Old 04-15-2009, 02:10 PM   #1
Rpaulino1
My Ride: 2002 325i
My e46 engine won't turn on!!!!
So..I'm about to turn on my car (2002 e46 325i) and all the lights turn on, on the dashboard but the engine won't start I try again with no luck, but a hear noise from underneath the driver side of the car....it's sounds like metal pulling or bending sort like a deep horn playing....I'm thinking its the fuel filter? doesn't seem at all electrical but any help would be appreciated
Rpaulino1 is offline   Reply With Quote
Old 04-15-2009, 02:12 PM   #2
warcraftjs
My Ride: 330CI 5 speed
Send a message via Yahoo to warcraftjs
Could be your battery, that is what happened to my 330ci. It was the battery. How old is your battery?
warcraftjs is offline   Reply With Quote
Old 04-15-2009, 02:12 PM   #3
Xeek
My Ride: 2000 328ci, 2010 328
Send a message via AIM to Xeek Send a message via Yahoo to Xeek
Hmm if she worked like my gf, all she needs is a few toys to get her turn.. oh your talking about the car.. hmm
So does it turn over or anything? Does the starter do anything? Hows your battery (check the voltage)?
2000 BMW 328Ci
2010 BMW 328i LCI
Xeek is offline   Reply With Quote
Old 04-15-2009, 02:16 PM   #4
Rpaulino1
My Ride: 2002 325i
I bought a new battery about 4 months ago.... I'll have to check the voltage just in case. Umm I don't hear any ticking at all when I try to turn it over... But what sucks I don't have a voltage meter.. but the thing is I doubt it the battery since all the lights turn on..No one thinks its the fuel pump or filter?
Old 04-15-2009, 02:58 PM   #5
DBear
My Ride: 2001 325i w/SportsPk
When my battery crapped out last year gave me no indication until I turned the ignition on. The interior fan came on suddenly (switch was in the off pos) and all the dash lights came on like a x-mas tree. Given everythihg that was going on I was kinda surprised to find out that it was my battery causing all of the problems.
Can't remember if my fuel pump came on or not. Was kinda dazzled by my dash lights at the time.
DBear is offline   Reply With Quote
Old 04-15-2009, 03:07 PM   #6
SweTurbo
Big Pimpin'
My Ride: 323i -98
If the engine cranks it's not the battery.
Low battery makes a "click" noise and the headlights flash once a second if you keep trying to start it.
Old 04-15-2009, 03:07 PM   #7
Rpaulino1
My Ride: 2002 325i
I think it is the damn battery.. I read a thread a few minutes ago, stating that if the wipers are moving slower then usual that it was a good indicator that the battery is dead so I just went out and the wipers were slow as can be I turned my headlights on then everything on the dashboard started dimming away. And I finally started hearing clicking noise.
Old 04-15-2009, 03:09 PM   #8
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
My Ride: 2001 / 330i
Send a message via MSN to ShaitanCR
The battery will always be the most inmprtant part of the e46. always change the battery for a fresh new one before spending big bucks.
That sound under the driver side, i don't know. Is the fuel pump located their ?
************! STEPTRONIC ALL THE WAY...
*SPL Car Audio Champion*
Hamann EURO Black Shadowline Grills
Black EURO 330i emblem
Carbon Fiber Hamann Style Eyelids
Carbon Fiber Emblems
Clear Turn Lights and Sidemarkers
ShaitanCR is offline   Reply With Quote
Old 04-15-2009, 03:11 PM   #9
CB434
My Ride: BMW
No, but it is on the drivers side of the vehicle. Without paying real close attention you might get fooled. When you power on the ignition, the fuel system pressurizes. That's the sound he's hearing.
I'd put a multimeter across the battery
Originally Posted by sull78ds
When i finally made it home i naturally checked the oil to find out THERE WAS NONE!!!!! WTF?!?!?!? So i got back in the car and decided to drive to Autozone to get me some oil
CB434 is offline   Reply With Quote
Old 04-15-2009, 03:25 PM   #10
Rpaulino1
My Ride: 2002 325i
Lucky I have a warranty on the battery...so when I get a ride to Autozone and replace it...I'll post what happens
Old 04-15-2009, 03:27 PM   #11
warcraftjs
If your battery is low. Then I would look into your battery being bad, bad alt., or a drain somewere.
Old 04-15-2009, 03:27 PM   #12
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
good luck ! remember to let the ignition do its thing, instead of just yanking the key and starting right off.
Old 04-15-2009, 03:30 PM   #13
vladvm
My Ride: 2002 325i
Use the on-board Voltmeter...
Hold odometer reset, turn key to ON
then keep pressing reset until 19.0 is displayed
pause for 1 sec until 19.0 display blinks...
then keep pressing until display shows 9.0
display should read 12.5, if not battery faulty.
if volts display is 12.5 try starting your car, if voltage drops to 10..then doesn't come back up, then battery is surely faulty.
BMW 325i
vladvm is offline   Reply With Quote
Old 04-15-2009, 03:33 PM   #14
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
thats new to me. WOW ! does that work on all BMW or all e46 ?
turn key to ON ? turn car on, or just put in ignition?
will the display stay on Volt ?
Old 04-15-2009, 03:55 PM   #15
vladvm
My Ride: 2002 325i
turn key to on.
Yes, will stay on volt even when you are driving.
BMW 325i
Old 04-15-2009, 03:57 PM   #16
ShaitanCR
Carbon Fiber Member
ShaitanCR's Avatar
If you have any more tricks like that you should post them, on PM me with them ! thnxs
Old 04-15-2009, 03:59 PM   #17
Xeek
That's a trick I have never heard of. How did you know about that?
2000 BMW 328Ci
2010 BMW 328i LCI
Old 04-15-2009, 04:03 PM   #18
vladvm
My Ride: 2002 325i
search for e46 easter egg
BMW 325i
Old 04-15-2009, 04:10 PM   #19
Rpaulino1
My Ride: 2002 325i
I changed the alternator in January so I don't think it's that....I still believe its the battery because I've had to jump start it a couple of times a few months back, I'm guessing it is a faulty battery since I bought it brand new
Old 04-15-2009, 05:02 PM   #20
Xeek
Can't seem to get that to work on my car. I get tEST if I keep holding I get rESET. In tEST if I keep pressing the button I go through a bunch of different things, but nothing that says 19.0
2000 BMW 328Ci
2010 BMW 328i LCI
