#21 | |
#22 |
Just Nuts
A light weight flywheel will spin up quicker and spin downer quicker upon clutch engagement. It's all to do with momentum. The light weight flywheel is only advantageous when you are constantly on the gas to compensate for loss of momentum when the load is on. Flywheel momentum is part of the torque, in addition to toque coming from the engine. I have no trouble contending light flywheels loses torque. The end product is poorer overall fuel economy compared to standard flywheel.
#23 |
I've heard some people throw out numbers concerning the cost of clutch kits and/or flywheels, and have looked around some on vendor sites, but I have yet to confirm the lowest price or best place to buy from. It looks like I'll probably just be doing the Sachs OEM clutch, as the UUC option is over $1k. Where's the best place to find it? I've looked on BavAuto and AutohausAZ, for example, an am considering either. Any better options I don't know about, or cheaper LW clutch kits?
![]() 18" Black ASA AR1 Rims | Yokohama Advan S4 Tires | Bilstein Sport Shocks | Eibach Pro-Kit Springs | Brembo Slotted Rotors | 6000k Xenons | 6000k P. Chrom. Angel Eyes | Eagle Eye LED Tail Lights | K&N FIPK CAI | M-Tech II Front Bumper | 35% Tint | Clear Corners | Matte Black Grille |
#24 | |
CDV delete, Sharked, AFE CAI, UUC stage 1 flywheel/m5 clutch, Turner tracksport coilovers, UUC transmission mounts, Short Shifter
#25 |
Apple Jews
Location: Drunk onthe Beach.. Official 4ngiefest.com Techie Go to: 4ngiefest.com/donate Needs: to leave the computer Status: ///Pantless
My Ride: 2001 325i Sedan
i have noticed no difference in gas mileage. and since then ive had it, ive gone through 3 tanks of gas.
[IMG]http://************/ogaeq6[/IMG] Question for you: Are boobs and hands polarly charged, thus causing the inevitable joining of the two? If so are some breasts simply charged backwards? On a scale from 0 to 24...wait, 3 to 24, where 6 is the lowest and 12 is the highest, how freaking high re you right now? She's got you high, and you don't even know yet. |
#26 |
I am at 165K. Still driving like a jackass and everything holds awesome.
I am totally amazed.
#27 | |
The loss of momentum is called "false torque." It seems useful during part-engagement of the clutch, such as right of the line, but once the clutch and flywheel lock together, the higher mass of a stock flywheel immediately becomes a burden. check the dyno graphs on UUC. as for the fuel economy part, i hope you had fun making up your load of sh ignore list: 1) bmwbun 2) goingnuts |
#28 | |
#29 | |
Just Nuts
Now, defend your position reduced momentum does not require increased force input to retain the same speed. Last edited by GoingNuts; 04-12-2009 at 06:51 PM. |
#30 | |
Just Nuts
#31 |
My clutch died around 70k. Dunno how hard the driver was before me or whether he/she just didn't know how to drive clutch properly. Also important to note my cdv was removed before I purchased the car. I hear this decreases the life of the clutch. Hopefully I can manage 100k+ off my new one. I'm at 103k now.
#32 |
NA V8
165k and original clutch
![]() M3 DCT/Swift Spec R Springs/Macht Schnell Spacers/Megan Exhaust/Coming Soon: Test Pipes and BPM Stg 2 Tune |
#33 |
Apple Jews
CDV in use will decrease the life of the clutch. its designed to be a smooth engagement. therefor...slipping...heating up.
#34 |
As soon as my clutch goes out i'll likely get the same setup as beingdevious. hopefully my engine's torque output will remain at 206lb-ft
![]() I was worried about losing the false torque and drivablilty of the heavier flywheel but jetskier, beingdevious, e46abuser, and a couple others i've heard from all seem to have nothing but good things to say about the aluminum flywheel setup. To anyone else reading along: just ignore goingnuts. you'll have alot less ignorant posts to sort through when looking for information. |
#35 |
Just Nuts
There's no such thing as false torque. People should disregard this nonsense.
#36 |
My Ride: AA2.5 ZHP, S54 Sedan
i replaced my clutch at 109k a month after i got my car, it was time for a new clutch because it fell apart (the springs broke)
- Krystian
http://www.facebook.com/kgawlak Owner of many E46's :) [Currently own 2005 AA 2.5 Kit ZHP, S54 Sedan, 01 330ci and 1 Coupe 1 Sedan 1 E46 M3 parts cars] Summer toy : 2009 Yamaha R6 Raven "Currently Lamborghini Balloon White" It is For Sale ! ![]() Like us at : Fluid Motorunion |
#37 |
Apple Jews
the engines output absolutely WILL NOT be affected by a lightweight flywheel. it is impossible. the flywheel is a transfer device from the engine to the transmission.
if you have 200ft lbs before, you will have 200ft lbs after. you will just be able to get there quicker (due to a quicker rev) i don't see whats so complicated about this.
#38 | |
If Im wrong ... .I will go with EXTRA heavyweight flywheel next time. Who sells those by the way?
#39 |
I'm at 179K on the original clutch. It's shuddering a little, but doesn't slip.
I've heard varying opinions about whether the flywheel can be turned or must be replaced. If it's not glazed (overheated from slipping a lot) then you should be able to reuse as-is.
2003 E39 M5 Lemans Blue: The most amazing car ever built
-------- 1999 E46 328i Bone stock 5-speed: Soon to be track rat 230K and still running strong |
#40 | ||
| Tags |
| flywheel, goingnuts |
