Old 04-15-2009, 07:28 AM   #1
HELLAS NC
My Ride: 03 320Diesel Tractor
How can you make the seatbelt light stay on?
The seatbelt light on the instrument cluster comes on and dies within a couple of seconds. It looks like it's just on a timer, cause even if you fasten the seatbelt, it stays on until the predetermined time and only then does it die.
Can I hardwire something to make the light stay on or have the beeper go off (after the car is started) until the seatbelt is fastened?
For the record: I NEVER drive without a seatbelt. (Good) Old habit I picked up from working on a mine once.
INFO: I have non-electric, non-heated leather seats.
I don't have a solution, but I admire the problem.
HELLAS NC is offline   Reply With Quote
Old 04-15-2009, 09:42 AM   #2
Adamo99
My Ride: 330Ci vert
?? I'm pretty sure mine stays lit up until I fasten my seatbelt.
Sorry, just noticed your seats are way different than mine. Mine are heated, electric, leather sport seats.
Adamo99 is offline   Reply With Quote
Old 04-15-2009, 09:48 AM   #3
FatBackNasty
My Ride: 330Ci
You can buy my car. That light stays on all the time whether im buckled or not.
http://forum.e46fanatics.com/signaturepics/sigpic125814_6.gif
FatBackNasty is offline   Reply With Quote
Old 04-15-2009, 09:50 AM   #4
JoeVert
My Ride: 330Cic
This has happened to me twice since I bought the car... then after shutting it off and starting it awhile later... gone, works like it should. wth?
-JoeVert
JoeVert is offline   Reply With Quote
Old 04-15-2009, 09:54 AM   #5
dh0licious
My Ride: '01 325i Sedanx0r
ive got the exact same issue. even if i don't fasten my (driver) seatbelt, the light goes off anyway after like like 8-10 seconds of me turning the car on...
subscribed
dh0licious is offline   Reply With Quote
Old 04-15-2009, 09:56 AM   #6
HELLAS NC
So the wiring for this function will prolly go with the electrics of the seat?
Old 04-15-2009, 11:00 AM   #7
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
My Ride: 2001 / 330i
Send a message via MSN to ShaitanCR
In the case of the electric sports seats YES... the seat harness and the seatbelt harness are connected. If you remove the seat or luck under it you can see that it is one big piece. The seatbelt part on the seat and the seat are 1
************! STEPTRONIC ALL THE WAY...
*SPL Car Audio Champion*
Hamann EURO Black Shadowline Grills
Black EURO 330i emblem
Carbon Fiber Hamann Style Eyelids
Carbon Fiber Emblems
Clear Turn Lights and Sidemarkers
ShaitanCR is offline   Reply With Quote
Old 04-15-2009, 11:04 AM   #8
Bimmer^Hue
My Ride: 330i
Send a message via ICQ to Bimmer^Hue Send a message via AIM to Bimmer^Hue Send a message via MSN to Bimmer^Hue Send a message via Yahoo to Bimmer^Hue Send a message via Skype™ to Bimmer^Hue
Originally Posted by adamo99 View Post
?? I'm pretty sure mine stays lit up until i fasten my seatbelt.
+1
2002 BMW 330i Titanium Silver Metallic | Gray Dakota Leather | 5-Speed | /// Sport, Winter and Premium Package
Bimmer^Hue is offline   Reply With Quote
Old 04-15-2009, 03:35 PM   #9
gphillips
My Ride: E46 323ci
I have the sport seats and my seatbelt light also comes on for a few seconds, and then goes off regardless of whether I fasten the belts or not. Is this a fault or by design?
Also I have an airbag warning light that my independant isnt able to diagnose - but he thought it might be related to a passenger occupancy sensor. Is it lilkely these two things are related?
gphillips is offline   Reply With Quote
Old 04-15-2009, 03:38 PM   #10
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
I have sports seats and the light only tirns off when i put on the seatbelt, The airbag light comes on when u put the ignition, but only as a diagnosis light, goes off shortly after !
Old 04-15-2009, 03:42 PM   #11
gphillips
My Ride: E46 323ci
What about the passenger side? If there is somebody sat in that seat do you get a seatbelt warning light (if they dont fasten the belt) or does it not work like that for the passenger?
I get a constan airbag light so clearly a problem
Old 04-15-2009, 03:44 PM   #12
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
doesn't worj with the passenger. it is only for driver !
Old 04-15-2009, 03:51 PM   #13
Safar
My Ride: comes with blow
I was lead to believe this was a setting in the car memory that could be toggled on/off by the dealer. In most US spec cars the light stays on until you buckle up, and apparently in European cars it's normally set to go off automatically after a few seconds. It also does this on mine.
As to the passenger, the car probably uses the seat occupancy sensor to determine whether it should keep the light on or not.
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 04-15-2009, 03:54 PM   #14
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
theires your answer
Old 04-15-2009, 07:30 PM   #15
Pir4t
My Ride: 323i -98
Send a message via MSN to Pir4t
Mine is a EU , light goes away after a few seconds whether its buckled or not.
One question tho ... bmw have a function to disable the airbag from deploying if no one is in the car (parked and seatbelt isn't buckled), this will probably disable that function will it ?
Pir4t is offline   Reply With Quote
Old 04-15-2009, 07:49 PM   #16
Acarder
My Ride: 04 330i, 99 328i
Well yes, but the airbags will always deploy in a crash if the car is turned on because you cant really be driving without anyone in the drivers seat.
Acarder is offline   Reply With Quote
Old 04-15-2009, 07:55 PM   #17
Fooljam
My Ride: 5
Make sense alright
Fooljam is offline   Reply With Quote
Old 04-15-2009, 10:06 PM   #18
fgin
My Ride: e46 facelift
Ive had a e46 in UK and now one in Australia and both have the light come and go off as in a timer. Has no affect if its bucked/not or passenger seated/empty. IMHO this light has no value or use in its present form.
fgin is online now   Reply With Quote
Old 04-15-2009, 11:45 PM   #19
Pir4t
My Ride: 323i -98
I was referring to this
Originally Posted by dillard View Post
18. The airbag system is 2 stage deployable depending on if the seat belts are latched. If there is no passenger, that front airbag wont even go off to save repair costs. (Along with the explosive seatbelt tensioners).
Old 04-16-2009, 12:44 AM   #20
HELLAS NC
I know the C class got the sensors in the passenger seat to trigger a buckle-up light, but not in the E46. The E90 got it though.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2010 performanceIX Inc - privacy policy - terms of use
