Old 04-15-2009, 11:40 AM   #1
mrwianno
My Ride: 325xi
Front transfer case lube.
for 2001 325xi, what is oil amount and specification for front transfer case.
mrwianno is offline   Reply With Quote
Old 04-15-2009, 11:49 AM   #2
GCoop
My Ride: '04 325xi
Differential or Transfer case???
Since you said front I assume you meant differential.
For the front differential you will want to use a synthetic 75W90 API GL-5 spec Gear oil. Capacity is just under 1 US qt. (.8 if i remember correctly)
ADDITIONAL INFO:
Rear Diff=Synthetic 75W90 API GL-5 spec Gear oil Capacity is just over 1 US QT. (1.125 if i remember correctly)
Transfer Case= 70W80 API GL-4 spec Gear Oil--Synthetic, if you can find it. Redline MTL is a good cantidate.
NOTE: Some people put ATF in their transfer case but it is WAY thinner than the original fill, 70W80 GL-4 gear oil is the closest that I have found to the original fill.
GCoop is offline   Reply With Quote
Old 04-15-2009, 11:53 AM   #3
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Transfer Case
Fluid Type MTF-LT1 Or MTF-LT2
Part Number 83-22-9-408-942 or 83 22 0 309 031
Lifetime fluid
Approved Final Drive Oils for Front and Rear Axle Final Drives
With and Without Limited Slip or Viscous Coupling
All models are factory filled with a synthetic final drive oil.
Limited Slip Differentials
BMW Synthetic Final Drive Oil (SAF-XJ)
(with multi-plate limited-slip differential)
Non Limited Slip Differentials
BMW Synthetic Final Drive Oil (SAF-XO)
(without multi-plate limited-slip differential, or with viscous differential lock [325iX/iXA])
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 04-15-2009, 01:30 PM   #4
76m2002
My Ride: 2002 325iT
For both Differentials I use Redline 75W90 Gear oil
For the transfer case and manual transmission I use Redline MTL
Ian
'01 325xiT
76m2002 is offline   Reply With Quote
Old 04-15-2009, 11:33 PM   #5
botaman
My Ride: 330xi/530 Blown
See attached link from Turnermotorsport.
http://www.turnermotorsport.com/html...=E46Xi-REDLINE
botaman is offline   Reply With Quote
Old 04-16-2009, 10:22 AM   #6
76m2002
My Ride: 2002 325iT
Somehow "common knowledge" has deemed D4ATF as the replacement for the tranny and transfer case fluid. When you read the specs MTL is the closest replacement, D4ATF is a little thin. Either is probably okay as long as you change them regularly (every 30K), but I prefer MTL. It's helped noisy hard-shifting Getrag transmissions for at least 15 years, and is still great stuff.
Ian
'01 325xiT
Old 04-16-2009, 01:32 PM   #7
GCoop
My Ride: '04 325xi
Ian
'01 325xiT
+1
Couldn't agree more
