Old 04-14-2009, 12:31 PM   #1
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Fuel trim code TSB keep in mind.....
SUBJECT
M54/M56: Mixture Too Lean - Fault Codes 2882/2883 are Stored in the DME
MODEL
E85 with M54 produced from 3/02 to 11/05
E46 with M54 from 8/00 to 8/06
E46 with M56 from 12/01 to 12/04
SITUATION
The customer complains that the "Service Engine Soon" light is illuminated. The fault codes "2882/2883 fuel trim, mixture too lean" are stored in the DME.
CAUSE
Possible causes may include: incorrect air filter, unmetered air or a defective air mass meter.
PROCEDURE
Remove and inspect the air filter element. Only the filter with the P/N 13 72 1 744 869 must be fitted. If the filter is the correct one, please follow the test plan and repair accordingly.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 06-11-2009, 08:21 AM   #2
jbeurotech
Regional Sponsor
Don't forget to keep this in mind
Seth Thorson
