem.
Thanks again... I love E46FANATICS!!!
Old 04-16-2009, 12:28 PM   #7
miguelflyat04
My Ride: 2001 325i
Alrighty.... this is what resolved my shaking problem:
HUB CENTRIC RINGS
My suggestion to anyone who has AFTERMARKET WHEELS and shaking problems is to first check for the HUB CENTRIC RINGS. Its easy and CHEAP!!!! This hubs are usually made of plastic and can easily wear down to the point that they break. They could have also been removed by any tire shop who forgot to re-install them.
Also, anyone requesting help with anything having to do with suspension... If you have aftermarket wheels, make sure you mention it. It is something that many people including myself forget to mention. Even though factory wheels may or may not require this hubs, MOST aftermarket wheels do require it.
When you think about it... it makes perfect sense! You can balance a wheel or tire or whatever, but if it has considerable play or if it is not laying solid on the hub... then balancing it makes no difference because it can still shake especially at higher speeds due to the pressure.
Anyways... I just wanted to share my results with everyone. I hope everyone who has the same problem can benefit from my information.
**REMEMBER**
If you have AFTERMARKET WHEELS.... Check for that little plastic thing (LMAO) called: HUB CENTRIC RING or HUB RING
steering wheel shake, warped rotors
