Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 4.96 average. Display Modes
Old 04-01-2011, 03:24 AM   #41
locomexicano
My Ride: E46 330ci
Send a message via MSN to locomexicano
Talking
Originally Posted by johnnatalie View Post
U have to find the leak u r letting air into the system which causes overheating (boiling water idea) check the air relief valve right above reservoir. Again find the leak u can damage the heads if it gets to hot
Thanks John, looks like I'll be busy this weekend Boys.
Do you guys know of any auto parts shops that will have any of these hoses in hand???
locomexicano is offline   Reply With Quote
Old 04-02-2011, 02:10 PM   #42
dharamveer
My Ride: e46 2002 2.5l
I tried my thermostat change today, my bolts were very corroded and one the bolts head broke off when I was trying to remove it so its stuck in.
see pic attached of which one it is.
some questions :
1. How can I remove it?
2. What if I just leave it in there and replace my thermostat and tighthen the other 2 bolts, if I put rtv sealant as well. Will I be ok or will it leak?
3. how much do garages charge to drill out bolts etc?
dharamveer is offline   Reply With Quote
Old 12-26-2012, 12:42 PM   #43
|2eckLesS
My Ride: 2004 330ci
+1
|2eckLesS is offline   Reply With Quote
Old 01-13-2013, 03:38 PM   #44
TAKAFOOMI
My Ride: 2004 330cic
Leaking lower radiator plug after thermostat replacement
Hello Guys. I'm hoping someone can provide some quick advice . I just replaced my thermostat in my 2004 E46 convertible, automatic. Everything reassembled, but after refilling the coolant and checking for leaks I found one, on the blue radiator plug under the expansion tank. I tightened the blue plug, just so it's snug.. However, the leak is coming from the black nut which the blue plug sits within. The nut looks like something meant to be tightened, but its not happy when I put a crescent wrench on it. It's a drip every 5 seconds or so at idle. Can anyone recommend a way to stop the leak? Some sort of goo I can put around the nut? Help! I attached a photo for clarification.
TAKAFOOMI is offline   Reply With Quote
Old 03-06-2013, 02:56 AM   #45
Iggy27
My Ride: 2003 330xi
How many lbs do you tighten a thermostat too?
Iggy27 is offline   Reply With Quote
Old 03-06-2013, 07:44 AM   #46
paraklas
My Ride: ESS TS2 320ci
hmm mine looks a bit different i think, I don't believe you are supposed to tighten anything down there. Are you sure the leak is not from the expansion tank - connector below that comes from?
Edit: I believe they're different because yours is automatic and mine is manual
10Nm (~8 lb ft)
Old 03-06-2013, 12:33 PM   #47
hummer
My Ride: 2001 330CI
Originally Posted by jabela View Post
I just replaced my thermostat today. It was stuck open. Also, the gasket had deteriorated along the bottom. Here's the bleeding procedure I used and everything looks good. Make sure to check your coolant level when your engine has cooled after your next drive.
Coolant Bleeding procedure.
Open sealing cap. Set heater control to maximum temperature. Set blower to low level. This opens the heating valves and sets the auxiliary water pump in operation. Run engine and briefly press accelerator pedal three to four times (approx. 4500 to 5000 rpm) to flush engine cooling circuit. In doing so, do not run engine for longer than approx. 30 seconds; otherwise coolant will heat up and expand. If the coolant level drops in the expansion tank during this operation, top up expansion tank with coolant up to edge. Screw on sealing cap and warm up engine until thermostat opens.
http://forum.e46fanatics.com/showpos...6&postcount=35
This is WRONG! Running the engine is not required or recommended to bleed the system properly! Do the heater thing and remove the bleeder screw. Pour the coolant into the tank until the fluid rises to the screw hole. Stop and wait as the air majically comes out all by itself! Pour again until the fluid at the screw hole stops dropping. If the car is on the wheels you might have to add more, if it's on a couple of 2X like I do to get underneath, it may actually over fill some. Start and drive through full temp, stop and cool, then check the level in the tank. The torque is 10 lbft. The only reason to use goop is if the block mating surface is F'd up. Otherwise no-no. If bolts are broken, it's because some a-hole tightened them too tight.
Old 04-20-2013, 10:22 AM   #48
Faucette1954
My Ride: 2005 BMW 325ci
First time BMW (05/325ci) automatic) owner the car is over heating I first thought it was because the electric fan was not working. I just notice that the car but when I checked it the lower hose to the radiator was not hot but the top one was boiling. Does that mean that the thermostat is not working and should be replaced? Coolant level is good.
thanks for any info that you can provide.
Faucette1954 is offline   Reply With Quote
Old 07-20-2013, 09:05 AM   #49
saturn
My Ride: 525i
Thanks to OP for a great DIY, although I have a question, is there a thermostat housing for M54B25 engines that will run the engine cooler i.e. open the thermostat earlier than 93F ????
saturn is offline   Reply With Quote
Old 07-21-2013, 04:33 AM   #50
paraklas
There was a discussion a lot of times regarding this time, and the general conclusion is that the current factory thermostat are optimized from the factory to provide the best combination among cooling and fuel efficiency. The ECU can and will open the thermostat earlier than its mechanical threshold if certain conditions are met (temperature, load, rpm) so there's no point in my opinion to mess up with other types of thermostats.
Are you facing a problem related with temperatures?
Old 07-21-2013, 06:23 AM   #51
saturn
My Ride: 525i
Thanks paraklas, I am not having any problems, just had a leak, so I thought I would try replacing the thermostat altogether with a new one and see if there is any better available. I guess old school plastic housing is the way to go from what you are saying.
Another question though, I am not sure when the thermostat housing was changed, if it is leaking, is it advisable to change the entire thermostat housing or just the gasket?
Old 07-22-2013, 07:26 PM   #52
saturn
My Ride: 525i
@OP, one of the steps you mentioned was "To prevent future coolant leaks, I applied some high temp RTV silicone sealant as per application instructions."
Is this step necessary? Or you just added extra silicone sealant for extra protection?
Old 11-23-2013, 01:30 PM   #53
TR4G-
My Ride: '01 325xi, '90 325iC
Originally Posted by JS8736 View Post
I agree with the RTV idea. I installed a new thermostat when I did a cooling system rebuild, torqued the thermostat to 10NM, etc., and it weeped slightly. I re-drained the radiator at the right side lower plug, removed the shroud and fan, disconnected the upper and lower hoses from the thermostat, RTV'd the mating surface exactly like in the photo here, and no more leaks....
Yeah, how do you know it's 10nm?? My bently doesn't have the torque values listed!!! It only says engine block drain plug and radiator drain plug...
On the m3 model which is a completely different setup, it states 10nm. So can someone clarify what the torque value is for the 4 thermostat bolts? I am halfway through this DIY and am waiting on torque values before buttoning up. Please let me know
TR4G- is offline   Reply With Quote
Old 12-21-2015, 07:30 PM   #54
3 Beater
My Ride: 2002 325i
What is the thread size and length os the 13mm bolt on the thermostat??
The one same size as the nut off of the thermostat
3 Beater is offline   Reply With Quote
Old 02-24-2016, 03:28 AM   #55
lhuy2733
My Ride: 99 E46 318i
Guys,
Is it possible to purchase the gasket only?
lhuy2733 is offline   Reply With Quote
Old 02-25-2016, 11:32 PM   #56
DEADF15H
My Ride: DD is a 2001 325i
Originally Posted by lhuy2733 View Post
Guys,
Yes you can.
DEADF15H is offline   Reply With Quote
Old 02-26-2016, 04:46 AM   #57
paraklas
Guys,
http://www.realoem.com/bmw/enUS/show...diagId=11_2180
Part #5
Just be careful, the thermostat housing is composite and becomes brittle with age and may crack even with the correct torque
Old 03-25-2016, 05:01 PM   #58
DEADF15H
Or you snap a 15 year old bolt, while torquing to 10 ft/lbs and really screw up your day.
I just did it.
EDIT: saved by Ace Hardware and the exact size SS bolts
