Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 04-14-2009, 11:45 AM   #1
yogi799
My Ride: 99 328i auto
Car won't crank, battery good, ghost problem, please help...
I am growing really desperate; occasionally, sometimes twice daily, sometimes twice weekly, etc car won't even crank when ingintion's turned. Just silence, nothing else (well, beeps if seatbelt not fastened). Dashboard lights DO NOT die when turning the ignition, also no clicking sound, so I know it's NOT the battery (tried jumping as well, no difference). Just regular lights ON and no crank, nothing...
So I thought based on some previous threads that it might be my key / transponder (for immobilizer) going bad, and the car thinks I'm using a wrong key thus blocking the ingnition - so I ordered a new key and SAME THING (the new key is good, I tested it and it started the car fine, when the problem temporarily goes away).
After a good two week period, daily problems again. What can this be?? I was just stuck for 10 minutes in the parking lot, trying the ignition many times and nothing. Then it finally cranks and starts beautifully. Sometimes I get this feeling that something isn't ready so the car waits - as several times it would start cranking only about a second after I turned the ignition to START, so with a bit of delay.
Help please....
yogi799 is offline   Reply With Quote
Old 04-14-2009, 11:53 AM   #2
Hrvat
My Ride: 02 Imola Red M3
Co-worker had this problem on his GM car. I dont know what you call it but it was that thing in the steering column where you insert the key into. Is that what you mean by transponder?
Let me ask you, do you have any things hanging off your car keys?
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 04-14-2009, 11:57 AM   #3
Custom3
My Ride: HellRot 330CI
there are 2 common problems for this.... fuel pump and cam sensor. its probably one of the 2.
Old 04-14-2009, 11:58 AM   #4
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
Judging by your post, since you're able to fully turn the key, your starter's probably dead (or very close to it, as it does crank every now and then).
Sicily1918 is offline   Reply With Quote
Old 04-14-2009, 12:06 PM   #5
Hrvat
If it was fuel pump, the car would crank but wouldn't start.
His car won't even crank at times
Old 04-14-2009, 12:19 PM   #6
inlinesicks
My Ride: E46, Jeep, Subaru
Next time it wont start try to hit you starter with something and then see if it starts........wait is it even possible to get the the starter with everything together?
inlinesicks is offline   Reply With Quote
Old 04-14-2009, 12:32 PM   #7
radaddict
My Ride: 325Xi
Ignition switch in the steering column. It could be the starter motor, but since you say that your dash lights aren't even dimming when you try to start, I'm thinking it's a faulty ignition switch. Turn your headlights on. If the lights don't go off or at least dim when you try to start, then your ignition switch isn't doing what it's supposed to do. Hope that helps.
radaddict is offline   Reply With Quote
Old 04-14-2009, 01:00 PM   #8
Sicily1918
Sicily1918's Avatar
My car didn't dim anything when my started died -- it just wouldn't start.
Old 04-14-2009, 01:04 PM   #9
Pete330iZHP
My Ride: 2010 Nissan 370Z
Mine was doing the same thing, but my immobilizer was throwing a code. i don't think the starter, fuel pump or cam sensor would cause that. so i'm going to bet that its the antenna (the ring around your ignition) I've read of those going bad...
2003 330i ZHP 6MT SOLD!
19" Staggered VMR VB3's - H&R Sport Cup Kit
Alcantara Interior Trim - Hardwired V1 - 15% Tint
Tinted Corners, Sidemarkers, and Tail Lights
Black Kidney Grills - Corner Delete - Clutch Stop
Pete330iZHP is offline   Reply With Quote
Old 04-14-2009, 01:05 PM   #10
BRYGUY1086
My Ride: 2001 330ci
just out of curiosity anyone heard of this problem being related to the vanos just because it throws the code for the cam sensor? I'm probably off but i was just curious
BRYGUY1086 is offline   Reply With Quote
Old 04-14-2009, 01:08 PM   #11
vPanya
My Ride: 01 325CI
Help please....
im assuming u using the original key..... the battery inside the keys dying. u gotta use the valet key. it dont recognize it and thats why it dont click. im sure ur lights and radio comes on, just no crank, not even click. USE VALET KEY
vPanya is offline   Reply With Quote
Old 04-14-2009, 02:53 PM   #12
yogi799
"So I thought based on some previous threads that it might be my key / transponder (for immobilizer) going bad, and the car thinks I'm using a wrong key thus blocking the ingnition - so I ordered a new key and SAME THING (the new key is good, I tested it and it started the car fine, when the problem temporarily goes away)."
Old 04-14-2009, 02:54 PM   #13
yogi799
Did all other symptoms match exactly what I have when your starter died?
Old 04-14-2009, 03:20 PM   #14
Sicily1918
Sicily1918's Avatar
The battery serves to operate the remote features of the car only; you do not need a working battery to actually start it as the transponder works in much the same way RFID does.
Well, once my starter died, it died... nothing I did could start my car... luckily that was the day I was supposed to take it to my mechaninc to get the starter replaced.
Basically, all I would hear was a slight click and then nothing... everything worked, but the engine would not turn over. The only other symptom I had was a weak starter for two days (it behaved exactly the same as a weak battery) and then nothing.
Radaddict may be right, though -- it could simply be that the ignition switch's not making proper contact, hence the random starts.
Old 04-14-2009, 10:03 PM   #15
yogi799
Man I'm gonna bump this thread as I just did a lengthy search and found more of us struggling with this ****.
Has anyone been able to fix it? What was it???
http://forum.e46fanatics.com/showthread.php?t=637354
http://forum.e46fanatics.com/showthread.php?t=655152
http://forum.e46fanatics.com/showthread.php?t=649895
Old 04-15-2009, 12:21 AM   #16
summit425
My Ride: E46 AW 323Ci
hey I read your PM. yeah I fixed my problem my replacing the HID wiring harness. My +ve end burned because I didn't install it properly. After I replace and install harness correctly everything worked! (I was not able to start the car with jump start either)
If you installed any after market parts I suggest you to move them first and see if you can start your engine. (HID, angel eyes etc.) hope you can fix your problem!
summit425 is offline   Reply With Quote
Old 04-15-2009, 12:43 PM   #17
Renboy
My Ride: 04 330Ci '08 Daytona
Mine was doing the same thing. I'm led to believe it's my clutch switch. Assuming yours is a manual, try this; turn key to start position first, push clutch pedal second. I haven't had a problem starting my car since I reversed the starting procedure. If it's an auto that you drive, then it's probably the starter.
Renboy is offline   Reply With Quote
Old 04-15-2009, 01:04 PM   #18
E46 S54B32
My Ride: 323ci
i have this probelm too sometimes..i think its the starter
GL fixing it dude
E46 S54B32 is offline   Reply With Quote
Old 04-16-2009, 12:43 PM   #19
SteelGray3
My Ride: 2003 slicktop LSB M3
This is exactly what happened to me yesterday, I have been roll starting my car everywhere. Where is the starter/how hard is it to replace? I already ordered the partor how much in labor did you get charged?
SteelGray3 is offline   Reply With Quote
Old 04-16-2009, 12:54 PM   #20
Hrvat
Actually, come to think of it my dad had same problem on his Pontiac van and it was a starter
I heard starters on E46 are bitch to change
